metropical 38 Posted April 3, 2024 Posted April 3, 2024 random stalls in music playback. M4A or mp3. Though it does seem more often with M4A. In shuffle play, I'll see a spinning blue circle. if I select the next cut that has apparently stalled playback, it immediately plays back. server has 2 new WD5400 2 TB drives. the server app is on an '18 mini on Monterey and the drives in a cMP3,1 running High Sierra. The computers are connected with a 5p TPlink unmanaged switch. Server 4.8.3.0 Thanks embyserver log.txt ffmpeg-transcode-99598b63-8442-455c-8cbd-016dada97c11_1.txt
metropical 38 Posted April 3, 2024 Author Posted April 3, 2024 I know it's in the emby log, but Firefox 124.0.1 is the.browser.
Luke 42237 Posted April 9, 2024 Posted April 9, 2024 Hi, can you try Chrome to see how things compare?
metropical 38 Posted April 9, 2024 Author Posted April 9, 2024 honestly, I'd rather not. It's a memory hog in MacOS and is not very secure. So much so that one place I work restricts it from use. But I'll try it and I guess perhaps Safari, which has it's issues as well.
metropical 38 Posted April 9, 2024 Author Posted April 9, 2024 (edited) tried Safari and Brave (which is a derivative of Chrome. Both failed. Chrome hasn't had a problem in around 3 hrs. What is the issue? Since any browser supports mp3 and m4a playback. and just as I wrote that, Chrome got stuck. argh! Edited April 9, 2024 by metropical
metropical 38 Posted April 10, 2024 Author Posted April 10, 2024 (edited) I think these are the right logs for the Chrome experience yesterday. embyserver-63848304001.txt ffmpeg-transcode-d29cd84b-2471-4c98-88b7-6e3231fb7a3b_1.txt Edited April 10, 2024 by metropical
Luke 42237 Posted April 16, 2024 Posted April 16, 2024 Quote Since any browser supports mp3 and m4a playback. Your log is alac though, in an m4a container. Yes the browsers support m4a as a container, but in order to direct play they also need to support the codec within the container.
Luke 42237 Posted April 16, 2024 Posted April 16, 2024 So is it only a problem when transcoding is occuring?
metropical 38 Posted April 16, 2024 Author Posted April 16, 2024 (edited) how would I know if it's transcoding only? sometimes it happens mid song, but mostly it happens transitioning to the next song. does that point to transcoding? is the an extension that can be added to Firefox or is it more that the files need to be true m4a not alac contained as m4a? in the future, should I be converting flac to Mpeg 4 AAC instead of alac? Edited April 16, 2024 by metropical
metropical 38 Posted April 16, 2024 Author Posted April 16, 2024 or somehow point FFx to FFmpeg to transcode?
metropical 38 Posted April 16, 2024 Author Posted April 16, 2024 since ALAC isn't supported by FFx, when I click the track that Emby stalls on, what makes it then play?
Luke 42237 Posted April 24, 2024 Posted April 24, 2024 On 4/16/2024 at 12:45 PM, metropical said: since ALAC isn't supported by FFx, when I click the track that Emby stalls on, what makes it then play? IT is converting the audio. I'm guessing this is only happening when transcoding is taking place, right? You can check that by having the server dashboard open while playing.
metropical 38 Posted May 16, 2024 Author Posted May 16, 2024 yes, transcoding is the issue. I guess it is what it is unless the music is flac or mp3?
Luke 42237 Posted May 28, 2024 Posted May 28, 2024 On 5/16/2024 at 11:18 AM, metropical said: yes, transcoding is the issue. I guess it is what it is unless the music is flac or mp3? Hi, are you still having an issue with this?
Luke 42237 Posted June 2, 2024 Posted June 2, 2024 Hi, have you updated to Emby Server 4.8.8? Has that helped?
metropical 38 Posted June 2, 2024 Author Posted June 2, 2024 didn't realize there was an update. Just installed. I'll let you know in a day or 2. Thanks, Luke. 1
metropical 38 Posted July 3, 2024 Author Posted July 3, 2024 is there something I should change in settings or whatever?
metropical 38 Posted July 28, 2024 Author Posted July 28, 2024 watching in real time, I see Emby web server app spinning. When I click the track that stalls it, for the most part, Emby immediately plays the track. 1
metropical 38 Posted July 29, 2024 Author Posted July 29, 2024 so I gather this is a function of the web interface, whether Chrome, Firefox, Safari, running out of cache or the like?
Solution Luke 42237 Posted October 22, 2024 Solution Posted October 22, 2024 Hi, have you updated to Emby Server 4.8.10? Has that helped?
