AdrianW 1058 Posted November 6, 2014 Posted November 6, 2014 After updating to 229 the "Switch To..." from the User menu is no longer working - it returns you to the initial login select user screen. (In both Chocolate and Classic)
Solution ebr 16334 Posted November 6, 2014 Solution Posted November 6, 2014 Thanks. Will be fixed in the next build.
