Vicpa 612 Posted April 9, 2024 Posted April 9, 2024 Hi, My client uses the old version of the Api client. The playback reporting methods Start, Progress and Stop, are the area I could use some help Start method: fails looking for another property what else do I need to add ? The methods I am using are below: /// <summary> /// Reports playback start /// </summary> /// <param name="info">The information.</param> /// <param name="isOffline">if set to <c>true</c> [is offline].</param> /// <param name="apiClient">The current apiClient. It can be null if offline</param> /// <returns>Task.</returns> public async Task ReportPlaybackStart(PlaybackStartInfo info, bool isOffline, IApiClient apiClient) { if (!isOffline) { await apiClient.ReportPlaybackStartAsync(info).ConfigureAwait(false); } } /// <summary> /// Reports playback progress /// </summary> /// <param name="info">The information.</param> /// <param name="streamInfo">The stream information.</param> /// <param name="isOffline">if set to <c>true</c> [is offline].</param> /// <param name="apiClient">The current apiClient. It can be null if offline</param> /// <returns>Task.</returns> public async Task ReportPlaybackProgress(PlaybackProgressInfo info, StreamInfo streamInfo, bool isOffline, IApiClient apiClient) { if (!isOffline) { if (streamInfo != null) { info.PlaySessionId = streamInfo.PlaySessionId; if (streamInfo.MediaSource != null) { info.LiveStreamId = streamInfo.MediaSource.LiveStreamId; } } await apiClient.ReportPlaybackProgressAsync(info).ConfigureAwait(false); } } /// <summary> /// Reports playback progress /// </summary> /// <param name="info">The information.</param> /// <param name="streamInfo">The stream information.</param> /// <param name="serverId">The server identifier.</param> /// <param name="userId">The user identifier.</param> /// <param name="isOffline">if set to <c>true</c> [is offline].</param> /// <param name="apiClient">The current apiClient. It can be null if offline</param> /// <returns>Task.</returns> public async Task ReportPlaybackStopped(PlaybackStopInfo info, StreamInfo streamInfo, string serverId, string userId, bool isOffline, IApiClient apiClient) { if (isOffline) { var action = new UserAction { Date = DateTime.UtcNow, ItemId = info.ItemId, PositionTicks = info.PositionTicks, ServerId = serverId, Type = UserActionType.PlayedItem, UserId = userId }; await _localAssetManager.RecordUserAction(action).ConfigureAwait(false); return; } if (streamInfo != null) { info.PlaySessionId = streamInfo.PlaySessionId; if (streamInfo.MediaSource != null) { info.LiveStreamId = streamInfo.MediaSource.LiveStreamId; } } // Put a try/catch here because we need to stop transcoding regardless try { await apiClient.ReportPlaybackStoppedAsync(info).ConfigureAwait(false); } catch (Exception ex) { _logger.ErrorException("Error in ReportPlaybackStoppedAsync", ex); } } Thanks any help would be appreciated. -vicpa
Luke 42234 Posted April 9, 2024 Posted April 9, 2024 Those calls should all include the PlaySessionId value that you got from the /PlaybackInfo call prior to playback.
