Neminem 1623 Posted June 2, 2024 Posted June 2, 2024 Not sure of ops server os. Windows does mount webdav. Here is a how to How to Map a WebDAV Drive in Windows - Make Tech Easier
svyaznoy362 17 Posted June 3, 2024 Author Posted June 3, 2024 On 6/2/2024 at 6:34 AM, Luke said: Hi, but doesn't webdav mount to a local share? What is mounted via RCLONE does not always work well. I decided to buy an apple TV and it has an infuse cataloger and Google drive, WebDAV, it’s all there, why don’t you want to implement it in emby?
SergeiAK 5 Posted July 19, 2024 Posted July 19, 2024 On 4/5/2024 at 4:06 PM, svyaznoy362 said: #2 This problem has been around for many years, but no one has fixed it. When you log into any library and click settings, you are thrown out of the application. The problem is on the Emby for Android TV client. Please fix Emby for Android TV SETING_ATV.rar 36.89 kB · 0 downloads I confirm that there is such a problem and it is very annoying.
Luke 42243 Posted July 20, 2024 Posted July 20, 2024 8 hours ago, SergeiAK said: I confirm that there is such a problem and it is very annoying. @SergeiAK Hi. Can you try searching for our standard android app (Just "Emby" on Amazon and "Emby for Android on Google) on the same device's app store and see how that compares? Thanks.
svyaznoy362 17 Posted July 20, 2024 Author Posted July 20, 2024 1 hour ago, Luke said: @СергейАК Привет. Можете ли вы попробовать поискать наше стандартное приложение для Android (просто «Emby» на Amazon и «Emby для Android в Google) в магазине приложений того же устройства и сравнить результаты? Спасибо. @Люк Why can't you fix this problem. You asked to send me the logs, I sent them to you.
Happy2Play 9812 Posted July 20, 2024 Posted July 20, 2024 (edited) 16 minutes ago, svyaznoy362 said: @Hatch Why can't you fix this problem. You asked to send me the logs, I sent them to you. 8 hours ago, GrimReaper said: AndroidTV app is on it's sunset (is generally receiving only maintenance updates) and Universal Android app is bound to supersede it eventually That is why asked to use universal app. Edited July 20, 2024 by Happy2Play
svyaznoy362 17 Posted July 20, 2024 Author Posted July 20, 2024 7 minutes ago, Happy2Play said: Вот почему добавлено универсальное приложение для использования. I like the Android TV app better and it is more convenient than just the Android app
Luke 42243 Posted July 20, 2024 Posted July 20, 2024 31 minutes ago, svyaznoy362 said: I like the Android TV app better and it is more convenient than just the Android app Hi, more convenient how?
svyaznoy362 17 Posted July 20, 2024 Author Posted July 20, 2024 8 minutes ago, Luke said: Привет, как удобнее? The application is designed for the Android TV interface, and the regular version is designed for Android aosp. You can install these 2 applications yourself and compare; on a certified box it is much more pleasant to use the Android TV version. Looks cooler!!!
svyaznoy362 17 Posted July 20, 2024 Author Posted July 20, 2024 I just don’t understand why you have to prove that an application that exists needs to fix errors in it, but they tell you to use another one that is less convenient
Solution Luke 42243 Posted July 20, 2024 Solution Posted July 20, 2024 14 hours ago, svyaznoy362 said: The application is designed for the Android TV interface, and the regular version is designed for Android aosp. You can install these 2 applications yourself and compare; on a certified box it is much more pleasant to use the Android TV version. Looks cooler!!! Hi, the standard app is designed for TV as well. What do you feel is less convenient? Please help us improve it by providing your feedback. Thanks.
svyaznoy362 17 Posted July 22, 2024 Author Posted July 22, 2024 On 20.07.2024 at 21:56, Luke said: Привет, стандартное приложение также предназначено для ТВ. Что, по-вашему, менее удобно? Пожалуйста, помогите нам улучшить его, предоставив свой отзыв. Спасибо. Hello. Here are my comparisons of Android and Android TV versions: 1) When you press search, a keyboard appears, which must be constantly removed, since I prefer voice search, voice search immediately starts on Android TV. 2) To exit the application in the Android version you need to press the remote control 3 times, in Android TV 2 3) In the Android version the item is not translated into Russian: Continue viewing, but it is written From Beginning 4) In the Android version there are few zoom modes 4) In Android TV By holding the ok button for a long time, I get detailed information about the film, in the Android version you have to go into the menu to enter the information and it is not so complete. 5) On the Android version, moving through the menu seems to be a little delayed, not as smooth as on Android TV
Luke 42243 Posted July 24, 2024 Posted July 24, 2024 Quote 3) In the Android version the item is not translated into Russian: Continue viewing, but it is written From Beginning Hi, the text has not yet been translated on OneSky. As soon as that happens, the app will get the updated translation. Quote 2) To exit the application in the Android version you need to press the remote control 3 times There is also the home button on the remote. Or if you press and hold back, that will take you back to the app home screen. From there just press back one more time to exit.
svyaznoy362 17 Posted August 4, 2024 Author Posted August 4, 2024 On 05.04.2024 at 16:07, svyaznoy362 said: #3 Я вам давно писал про внешний плеер. Я использую emby как каталогизатор и он мне очень нравится, но мне не хватает возможности выбирать, каким видеоплеером его воспроизводить. На фото я показал как это реализовано в каталогизаторе jelly fun и в iptv Tivimate. Я использую разные потоки и не все могут или хотят воспроизводить exo player и тогда я могу воспроизвести этот поток внешним плеером, но как это сделано у вас сейчас очень плохо, так как мне постоянно нужно лезть в настройки и менять тип плеера. Пожалуйста, добавьте уже эту функцию. @Люк hi. When you add an external player to the main screen. If you add , then maybe you can switch to the Android application.
beerland 0 Posted August 4, 2024 Posted August 4, 2024 (edited) On 7/20/2024 at 8:56 PM, Luke said: Hi, the standard app is designed for TV as well. What do you feel is less convenient? Please help us improve it by providing your feedback. Thanks. Main reason I cant use that version is because of the "Allow TrueHD pass-thru" setting that's missing. I get a weird audio..Stutter? in some movies. When I uncheck that setting on the android TV version everything works fine. Edited August 4, 2024 by beerland
Luke 42243 Posted August 4, 2024 Posted August 4, 2024 4 hours ago, beerland said: Main reason I cant use that version is because of the "Allow TrueHD pass-thru" setting that's missing. I get a weird audio..Stutter? in some movies. When I uncheck that setting on the android TV version everything works fine. Does your audio setup not handle truehd well?
beerland 0 Posted August 9, 2024 Posted August 9, 2024 (edited) On 8/5/2024 at 12:29 AM, Luke said: Does your audio setup not handle truehd well? For some reason it doesn't. For most movies I probably could use the alternate track but some only have truehd so that setting solved the issue. With some truehd tracks there are like pops in audio and I see the dolby vision enabled popping up again when it happens but when "Allow Truehd Pass-thru" is checked off it all plays fine. Had the same issue with Plex and could never find a fix until I started using Emby that allowed me to uncheck that setting, which allowed me to direct play it without audio issues. Edited August 9, 2024 by beerland
Luke 42243 Posted August 24, 2024 Posted August 24, 2024 OK yes we can look at getting this option added. Thanks.
