griam01 14 Posted April 10, 2024 Posted April 10, 2024 (edited) Seems like sometime today my EPG data fails to load anymore Here is what is in the log, I confirmed from the link there is data in there, but emby seems to be crashing when loading. I rebooted, removed the plugins and readded them, still the same. 2024-04-09 21:56:52.759 Info TaskManager: Executing Refresh Guide 2024-04-09 21:56:52.778 Info HttpClient: GET https://tinyurl.com/x_path1_x 2024-04-09 21:56:53.547 Info HttpClient: GetTempFileResponse url: https://tinyurl.com/x_path2_x 2024-04-09 21:56:53.547 Info HttpClient: GET https://tinyurl.com/x_path2_x 2024-04-09 21:56:54.266 Error LiveTvManager: Error getting channels *** Error Report *** Version: 4.8.3.0 Command line: C:\Users\Emby\AppData\Roaming\Emby-Server\system\EmbyServer.dll -noautorunwebapp Operating system: Microsoft Windows 10.0.22000 Framework: .NET 6.0.27 OS/Process: x64/x64 Runtime: C:/Users/Emby/AppData/Roaming/Emby-Server/system/System.Private.CoreLib.dll Processor count: 4 Data path: C:\Users\Emby\AppData\Roaming\Emby-Server\programdata Application path: C:\Users\Emby\AppData\Roaming\Emby-Server\system System.Xml.XmlException: System.Xml.XmlException: An error occurred while parsing EntityName. Line 9, position 543. at Emby.XmlTV.XmlTvProvider.GetXmlDataCache(ListingsProviderInfo info, CancellationToken cancellationToken) at Emby.XmlTV.XmlTvProvider.GetChannels(ListingsProviderInfo info, CancellationToken cancellationToken) at Emby.LiveTV.LiveTvManager.RefreshEmbyChannelsInternal(IProgress`1 progress, CancellationToken cancellationToken) Source: Emby.XmlTV TargetSite: Void MoveNext() Edited April 10, 2024 by griam01
Luke 42241 Posted April 10, 2024 Posted April 10, 2024 Hi there, please attach the complete emby server log file. Thanks.
griam01 14 Posted April 10, 2024 Author Posted April 10, 2024 embyserver-63848304000.txt I was able to put the file locally versus a dropbox link and it worked but this has been working for months like this and just started yesterday. If I download the file via dropbox it does contain the data and no errors pulling it down and opening it.
Luke 42241 Posted April 10, 2024 Posted April 10, 2024 HI, what it appears is that the xml url is not sending back valid xml data.
griam01 14 Posted May 23, 2024 Author Posted May 23, 2024 @Lukethis is still causing an issue, can you check the latest logs and see if you are still showing the same problem with the xml url not sending back valid data? Others don't seem to be having the issue. I tried full link and shortened url to dropbox and both just show a blank screen under live tv. When I do a refresh of guide data with either dropbox url (shortened or not), it comes back immediately as done. As soon as I put in a local file on my computer, it works. Attaching latest logs from this morning where I tested this after a reboot, then switched to local file. embyserver(6).txt
Luke 42241 Posted May 24, 2024 Posted May 24, 2024 I'm not really sure. Could dropbox at some point be returning an older version?
griam01 14 Posted May 24, 2024 Author Posted May 24, 2024 @LukeI ended up moving this to google drive and it seems to be fine now, we will see how it continues to function. 1
