ntls2000 5 Posted April 10, 2024 Posted April 10, 2024 Je rencontre un problème avec la mise à jour des séries TV. Le synopsis ne se mets pas en français, mais en anglais. Sur la fiche de thetvdb, le français est disponible. 2024-04-10 07:23:55.253 Info App: Sorting file /incoming/tvshows/Gotham Knights - S01E01 - Pilot.mkv 2024-04-10 07:23:55.256 Info HttpClient: GET https://api4.thetvdb.com/v4/search?type=series&q=Gotham Knights 2024-04-10 07:23:55.526 Info HttpClient: GET https://api4.thetvdb.com/v4/series/420061/episodes/official/fra?page=0 2024-04-10 07:23:56.041 Info HttpClient: GET https://api4.thetvdb.com/v4/episodes/9162339/extended 2024-04-10 07:23:56.239 Info App: Sorting file /incoming/tvshows/Gotham Knights - S01E01 - Pilot.mkv into series /tvshows/Gotham Knights (2023) 2024-04-10 07:23:56.239 Info App: Sorting file /incoming/tvshows/Gotham Knights - S01E01 - Pilot.mkv to new path /tvshows/Gotham Knights (2023)/Season 1/Gotham Knights - S01E01 - Pilot.mkv 2024-04-10 07:24:22.305 Info LibraryMonitor: tvshows (/tvshows) will be refreshed. 2024-04-10 07:24:22.306 Info LibraryMonitor: tvshows (/tvshows) will be refreshed. 2024-04-10 07:24:22.307 Info LibraryMonitor: tvshows (/tvshows) will be refreshed. 2024-04-10 07:24:22.308 Info LibraryMonitor: tvshows (/tvshows) will be refreshed. 2024-04-10 07:24:22.313 Info LibraryMonitor: tvshows (/tvshows) will be refreshed. 2024-04-10 07:24:22.313 Info LibraryMonitor: tvshows (/tvshows) will be refreshed. 2024-04-10 07:24:22.314 Info LibraryMonitor: tvshows (/tvshows) will be refreshed. 2024-04-10 07:24:22.889 Info HttpClient: GET https://api4.thetvdb.com/v4/search?type=series&q=Gotham Knights&year=2023 2024-04-10 07:24:23.192 Info MediaProbeManager: ProcessRun 'ffprobe' Execute: /bin/ffprobe -i file:"/tvshows/Gotham Knights (2023)/Season 1/Gotham Knights - S01E01 - Pilot.mkv" -threads 0 -v info -print_format json -show_streams -show_chapters -show_format -show_data 2024-04-10 07:24:23.223 Info MediaProbeManager: ProcessRun 'ffprobe' Process exited with code 0 - Succeeded 2024-04-10 07:24:23.227 Info HttpClient: GET https://api4.thetvdb.com/v4/series/420061/episodes/official/fra?page=0 2024-04-10 07:24:23.456 Info HttpClient: GET https://api4.thetvdb.com/v4/episodes/9162339/extended 2024-04-10 07:24:23.659 Info App: /tvshows/Gotham Knights (2023)/Season 1 has 0 episodes with audio fingerprints available 2024-04-10 07:24:42.551 Info LibraryMonitor: test (/config/data/userplaylists/test [playlist]/test.m3u) will be refreshed. 2024-04-10 07:25:09.887 Info App: Sqlite: 284 - automatic index on LastWatchedEpisodes(SeriesPresentationUniqueKey) 2024-04-10 07:25:11.632 Info HttpClient: GET https://artworks.thetvdb.com/banners/v4/series/420061/posters/63ee9e71cf3a7.jpg 2024-04-10 07:25:13.684 Info App: Sqlite: 284 - automatic index on LastWatchedEpisodes(SeriesPresentationUniqueKey) 2024-04-10 07:25:13.702 Info HttpClient: GET https://artworks.thetvdb.com/banners/v4/series/420061/backgrounds/64117fe4d84e0.jpg 2024-04-10 07:25:13.702 Info HttpClient: GET https://artworks.thetvdb.com/banners/v4/series/420061/clearlogo/641202a7bbb75.png 2024-04-10 07:25:13.791 Info HttpClient: GET https://artworks.thetvdb.com/banners/v4/episode/9162339/screencap/64b412d61365e.jpg 2024-04-10 07:25:13.811 Info App: Sqlite: 284 - automatic index on LastWatchedEpisodes(SeriesPresentationUniqueKey) 2024-04-10 07:25:25.724 Info App: Sqlite: 284 - automatic index on LastWatchedEpisodes(SeriesPresentationUniqueKey) 2024-04-10 07:25:42.617 Info LibraryMonitor: test (/config/data/userplaylists/test [playlist]/test.m3u) will be refreshed. 2024-04-10 07:25:47.094 Info LibraryMonitor: Gotham Knights (/tvshows/Gotham Knights (2023)) will be refreshed. 2024-04-10 07:25:47.094 Info LibraryMonitor: Pilot (/tvshows/Gotham Knights (2023)/Season 1/Gotham Knights - S01E01 - Pilot.mkv) will be refreshed.
MAX92 93 Posted April 11, 2024 Posted April 11, 2024 Bonjour, Est-ce que tu as bien sélectionné Français dans la médiathèque ?
ntls2000 5 Posted April 13, 2024 Author Posted April 13, 2024 j'ai du supprimer la librairie, et ensuite je l'ai recrée Cela fonctionne, un bug certainement lors de la creation de la librairie.
Happy2Play 9811 Posted April 13, 2024 Posted April 13, 2024 Issue is there is not French translation for the show via the Show query. Quote 2024-04-10 07:23:55.256 Info HttpClient: GET https://api4.thetvdb.com/v4/search?type=series&q=Gotham Knights 2024-04-10 07:23:55.526 Info HttpClient: GET https://api4.thetvdb.com/v4/ series/420061/episodes/official/eng?page=0 { "status": "failure", "message": "NotFoundException: error fetching ", "data": null } So it fallback to episode query 2024-04-10 07:24:23.456 Info HttpClient: GET https://api4.thetvdb.com/v4/episodes/9162339/extended But then loses language. @Lukeshouldn't a fallback to episode actually do "/episodes/{ID}/extended?meta=translations" to be able to attempt to maintain language variable since it is lost do to not existing at Series level? As without "?meta=translations" it will never see translations per episode.
Luke 42239 Posted April 16, 2024 Posted April 16, 2024 @Happy2Playhave they already fixed something do you think? I set a test library to french, added this series, and I got everything back in french.
Happy2Play 9811 Posted April 16, 2024 Posted April 16, 2024 37 minutes ago, Luke said: @Happy2Playhave they already fixed something do you think? I set a test library to french, added this series, and I got everything back in french. pretty sure it is related to issue 323 but yes translations appear to working again at least in this case. 1
Happy2Play 9811 Posted April 16, 2024 Posted April 16, 2024 (edited) Appears the TVDB ticket above has been closed. Can everyone verify they can now get correct data. If not please provide specific examples. Edited April 16, 2024 by Happy2Play 1
