PurpleTrousers 0 Posted April 7, 2024 Posted April 7, 2024 Hi all, I am sure I am missing something obvious, but I can't find the answer so I was hoping I could be pointed in the right direction please. I have installed emby to my synology NAS (DS220+) version :DSM 7.2.1-69057 Update 4 I have edited the permissions of the folders I have added to emby as follows: I have added the associated folders in emby, and it appears access is working as image previews are being displayed: But I can't see any media in emby: I would appreciate anyone who can point me in the right direction please
GrimReaper 4896 Posted April 7, 2024 Posted April 7, 2024 Not a Synology user, but is "emby" System internal user? Also, your library thumb looks like a collage of screen grabs (as opposed to usual posters), might indicate some network issues as well. How to Report a Problem
Happy2Play 9811 Posted April 8, 2024 Posted April 8, 2024 This looks like the Access/Parental controls issue as you were able to add folders to the library. Do you have Access or Parental controls set on user? If no can you toggle Parental controls to any "Maximum allowed parental rating" and hit save, then remove it and hit save. Does the library now show on Home Screen?
