sftech13 25 Posted April 13, 2024 Posted April 13, 2024 So I deleted one of my libraries and then the other libraries don't show any content. I have check permissions. They're good. I rescan the files only partial of the library show up. Still missing a few different libraries. I checked the library DB. Everything was fine. I even rebuilt it. Same situation. Question, can I delete the library DB? Let it regenerate a new one and be able to keep all my users watch status regardless if they have trackt or not?
Luke 42184 Posted April 13, 2024 Posted April 13, 2024 Quote Question, can I delete the library DB? Hi, you can, but you'll have to redo quite a bit of settings as most data and config is stored there.
sftech13 25 Posted April 13, 2024 Author Posted April 13, 2024 So I am rerunning library scan now and it may work. Its at like 45%. Ill wait it out. The Latest TV Show Icons are small when they are usually the same size as movies.
sftech13 25 Posted April 13, 2024 Author Posted April 13, 2024 (edited) The scan is sitting at 44%. I attached a log for any help. I noticed some errors @Luke 2024-04-13 12:35:20.377 Info QuickImageSeriesExtractor: ProcessRun 'quick-extract-imageseries' Process exited with code 0 - Succeeded 2024-04-13 12:35:20.377 Info QuickImageSeriesExtractor: ProcessRun 'quick-extract-imageseries' Execute: /opt/emby-server/bin/ffmpeg -f matroska -threads 1 -skip_interval 10 -copyts -i file:"/media/Movies/The Babysitter (2017)/The Babysitter (2017) {imdb-tt4225622} [Bluray-1080p][AC3 5.1][x264]-nikt0.mkv" -an -sn -vf "scale=w=320:h=180" -vsync cfr -r 0.1 -f image2 "/var/lib/emby/cache/temp/2a4b5b8c835f4f94acdf806b42e2ef35/img_%05d.jpg" 2024-04-13 12:35:20.425 Info MediaProbeManager: ProcessRun 'ffprobe' Execute: /opt/emby-server/bin/ffprobe -i file:"/media/TV Shows/Fargo (2014) [imdb-tt2802850]/Season 01/Fargo (2014) - S01E03 - A Muddy Road [NF WEBDL-1080p][EAC3 5.1][PT+EN][x264].mkv" -threads 0 -v info -print_format json -show_streams -show_chapters -show_format -show_data 2024-04-13 12:35:20.484 Info MediaProbeManager: ProcessRun 'ffprobe' Process exited with code 0 - Succeeded 2024-04-13 12:35:20.661 Info HttpClient: POST https://api.trakt.tv/sync/collection 2024-04-13 12:35:21.042 Error Trakt: Exception handled processing queued movie events *** Error Report *** Version: 4.8.3.0 Command line: /opt/emby-server/system/EmbyServer.dll -programdata /var/lib/emby -ffdetect /opt/emby-server/bin/ffdetect -ffmpeg /opt/emby-server/bin/ffmpeg -ffprobe /opt/emby-server/bin/ffprobe -restartexitcode 3 -updatepackage emby-server-deb_{version}_amd64.deb Operating system: Linux version 5.4.0-176-generic (buildd@bos03-amd64-046) (gcc version 9.4.0 (Ubuntu 9.4.0-1ubuntu1~20.04.2)) #196-Ubuntu SMP Fri Mar 22 16:46:39 UTC 2 Framework: .NET 6.0.25 OS/Process: x64/x64 Runtime: opt/emby-server/system/System.Private.CoreLib.dll Processor count: 8 Data path: /var/lib/emby Application path: /opt/emby-server/system MediaBrowser.Model.Net.HttpException: MediaBrowser.Model.Net.HttpException: BadGateway at Emby.Server.Implementations.HttpClientManager.CoreHttpClientManager.SendAsyncInternal(HttpRequestOptions options, String httpMethod) at Emby.Server.Implementations.HttpClientManager.CoreHttpClientManager.SendAsync(HttpRequestOptions options, String httpMethod) at Trakt.Api.TraktApi.PostToTrakt(String url, Object data, TraktUser traktUser, CancellationToken cancellationToken) at Trakt.Api.TraktApi.SendLibraryUpdateAsync(List`1 movies, TraktUser traktUser, CancellationToken cancellationToken, EventType eventType) at Trakt.Helpers.LibraryManagerEventsHelper.ProcessQueuedMovieEvents(List`1 events, TraktUser traktUser, EventType eventType, CancellationToken cancellationToken) Source: Emby.Server.Implementations TargetSite: Void MoveNext() embyserver.txt Edited April 13, 2024 by Matt_Simoni
Happy2Play 9799 Posted April 14, 2024 Posted April 14, 2024 3 hours ago, Matt_Simoni said: The scan is sitting at 44%. I attached a log for any help. I noticed some errors @Luke 2024-04-13 12:35:20.377 Info QuickImageSeriesExtractor: ProcessRun 'quick-extract-imageseries' Process exited with code 0 - Succeeded 2024-04-13 12:35:20.377 Info QuickImageSeriesExtractor: ProcessRun 'quick-extract-imageseries' Execute: /opt/emby-server/bin/ffmpeg -f matroska -threads 1 -skip_interval 10 -copyts -i file:"/media/Movies/The Babysitter (2017)/The Babysitter (2017) {imdb-tt4225622} [Bluray-1080p][AC3 5.1][x264]-nikt0.mkv" -an -sn -vf "scale=w=320:h=180" -vsync cfr -r 0.1 -f image2 "/var/lib/emby/cache/temp/2a4b5b8c835f4f94acdf806b42e2ef35/img_%05d.jpg" 2024-04-13 12:35:20.425 Info MediaProbeManager: ProcessRun 'ffprobe' Execute: /opt/emby-server/bin/ffprobe -i file:"/media/TV Shows/Fargo (2014) [imdb-tt2802850]/Season 01/Fargo (2014) - S01E03 - A Muddy Road [NF WEBDL-1080p][EAC3 5.1][PT+EN][x264].mkv" -threads 0 -v info -print_format json -show_streams -show_chapters -show_format -show_data 2024-04-13 12:35:20.484 Info MediaProbeManager: ProcessRun 'ffprobe' Process exited with code 0 - Succeeded 2024-04-13 12:35:20.661 Info HttpClient: POST https://api.trakt.tv/sync/collection 2024-04-13 12:35:21.042 Error Trakt: Exception handled processing queued movie events *** Error Report *** Version: 4.8.3.0 Command line: /opt/emby-server/system/EmbyServer.dll -programdata /var/lib/emby -ffdetect /opt/emby-server/bin/ffdetect -ffmpeg /opt/emby-server/bin/ffmpeg -ffprobe /opt/emby-server/bin/ffprobe -restartexitcode 3 -updatepackage emby-server-deb_{version}_amd64.deb Operating system: Linux version 5.4.0-176-generic (buildd@bos03-amd64-046) (gcc version 9.4.0 (Ubuntu 9.4.0-1ubuntu1~20.04.2)) #196-Ubuntu SMP Fri Mar 22 16:46:39 UTC 2 Framework: .NET 6.0.25 OS/Process: x64/x64 Runtime: opt/emby-server/system/System.Private.CoreLib.dll Processor count: 8 Data path: /var/lib/emby Application path: /opt/emby-server/system MediaBrowser.Model.Net.HttpException: MediaBrowser.Model.Net.HttpException: BadGateway at Emby.Server.Implementations.HttpClientManager.CoreHttpClientManager.SendAsyncInternal(HttpRequestOptions options, String httpMethod) at Emby.Server.Implementations.HttpClientManager.CoreHttpClientManager.SendAsync(HttpRequestOptions options, String httpMethod) at Trakt.Api.TraktApi.PostToTrakt(String url, Object data, TraktUser traktUser, CancellationToken cancellationToken) at Trakt.Api.TraktApi.SendLibraryUpdateAsync(List`1 movies, TraktUser traktUser, CancellationToken cancellationToken, EventType eventType) at Trakt.Helpers.LibraryManagerEventsHelper.ProcessQueuedMovieEvents(List`1 events, TraktUser traktUser, EventType eventType, CancellationToken cancellationToken) Source: Emby.Server.Implementations TargetSite: Void MoveNext() embyserver.txt 6.37 MB · 0 downloads Looks like Trakt only complained once in that log or a network issue on their end as following connections has no issues.
Luke 42184 Posted April 15, 2024 Posted April 15, 2024 On 4/13/2024 at 4:49 PM, Matt_Simoni said: The scan is sitting at 44%. I attached a log for any help. I noticed some errors @Luke 2024-04-13 12:35:20.377 Info QuickImageSeriesExtractor: ProcessRun 'quick-extract-imageseries' Process exited with code 0 - Succeeded 2024-04-13 12:35:20.377 Info QuickImageSeriesExtractor: ProcessRun 'quick-extract-imageseries' Execute: /opt/emby-server/bin/ffmpeg -f matroska -threads 1 -skip_interval 10 -copyts -i file:"/media/Movies/The Babysitter (2017)/The Babysitter (2017) {imdb-tt4225622} [Bluray-1080p][AC3 5.1][x264]-nikt0.mkv" -an -sn -vf "scale=w=320:h=180" -vsync cfr -r 0.1 -f image2 "/var/lib/emby/cache/temp/2a4b5b8c835f4f94acdf806b42e2ef35/img_%05d.jpg" 2024-04-13 12:35:20.425 Info MediaProbeManager: ProcessRun 'ffprobe' Execute: /opt/emby-server/bin/ffprobe -i file:"/media/TV Shows/Fargo (2014) [imdb-tt2802850]/Season 01/Fargo (2014) - S01E03 - A Muddy Road [NF WEBDL-1080p][EAC3 5.1][PT+EN][x264].mkv" -threads 0 -v info -print_format json -show_streams -show_chapters -show_format -show_data 2024-04-13 12:35:20.484 Info MediaProbeManager: ProcessRun 'ffprobe' Process exited with code 0 - Succeeded 2024-04-13 12:35:20.661 Info HttpClient: POST https://api.trakt.tv/sync/collection 2024-04-13 12:35:21.042 Error Trakt: Exception handled processing queued movie events *** Error Report *** Version: 4.8.3.0 Command line: /opt/emby-server/system/EmbyServer.dll -programdata /var/lib/emby -ffdetect /opt/emby-server/bin/ffdetect -ffmpeg /opt/emby-server/bin/ffmpeg -ffprobe /opt/emby-server/bin/ffprobe -restartexitcode 3 -updatepackage emby-server-deb_{version}_amd64.deb Operating system: Linux version 5.4.0-176-generic (buildd@bos03-amd64-046) (gcc version 9.4.0 (Ubuntu 9.4.0-1ubuntu1~20.04.2)) #196-Ubuntu SMP Fri Mar 22 16:46:39 UTC 2 Framework: .NET 6.0.25 OS/Process: x64/x64 Runtime: opt/emby-server/system/System.Private.CoreLib.dll Processor count: 8 Data path: /var/lib/emby Application path: /opt/emby-server/system MediaBrowser.Model.Net.HttpException: MediaBrowser.Model.Net.HttpException: BadGateway at Emby.Server.Implementations.HttpClientManager.CoreHttpClientManager.SendAsyncInternal(HttpRequestOptions options, String httpMethod) at Emby.Server.Implementations.HttpClientManager.CoreHttpClientManager.SendAsync(HttpRequestOptions options, String httpMethod) at Trakt.Api.TraktApi.PostToTrakt(String url, Object data, TraktUser traktUser, CancellationToken cancellationToken) at Trakt.Api.TraktApi.SendLibraryUpdateAsync(List`1 movies, TraktUser traktUser, CancellationToken cancellationToken, EventType eventType) at Trakt.Helpers.LibraryManagerEventsHelper.ProcessQueuedMovieEvents(List`1 events, TraktUser traktUser, EventType eventType, CancellationToken cancellationToken) Source: Emby.Server.Implementations TargetSite: Void MoveNext() embyserver.txt 6.37 MB · 1 download HI, please try removing these plugins: 2024-04-13 10:26:18.546 Info App: Loading ComSkipper, Version=2.0.0.0, Culture=neutral, PublicKeyToken=null from /var/lib/emby/plugins/ComSkipper.dll 2024-04-13 10:26:18.546 Info App: Loading CustomProviderbeta, Version=1.0.0.3200, Culture=neutral, PublicKeyToken=null from /var/lib/emby/plugins/CustomProviderbeta.dll 2024-04-13 10:26:18.546 Info App: Loading Emby.Bulky, Version=1.0.20.0, Culture=neutral, PublicKeyToken=null from /var/lib/emby/plugins/Emby.Bulky.dll Then restart the server and see how things compare.
Solution sftech13 25 Posted April 15, 2024 Author Solution Posted April 15, 2024 I just let it run and it looks good. Some of the latest media dates are incorrect but its ok. Thank you 1
