tiff1002 7 Posted April 6, 2024 Posted April 6, 2024 I have a fairly complex setup with live tv (i import a tuner as well as m3u of hulu live tv provided by channels dvr as well as other custom m3u with things like security cams and all the m3us are made via iptvboss). I have refresh guide data running regularly as well as my m3us and xml epg files regularly (the tuner uses emby guide data). Now earlier today it was not working guide data wise at all and I have since fixed it, but on my TV for example it still said no guide data until I quit and reloaded the app. Is there a way to get the client to reload the guide data from the server without reloading the whole app? This is no big deal if there is no way I was just hoping there was. In this particular example the app I had to reload was the emby app on an onn box (the 20 dollar android tv box from walmart) Thanks in advance 1
feerlessleadr 173 Posted April 7, 2024 Posted April 7, 2024 I too am interested in this since this happens sometimes for my father where the guide data doesn't update. He's older and struggles with remembering how to force close the app and re-open (and forget about my mother even trying), so this would be awesome if possible.
tiff1002 7 Posted April 7, 2024 Author Posted April 7, 2024 Exactly and some devices quitting and restarting isn't exactly a great solution
BillOatman 597 Posted April 8, 2024 Posted April 8, 2024 (edited) @tiff1002 You can have a look at this. It might help. Edited April 8, 2024 by BillOatman
tiff1002 7 Posted April 8, 2024 Author Posted April 8, 2024 That's a cool tool but does that force clients to refresh because I already have the server refreshing enough. I need a client side refresh.
BillOatman 597 Posted April 9, 2024 Posted April 9, 2024 12 hours ago, tiff1002 said: That's a cool tool but does that force clients to refresh because I already have the server refreshing enough. I need a client side refresh. The clients should get the guide data from the server I believe, So server updates, client updates. Not true for the logos (icons), but for the guide data itself I believe it does.
tiff1002 7 Posted April 9, 2024 Author Posted April 9, 2024 Not my experience. I have had a client show no guide data and quit reopen and it is there
Luke 42241 Posted April 9, 2024 Posted April 9, 2024 Quote This is no big deal if there is no way I was just hoping there was. In this particular example the app I had to reload was the emby app on an onn box (the 20 dollar android tv box from walmart) Hi. Can you try sideloading our standard android app on the same device and see how that compares? https://emby.media/emby-for-android.html Thanks.
tiff1002 7 Posted April 14, 2024 Author Posted April 14, 2024 so that is different from the one on the app store (android tv play store) and potentially better?
Luke 42241 Posted April 16, 2024 Posted April 16, 2024 On 4/13/2024 at 11:26 PM, tiff1002 said: so that is different from the one on the app store (android tv play store) and potentially better? Hi, yes it is.
tiff1002 7 Posted April 16, 2024 Author Posted April 16, 2024 Should I use that on my pixel 7 pro too? Better version of the Windows app exist somewhere too?
Luke 42241 Posted April 16, 2024 Posted April 16, 2024 10 minutes ago, tiff1002 said: Should I use that on my pixel 7 pro too? Better version of the Windows app exist somewhere too? That's the same app as what you have on the pixel 7. It's also compatible with TV devices, it's just not enabled in the store yet for them.
tiff1002 7 Posted April 16, 2024 Author Posted April 16, 2024 Oh cool good to know. It does work best on my android phone. 1
