TheChief 3 Posted April 7, 2024 Posted April 7, 2024 Good morning, I'm relatively new to Emby. I am encountering the problem that I cannot find/download subtitles for a certain series via the Emby app on my Google TV or via the Emby app on my Android tablet/phone, but it works fine via the web version of Emby. My setup: -Qnap with Emby Server 4.8.3.0 installed in container station -Emby premium account -OpenSubtitles setup correctly in both the Open Subtitles settings and in the library settings from the series and movies. -Open Subtitles VIP member -Automatic download with Sonarr/Radarr/SabNzbd As mentioned, the subtitles work well when I go to the web version of Emby (http://*****:8096/web/index.html#!/home), but the subtitles do not work via the apps. What am I missing? TheChief
TheChief 3 Posted April 7, 2024 Author Posted April 7, 2024 The logfile from the embyserver embyserver.txt
Neminem 1621 Posted April 7, 2024 Posted April 7, 2024 If you are using radarr/sonarr consider using Bazarr for your subtitle need. Bazarr is an companion app, that ties into radarr and sonarr. 1
Solution Neminem 1621 Posted April 7, 2024 Solution Posted April 7, 2024 (edited) Looking at your logs, I see this Unauthorized 2024-04-07 08:26:48.406 Error SubtitleManager: Error searching for subtitles on Open Subtitles *** Error Report *** Version: 4.8.3.0 Command line: /app/emby/system/EmbyServer.dll -programdata /config -ffdetect /app/emby/bin/ffdetect -ffmpeg /app/emby/bin/ffmpeg -ffprobe /app/emby/bin/ffprobe -restartexitcode 3 Operating system: Linux version 5.10.60-qnap (root@U16BuildServer174) (x86_64-QNAP-linux-gnu-gcc (toolchain config: [gcc-4.9.2 binutils-2.25 glibc-2.21]) 4.9.2, GNU ld Framework: .NET 6.0.25 OS/Process: x64/x64 Runtime: app/emby/system/System.Private.CoreLib.dll Processor count: 2 Data path: /config Application path: /app/emby/system MediaBrowser.Model.Net.HttpException: MediaBrowser.Model.Net.HttpException: Unauthorized at Emby.Server.Implementations.HttpClientManager.CoreHttpClientManager.SendAsyncInternal(HttpRequestOptions options, String httpMethod) at Emby.Server.Implementations.HttpClientManager.CoreHttpClientManager.SendAsync(HttpRequestOptions options, String httpMethod) at OpenSubtitles.OpenSubtitleComDownloader.Login(OpenSubtitleOptions options, CancellationToken cancellationToken) at OpenSubtitles.OpenSubtitleComDownloader.SearchInternal(SubtitleSearchRequest request, Boolean useFilename, OpenSubtitleOptions options, CancellationToken cancellationToken) at OpenSubtitles.OpenSubtitleComDownloader.Search(SubtitleSearchRequest request, OpenSubtitleOptions options, CancellationToken cancellationToken) at Emby.Providers.Subtitles.SubtitleManager.SearchSubtitles(SubtitleSearchRequest request, CancellationToken cancellationToken) Source: Emby.Server.Implementations TargetSite: Void MoveNext() Are you using .org or .com login ? Edited April 7, 2024 by jaycedk 1
TheChief 3 Posted April 7, 2024 Author Posted April 7, 2024 @jaycedk That was the problem! Until a few weeks ago I used Kodi and, as mentioned, I am unfamiliar with Emby. I have now set it up correctly with the login from opensubtitles.com instead of .org and now it downloads the subs correctly! Thank you very much! @jaycedk 1
