hetkoznap 2 Posted April 4, 2024 Posted April 4, 2024 Is there a way to import guide data to Emby from a HDHomerun Connect? My problem is that as far as I know there is no guide.xml (generated by my HDHomerun Connect) I can add to Emby. I used a Vbox TV Gateway before and it generated a guide.xml i could add to Emby but I see no option like this in the HDHomerun's web interface. Using the Channels iOS app I can see the EPG so there is guide data in my cable provider's stream. I know SiliconDust offers a DVR subscription with guide data but it's not available in my county and I also don't need 14 days of EPG, the 3-4 hours of EPG they offer for free is more than enough for me if I can add it to Emby.
Sammy 791 Posted April 4, 2024 Posted April 4, 2024 https://emby.media/support/articles/Emby-Guide-Data.html
hetkoznap 2 Posted April 4, 2024 Author Posted April 4, 2024 5 minutes ago, Sammy said: https://emby.media/support/articles/Emby-Guide-Data.html Thanks but Emby Guide Data is not available where I live.
Sammy 791 Posted April 4, 2024 Posted April 4, 2024 https://www.thegreenbutton.tv/forums/viewforum.php?f=99&sid=bc0eb46daa0a0d776d7b4d93205e5bcc Maybe?
BillOatman 597 Posted April 10, 2024 Posted April 10, 2024 On 4/4/2024 at 3:07 PM, hetkoznap said: Is there a way to import guide data to Emby from a HDHomerun Connect? My problem is that as far as I know there is no guide.xml (generated by my HDHomerun Connect) I can add to Emby. I used a Vbox TV Gateway before and it generated a guide.xml i could add to Emby but I see no option like this in the HDHomerun's web interface. Using the Channels iOS app I can see the EPG so there is guide data in my cable provider's stream. I know SiliconDust offers a DVR subscription with guide data but it's not available in my county and I also don't need 14 days of EPG, the 3-4 hours of EPG they offer for free is more than enough for me if I can add it to Emby. Or https://iptvboss.pro/ 2
