Stuza 2 Posted April 3, 2024 Posted April 3, 2024 Hi All, as title says, the Android Emby client for me will not keep the external 2nd screen alive, even if I set the Android screen time out to 30 minutes! This is really frustrating as I really like the idea of using Emby client to keep everything in sync whilst at work watching movies and updating when I get home to my wifi and server. Phone Motorola Edge Pro (2023) Android version 14 Emby client version (according to Android App Info is 3.3.7.7) There are no logs in the Android/Data directory The media is all downloaded via the Emby download options I'm obviously not 100% sure this is an Emby issue however, VLC works fine when plugged in to my external USB-C screen and keeps the screen alive. Any thoughts? Maybe a setting I've missed in Android or Emby? Thanks!
Luke 42242 Posted May 17, 2024 Posted May 17, 2024 @StuzaHi, has this been resolved in the latest update to Emby for Android? If not, then please temporarily enable app logging, force close the app to restart it, then reproduce the issue, and then attach the app log here? Make sure to disable app logging when you're done. Thanks !
