gillmacca01 220 Posted April 6, 2024 Posted April 6, 2024 (edited) Before I investigate further, are there any users who are using UK Sky guide data from Emby, all of a sudden missing channels in the guide data list, after doing a tv guide refresh Edited April 6, 2024 by gillmacca01
PeteD 3 Posted April 6, 2024 Posted April 6, 2024 I'm grabbing both UK Freeview & Freesat guide data from Emby and both are missing channels today such as ITV1 HD, ITV3+1, ITV4, ITV4+1, E4 Extra, Channel 5+1, etc.
gillmacca01 220 Posted April 6, 2024 Author Posted April 6, 2024 Thanks for the confirmation that it's not something my end. @Lukeor whoever has contact with Gracenote, could you raise this with them please
AaronClarke 3 Posted April 6, 2024 Posted April 6, 2024 I have also noticed this today.... I typically use Freeview (Northwest) (GBR-1000040-DEFAULT) and have found that I a missing a number of channels. I have managed to replace some of them using GBR-1000039-DEFAULT (Freesat (Northwest)) instead but that also appears to be missing some channels.
mrbenjaminryder 4 Posted April 6, 2024 Posted April 6, 2024 Yep! Just noticed and was about to start re-mapping the channels again (sigh)
ebr 16331 Posted April 7, 2024 Posted April 7, 2024 Hi. Unfortunately, the provider has been doing stuff like this lately - where the change the makeup of a lineup so you have also change your lineup. We asked them to make the process more obvious (that it happened) and easier to recover from but they weren't very responsive.
gillmacca01 220 Posted April 7, 2024 Author Posted April 7, 2024 I understand they keep making changes (annoying as it is), but changing lineups do not help in this instance I tried another postcode for sky, and it had exactly the same channels missing, and these channels never changes names or channel numbers, so why they would change these, God knows. I know it sounds like I'm complaining to you, but know you have no control over this Hopefully they get things sorted and stop messing about with lineups, when there is no need to change things, otherwise I will have to consider going back to using the IPTV listings and lose programme images - series/episode numbers
Solution gillmacca01 220 Posted April 7, 2024 Author Solution Posted April 7, 2024 Just ran a guide refresh, and it's looks like they have fixed the issue. Channels that lost listings are now re-populating within having to remap these channels 1
PeteD 3 Posted April 7, 2024 Posted April 7, 2024 Just done a refresh myself and all back as you said 1
