svyaznoy362 17 Posted April 5, 2024 Posted April 5, 2024 @Luke Hello. There is an emby premium subscription and I would like to ask you to fix the current problems and add a new one.
svyaznoy362 17 Posted April 5, 2024 Author Posted April 5, 2024 #1 I use Nvidia shield and the Emby for Android TV Beta client: v2.1.11g and on many videos in the mkv container I constantly catch the transcode, although this should not be, I installed Emby for Android Beta: v3.3.79 for the test and all my videos play there directly without the transcode and, accordingly, nothing it doesn't hang. Please fix Emby for Android TV. ATV_log.zip mobile version_log.rar
svyaznoy362 17 Posted April 5, 2024 Author Posted April 5, 2024 #2 This problem has been around for many years, but no one has fixed it. When you log into any library and click settings, you are thrown out of the application. The problem is on the Emby for Android TV client. Please fix Emby for Android TV SETING_ATV.rar
svyaznoy362 17 Posted April 5, 2024 Author Posted April 5, 2024 #3 I've been writing to you about the external player for a long time. I use emby as a cataloger and I really like it, but I lack the ability to choose which video player to play it with. In the photo, I showed how this is implemented in the jelly fun cataloger and in the iptv Tivimate. I use different streams and not everyone can or wants to play exo player and then I can play this stream with an external player, but how it is done with you now is very bad, since I constantly need to go into the settings and change the type of player. Please add this feature already.
adminExitium 356 Posted April 5, 2024 Posted April 5, 2024 This is the Feature Request sub-forum. Support requests need to be posted here for AndroidTV: https://emby.media/community/index.php?/forum/147-android-tv-fire-tv/ 3
svyaznoy362 17 Posted April 5, 2024 Author Posted April 5, 2024 (edited) #4 When adding a storm that uses the .mpd stream, exo player refuses to play on any version of the client. If you select an external player on Emby for Android TV, then I also get an error, if you select in Emby for Android Beta: v3.3.79, then the VLc player plays this stream. Please fix Emby for Android TV strm_ATV.zip strm_мобильная версия.zip Edited April 5, 2024 by svyaznoy362 1
Luke 42243 Posted April 5, 2024 Posted April 5, 2024 HI, are you happy continuing to use the Emby standard app?
svyaznoy362 17 Posted April 8, 2024 Author Posted April 8, 2024 On 05.04.2024 at 21:49, Luke said: Привет, вы довольны тем, что продолжаете использовать стандартное приложение Emby? Hello, application v3.3.79 can’t scale, the settings menu is inconvenient, I’m waiting for you to fix the ATV version, I like it better in appearance.
Luke 42243 Posted April 8, 2024 Posted April 8, 2024 13 hours ago, svyaznoy362 said: Hello, application v3.3.79 can’t scale, the settings menu is inconvenient, I’m waiting for you to fix the ATV version, I like it better in appearance. Hi, what exactly can't scale? What exactly is inconvenient?
svyaznoy362 17 Posted May 27, 2024 Author Posted May 27, 2024 Hello guys, when will you install cloud services such as Google drive, OneDrive and so on and WebDAV, the Chinese are already stealing your developments and are already overtaking you on corners, guys, we believe in you that you are also capable of more https://apps.apple.com/us/app/yybx/id1519723194
Luke 42243 Posted May 28, 2024 Posted May 28, 2024 15 hours ago, svyaznoy362 said: Hello guys, when will you install cloud services such as Google drive, OneDrive and so on and WebDAV, the Chinese are already stealing your developments and are already overtaking you on corners, guys, we believe in you that you are also capable of more https://apps.apple.com/us/app/yybx/id1519723194 Why would you use something like that?
svyaznoy362 17 Posted May 28, 2024 Author Posted May 28, 2024 3 minutes ago, Luke said: Why would you use something like that? Hello. I have a huge library of films on Google drive. I've been waiting for a long time for you to implement the ability to add libraries from cloud services or WebDAV.
Luke 42243 Posted May 28, 2024 Posted May 28, 2024 1 minute ago, svyaznoy362 said: Hello. I have a huge library of films on Google drive. I've been waiting for a long time for you to implement the ability to add libraries from cloud services or WebDAV. Can't you just mount webdav as a local drive on your server machine?
svyaznoy362 17 Posted May 28, 2024 Author Posted May 28, 2024 6 minutes ago, Luke said: Can't you just mount webdav as a local drive on your server machine? So the emby server does not see my webdav
Luke 42243 Posted May 28, 2024 Posted May 28, 2024 10 hours ago, svyaznoy362 said: So the emby server does not see my webdav Hi, that's not a folder path that you entered. That is only an ip address. please try typing in a full folder path and then it should work.
svyaznoy362 17 Posted May 28, 2024 Author Posted May 28, 2024 21 minutes ago, Luke said: Привет, это не тот путь к папке, который вы ввели. Это всего лишь IP-адрес. попробуйте ввести полный путь к папке, и тогда все должно работать. So WebDAV is on another device and I can only get the library via smb, but I need webdav
svyaznoy362 17 Posted May 28, 2024 Author Posted May 28, 2024 7 minutes ago, Luke said: What is the smb path to the webdav mount? \\192.168.1.9
Luke 42243 Posted May 29, 2024 Posted May 29, 2024 Please Try typing in a subfolder under that because that's not actually a folder path.
svyaznoy362 17 Posted May 29, 2024 Author Posted May 29, 2024 (edited) 1 hour ago, Luke said: Please Try typing in a subfolder under that because that's not actually a folder path. I use Rclone on another device ( android), webdav is built into it, the root of the cloud disk is mounted, I calmly connect to the address http://192.168.1.9:18037 on a computer, mobile phone. The emby server is on ubuntu and synology, when I try to add a Webdav server, the emby server just doesn't see it. Emby simply does not know how to connect via http, I would like to ask you to implement this feature. Thank you. sleep 3 && /opt/bin/rclone serve webdav --addr :18037 /storage/emulated/0/DuneHD/Disk362 --rc --rc-addr 127.0.0.1:1614 -L & Edited May 29, 2024 by svyaznoy362
Luke 42243 Posted May 29, 2024 Posted May 29, 2024 13 hours ago, Luke said: Please Try typing in a subfolder under that because that's not actually a folder path. Hi, did you try this? What did you try?
svyaznoy362 17 Posted May 29, 2024 Author Posted May 29, 2024 20 minutes ago, Luke said: Hi, did you try this? What did you try? I selected the Film folder, but the emby server does not see the library.
Luke 42243 Posted May 29, 2024 Posted May 29, 2024 Hi, that is an http url. Try typing in the full smb folder location. Please see if that helps.
svyaznoy362 17 Posted May 30, 2024 Author Posted May 30, 2024 6 hours ago, Luke said: Hi, that is an http url. Try typing in the full smb folder location. Please see if that helps. Так по smb видна библиотека, меня интересует WebDAV, я по по smb могу видеть только то что в локальной сети , а WebDAV даёт возможность подключаться к любой библиотеке.
