aenon83 8 Posted April 7, 2024 Posted April 7, 2024 Hello, I'm from Spain and I'm having a little trouble trying to clean my library. I have the problem with genres and tags, they are always downloaded in english and I want to translate them to spanish. For example, from Comedy to Comedia: I made a small app in c# that using the api /Genres and /Tags I can obtain all the names, and translate and updates them through the api. The problem is when I add a new movie or episode, it creates a new Genre or Tag in english again, and if I try to translate them I'm getting duplicates. Is there a posibility to add in future updates new Endpoints for merge Genres or Tags? Moving all movies and episodes from one Genre to another? If it's not posible, is it posible doing it manually calling the api? I'm thinking the next steps but I don't know which endpoints and data to use: - Get the id of the old genre (or tag) - Get the id of the new genre (or tag) - Get all movies, shows and episodes with the old genre id - Update movies, shows and episodes to the new genre id - Delete the old genre Thanks.
GrimReaper 4893 Posted April 7, 2024 Posted April 7, 2024 You can use Genre Cleaner plugin. You'll find it in the Catalogue.
aenon83 8 Posted April 7, 2024 Author Posted April 7, 2024 Thanks, I saw that plug-in, but I would still have the problem with the tags
GrimReaper 4893 Posted April 7, 2024 Posted April 7, 2024 10 minutes ago, aenon83 said: I have the problem with genres and tags, they are always downloaded in english 1 minute ago, aenon83 said: but I would still have the problem with the tags Where are those tags coming from? Emby doesn't download tags from any provider/source.
aenon83 8 Posted April 7, 2024 Author Posted April 7, 2024 Oh, I think they could be coming from TinyMediaManager, I could disable all providers in my libraries, let TinyMediaManager fetch all the data in a temp folder and translate it before adding them to Emby. Thanks. 1
Rubiko 0 Posted June 19, 2025 Posted June 19, 2025 (edited) Can be done using the API: - Get all genres: GET /emby/Genres - Get all detailed genre info GET /emby/Users/{userId}/Items/{genreId} - Update translations (Name, SortName, ForcedSortName) with altered json as body POST /emby/Items/{genreId} Edited June 19, 2025 by Rubiko font size
