deelight 2 Posted March 15, 2025 Posted March 15, 2025 59 minutes ago, Luke said: HI, did you remove what you accidentally added? Yes, immediately after adding it. I managed to get the server running again after shutting it down, removing /var/lib/emby/data/library.db, restarting Emby and recreating my libraries. 2
sa2000 703 Posted March 17, 2025 Author Posted March 17, 2025 On 15/03/2025 at 04:17, deelight said: I managed to get the server running again after shutting it down, removing /var/lib/emby/data/library.db, restarting Emby and recreating my libraries With 4.9.0.42 and later, it should be sufficient to just remove the erroneous path and the media libraries would adjust and get recovered
