speechles 2062 Posted April 24, 2024 Posted April 24, 2024 @scott46953Apologies. As mentioned above we would need an example to know why this occurs. If you can provide one we could better solve this. In the meantime...The most obvious reason this happens is they are not using "Auto" for their video quality. You might tell your remote users to choose "Auto" for their video quality. Otherwise it is possible they can choose a video quality which will over saturate your connection. This would cause endless buffering hell for them which is exactly as are describe to us. If you know exactly what upload speed you want them to consume that would be best to set their video quality with. They then can set their video quality to match that speed you suggest to them.
ebr 16334 Posted April 25, 2024 Posted April 25, 2024 If we're talking Live TV on the Roku, I don't believe it will ever direct play. It will always at least remux.
scott46953 31 Posted April 25, 2024 Author Posted April 25, 2024 @speechlesVery few of my users use Auto, I manually set all my users based on what I believe is good for them on the size of their tv VS their internet speeds on Wifi. However, most are at 5mb and some are at 3mb, the ones that have troubles are lowered to 2 or 1mb. But, when this happens, it does not matter what selection it is on. it will just buffer buffer buffer. then i have to hear how sling, youtube and other streaming apps are perfectly fine. Most of the time it seems to be mainly ROKU Devices that have this issue. But when the same person, same setup changes the ROKU to a FireStick the issue goes away? I keep trying to explain to people to reboot their devices. I even reboot the server and sometimes that fixes their issues. However, nobody wants to add an Auto Reboot task... but instead ask to see and resolve the issues. But nothing seems to have been done and I am now getting less people watching. The result is now i no longer need all the connecctions I am paying for. So how to I Remove the extra monthly connections? DO not need to pay for something I am no longer using on AUTO PAY....
scott46953 31 Posted April 25, 2024 Author Posted April 25, 2024 (edited) I can get it to direct play after selecting Several settings in the device i am watching it on. Settings LIVE TV Direct Play Live TV Option Allow Video Stream Copy Option then I go back to Playback options Allow Direct Play of TS Files Then regardless of the selected quality setting the users settings on the server for the user it will direct play the stream. Edited April 25, 2024 by scott46953
ebr 16334 Posted April 25, 2024 Posted April 25, 2024 Just now, scott46953 said: Settings LIVE TV Direct Play Live TV Option Allow Video Stream Copy Option then I go back to Playback options Allow Direct Play of TS Files Those are all in the Android/Fire app, not the Roku.
ebr 16334 Posted April 25, 2024 Posted April 25, 2024 Just now, scott46953 said: So how to I Remove the extra monthly connections? How do I Upgrade my Emby Premiere Membership? Same would apply to downgrading it but, if you still have problems, just shoot an email to billingsupport@emby.media.
scott46953 31 Posted April 25, 2024 Author Posted April 25, 2024 How does somebody with the Roku direct stream?
ebr 16334 Posted April 25, 2024 Posted April 25, 2024 Just now, scott46953 said: How does somebody with the Roku direct stream? That's what I'm saying. If you're talking live TV, the Roku cannot. It will always at least remux and this could be the difference that you are seeing.
scott46953 31 Posted April 25, 2024 Author Posted April 25, 2024 Everybody on my server remuxes, nobody except for myself has the live direct stream options enabled because they're not enabled by default, that's not the differences that I'm seeing, any other ideas? The log files there
scott46953 31 Posted April 25, 2024 Author Posted April 25, 2024 In advance settings there is buffer settings, there's two different ones, excuse my memory, I took the default value times three and enter that manually in the spot. Complaints have limited, but I did reboot this morning. 1
scott46953 31 Posted April 29, 2024 Author Posted April 29, 2024 (edited) had a complant yesterday late afternoon, Roku person says unwatchable. Also says the channels drop out at the top of the hour, then i got to thinking... does this have anything to do with commerical skip? or is there another task that I do not need as a plugin that is causing iptv channels to stop or freeze to a stopping point at the top of the hour? it also have at the 30 of hour hour as well, but not as often.. This could also lead to buffering during quick dropout times, so it maybe related to the buffering, but not sure at this point. just an idea. I was also watching tv on android and did not notice anything on Nvidia box. But i was watching recorded tv. When i switched to live tv, i did not see any issues, neither did anyone else.. So I instructed the person to reboot the Roku and let them know the Emby team is checking into the issue. here is the log file, the server was not rebooted over the weekend. so any issues should show up on this log. embyserver-63849945600.zip Also A-team s1e4 and s1e5 is stuck as ghost on my screen as one, and flip flops... My iptv server says i have stream running today and nothing is showing on my server. a reboot of server fixes the stuck streams Edit, just received a second complaint of buffering over the weekend. Normal people that have been watching for years are saying unwatchable buffering or stopping of channels... I will start rebooting the server everyday including the weekends... especially before any big events... Dont need an reboot task?? but you want to fix the issue? How long will it take to resolve? Edited April 29, 2024 by scott46953
ebr 16334 Posted April 29, 2024 Posted April 29, 2024 1 hour ago, scott46953 said: does this have anything to do with commerical skip? Have you tried removing that plug-in and seeing if the problem goes away?
scott46953 31 Posted April 29, 2024 Author Posted April 29, 2024 If that is what the log file says, then will remove the highly wanted plugin and contact the commercial skip plugin, should I also remove the "on record run comskip" in the scripter-x settings? Or just the plugin?
Luke 42241 Posted April 30, 2024 Posted April 30, 2024 13 hours ago, scott46953 said: If that is what the log file says, then will remove the highly wanted plugin and contact the commercial skip plugin, should I also remove the "on record run comskip" in the scripter-x settings? Or just the plugin? Yes, both. All third party plugins. That's generally the first step to troubleshooting problems that are hard to track down. That helps remove unknown variables. Thanks.
scott46953 31 Posted April 30, 2024 Author Posted April 30, 2024 Have not removed plugins yet, reboot seems to fix the problem fine and I get to keep the plugins, so I'll just manually reboot once a day. I went long enough without my commercial skip earlier this month. I guess when I decide that rebooting is too much of a headache to do manually I'll come back to the Post.
scott46953 31 Posted May 16, 2024 Author Posted May 16, 2024 commercial skip and scripterX has been uninstalled I will now run the server without reboots until buffering and channel stops happen, once that is complete I will send a new log file. tired of getting messages on my phone of this issue when i'm out doing my daily busy tasks. 1
scott46953 31 Posted May 20, 2024 Author Posted May 20, 2024 here is 2 log files from the weekend. embyserver-63851760000.zip embyserver-63851673600.zip
scott46953 31 Posted May 21, 2024 Author Posted May 21, 2024 it seems to run for longer times/days but still needs restarted after a period of time.
scott46953 31 Posted May 22, 2024 Author Posted May 22, 2024 I've had a couple people say that it seems to be quite a bit better, there's still some buffering and some dropouts but is an improvement.. just wondering if you had a chance to look at the log file to see if there's anything else causing delay?
scott46953 31 Posted May 22, 2024 Author Posted May 22, 2024 Also wondering if emby is making use of all the CPUs? Does emby server only use one CPU or is it allowing it to use multiple threads?
Luke 42241 Posted May 23, 2024 Posted May 23, 2024 The transcoding process is multithreaded. I would suggest lowering the quality setting in the app that you're playing from and see if that helps. Thanks.
scott46953 31 Posted May 23, 2024 Author Posted May 23, 2024 Unfortunately that's not the question I asked. I asked if emby app is making use of multi-threading? I already know the transcode is multi-threading. We already know that lower in the quality does not change the outcome of the buffering issue. I understand you got a lot of stuff going on so just letting you know, the actual question maybe I wasn't clear.
Luke 42241 Posted May 27, 2024 Posted May 27, 2024 That will vary per client. User interfaces run on the main thread. Whether each client video player is multi-threaded or not, video players don't generally document that, but since many of them are based on ffmpeg I would say yes.
scott46953 31 Posted May 27, 2024 Author Posted May 27, 2024 So to be clear and to answer my question. Emby processes run on a single thread and is not multi-threading enabled. Playing video which is multithreading using the encoder/decoder program which is customized by emby
