lalajee2 0 Posted April 14, 2024 Posted April 14, 2024 Hi, I have Portable version of Emby on my PC and I would like to migrate this onto my Synology box. Is it possible to do this without using backup/restore on Emby?
Abobader 3484 Posted April 14, 2024 Posted April 14, 2024 Hello lalajee2, ** This is an auto reply ** Please wait for someone from staff support or our members to reply to you. It's recommended to provide more info, as it explain in this thread: Thank you. Emby Team
Happy2Play 9799 Posted April 14, 2024 Posted April 14, 2024 Do both servers have the same users? If they do the question becomes do they have the same userid in the each database? Littler harder to know. But would require creating a backup on PC and pointing backup plugin on Synology to that back and extracting userdata from that backup. Otherwise you would have to extract userdatas table from database and import into synology db. But same issue would be userid alignment.
lalajee2 0 Posted April 14, 2024 Author Posted April 14, 2024 I have create same username with same password
Happy2Play 9799 Posted April 14, 2024 Posted April 14, 2024 55 minutes ago, lalajee2 said: I have create same username with same password In theory then you would have to do as mentioned above. 7 hours ago, Happy2Play said: require creating a backup on PC and pointing backup plugin on Synology to that back and extracting userdata from that backup. Then you should be able to map users if they are misaligned.
