Guest Posted April 3, 2024 Posted April 3, 2024 (edited) hi, I have a problem with 4K on the fire stick 4k max, it turns out that it transcodes me because it appears in records, but on the panel it shows me that everything is in direct play. Do you know what the reason is? In principle, the Fire Stick is 100% compatible with the file. thank you ffmpeg-transcode-8a243dfc-c56f-4702-aa7b-f9bd2bb13472_1.txt Edited April 3, 2024 by iPley_1 ffmpeg
ebr 16337 Posted April 3, 2024 Posted April 3, 2024 Hi. It is transcoding because the video is 98Mps but your setting in the app is 20. You can try increasing the setting in the app to see if it will direct play.
Luke 42244 Posted April 3, 2024 Posted April 3, 2024 @iPley_1please let us know if this helps. Thanks.
Guest Posted April 4, 2024 Posted April 4, 2024 In the server control panel and in statistics for nerds it appeared that it was playing in original, but I noticed that this was not true due to the high CPU consumption. That is why I don't know if the panel showed something incorrect or what the cause was.
Luke 42244 Posted April 5, 2024 Posted April 5, 2024 23 hours ago, Guest said: In the server control panel and in statistics for nerds it appeared that it was playing in original, but I noticed that this was not true due to the high CPU consumption. That is why I don't know if the panel showed something incorrect or what the cause was. Hi, but that cpu consumption could have come from anything, right? Please attach the emby server log from when this happened: How to Report a Problem Thanks.
