Bill LeDuc 5 Posted April 2, 2024 Posted April 2, 2024 On three occasions Emby live TV recordings have had a strange delay in post processing. I use post processing to change the container from ts to to the mkv using ffmpeg (my copy).. After the recording has completed I find two images for the recording. One is representing the ts file. This will not play I presume because is probably busy with post processing. The second image I am not sure what it represents and it will not play or even open. I have waited hours and nothing changes and yet by the next day I find the conversion complete and everything seems normal. I am using version 4.8.3. I have only seen this since 4.8.2 was available.
Luke 42184 Posted April 2, 2024 Posted April 2, 2024 Hi there, can you please provide a specific example? How to Report a Problem Thanks.
Bill LeDuc 5 Posted April 3, 2024 Author Posted April 3, 2024 The issue happened while recording iHeartRadio award shembyserver-63847612799-iHeartRadio.txtow from 7:00pm to 9:00pm. Attached is the relevant log file for that period.
Bill LeDuc 5 Posted April 3, 2024 Author Posted April 3, 2024 I forgot to say that the recording was done on 4/1/24. Also I attached the post processing script. The post processing has been functioning correctly for 2yrs. MyEmbyPP1.bat embyserver-63847612799-iHeartRadio.txt
Luke 42184 Posted April 3, 2024 Posted April 3, 2024 The recording stopped and within a fraction of a second your post processing script was executed: 2024-04-01 20:59:59.999 Info LiveTV: Recording stopped: D:\Emby Recordings\The 2024 iHeartRadio Music Awards (2024)\The 2024 iHeartRadio Music Awards 2024_04_01_19_00_00.ts 2024-04-01 20:59:59.999 Info MediaSourceManager: Live stream native_dc8fbd69e0dcaf4b4f967488cd69747d_71b5a3799d29c6768eae607ca528d6ce consumer count is now 0 2024-04-01 20:59:59.999 Info MediaSourceManager: Closing live stream 06044cf0e6f93cdae5f285c9ecfaaeb4_01413a525b3a9622ce6fdf19f7dde354_native_dc8fbd69e0dcaf4b4f967488cd69747d_71b5a3799d29c6768eae607ca528d6ce 2024-04-01 20:59:59.999 Info SharedHttpPipelineSource: Closing SharedHttpPipelineSource 2024-04-01 20:59:59.999 Info SharedHttpPipelineSource: Deleting temp files C:\Users\willi\AppData\Roaming\Emby-Server\programdata\transcoding-temp\d8abace370934fc0a1e4ba5c6cbabddb\0000000.ts, C:\Users\willi\AppData\Roaming\Emby-Server\programdata\transcoding-temp\d8abace370934fc0a1e4ba5c6cbabddb\0000001.ts, C:\Users\willi\AppData\Roaming\Emby-Server\programdata\transcoding-temp\d8abace370934fc0a1e4ba5c6cbabddb\0000002.ts, C:\Users\willi\AppData\Roaming\Emby-Server\programdata\transcoding-temp\d8abace370934fc0a1e4ba5c6cbabddb\0000003.ts, C:\Users\willi\AppData\Roaming\Emby-Server\programdata\transcoding-temp\d8abace370934fc0a1e4ba5c6cbabddb\0000004.ts, C:\Users\willi\AppData\Roaming\Emby-Server\programdata\transcoding-temp\d8abace370934fc0a1e4ba5c6cbabddb\0000005.ts, C:\Users\willi\AppData\Roaming\Emby-Server\programdata\transcoding-temp\d8abace370934fc0a1e4ba5c6cbabddb\0000006.ts, C:\Users\willi\AppData\Roaming\Emby-Server\programdata\transcoding-temp\d8abace370934fc0a1e4ba5c6cbabddb\0000007.ts, C:\Users\willi\AppData\Roaming\Emby-Server\programdata\transcoding-temp\d8abace370934fc0a1e4ba5c6cbabddb\0000008.ts, C:\Users\willi\AppData\Roaming\Emby-Server\programdata\transcoding-temp\d8abace370934fc0a1e4ba5c6cbabddb\0000009.ts, C:\Users\willi\AppData\Roaming\Emby-Server\programdata\transcoding-temp\d8abace370934fc0a1e4ba5c6cbabddb\0000010.ts, C:\Users\willi\AppData\Roaming\Emby-Server\programdata\transcoding-temp\d8abace370934fc0a1e4ba5c6cbabddb\0000011.ts, C:\Users\willi\AppData\Roaming\Emby-Server\programdata\transcoding-temp\d8abace370934fc0a1e4ba5c6cbabddb\0000012.ts, C:\Users\willi\AppData\Roaming\Emby-Server\programdata\transcoding-temp\d8abace370934fc0a1e4ba5c6cbabddb\0000013.ts, C:\Users\willi\AppData\Roaming\Emby-Server\programdata\transcoding-temp\d8abace370934fc0a1e4ba5c6cbabddb\0000014.ts, C:\Users\willi\AppData\Roaming\Emby-Server\programdata\transcoding-temp\d8abace370934fc0a1e4ba5c6cbabddb\0000015.ts, C:\Users\willi\AppData\Roaming\Emby-Server\programdata\transcoding-temp\d8abace370934fc0a1e4ba5c6cbabddb\0000016.ts, C:\Users\willi\AppData\Roaming\Emby-Server\programdata\transcoding-temp\d8abace370934fc0a1e4ba5c6cbabddb\0000017.ts, C:\Users\willi\AppData\Roaming\Emby-Server\programdata\transcoding-temp\d8abace370934fc0a1e4ba5c6cbabddb\0000018.ts, C:\Users\willi\AppData\Roaming\Emby-Server\programdata\transcoding-temp\d8abace370934fc0a1e4ba5c6cbabddb\0000019.ts, C:\Users\willi\AppData\Roaming\Emby-Server\programdata\transcoding-temp\d8abace370934fc0a1e4ba5c6cbabddb\0000020.ts, C:\Users\willi\AppData\Roaming\Emby-Server\programdata\transcoding-temp\d8abace370934fc0a1e4ba5c6cbabddb\0000021.ts, C:\Users\willi\AppData\Roaming\Emby-Server\programdata\transcoding-temp\d8abace370934fc0a1e4ba5c6cbabddb\0000022.ts, C:\Users\willi\AppData\Roaming\Emby-Server\programdata\transcoding-temp\d8abace370934fc0a1e4ba5c6cbabddb\0000023.ts, C:\Users\willi\AppData\Roaming\Emby-Server\programdata\transcoding-temp\d8abace370934fc0a1e4ba5c6cbabddb\0000024.ts, C:\Users\willi\AppData\Roaming\Emby-Server\programdata\transcoding-temp\d8abace370934fc0a1e4ba5c6cbabddb\0000025.ts, C:\Users\willi\AppData\Roaming\Emby-Server\programdata\transcoding-temp\d8abace370934fc0a1e4ba5c6cbabddb\0000026.ts, C:\Users\willi\AppData\Roaming\Emby-Server\programdata\transcoding-temp\d8abace370934fc0a1e4ba5c6cbabddb\0000027.ts, C:\Users\willi\AppData\Roaming\Emby-Server\programdata\transcoding-temp\d8abace370934fc0a1e4ba5c6cbabddb\0000028.ts, C:\Users\willi\AppData\Roaming\Emby-Server\programdata\transcoding-temp\d8abace370934fc0a1e4ba5c6cbabddb\0000029.ts, C:\Users\willi\AppData\Roaming\Emby-Server\programdata\transcoding-temp\d8abace370934fc0a1e4ba5c6cbabddb\0000030.ts, C:\Users\willi\AppData\Roaming\Emby-Server\programdata\transcoding-temp\d8abace370934fc0a1e4ba5c6cbabddb\0000031.ts, C:\Users\willi\AppData\Roaming\Emby-Server\programdata\transcoding-temp\d8abace370934fc0a1e4ba5c6cbabddb\0000032.ts, C:\Users\willi\AppData\Roaming\Emby-Server\programdata\transcoding-temp\d8abace370934fc0a1e4ba5c6cbabddb\0000033.ts, C:\Users\willi\AppData\Roaming\Emby-Server\programdata\transcoding-temp\d8abace370934fc0a1e4ba5c6cbabddb\0000034.ts, C:\Users\willi\AppData\Roaming\Emby-Server\programdata\transcoding-temp\d8abace370934fc0a1e4ba5c6cbabddb\0000035.ts, C:\Users\willi\AppData\Roaming\Emby-Server\programdata\transcoding-temp\d8abace370934fc0a1e4ba5c6cbabddb\0000036.ts, C:\Users\willi\AppData\Roaming\Emby-Server\programdata\transcoding-temp\d8abace370934fc0a1e4ba5c6cbabddb\0000037.ts, C:\Users\willi\AppData\Roaming\Emby-Server\programdata\transcoding-temp\d8abace370934fc0a1e4ba5c6cbabddb\0000038.ts, C:\Users\willi\AppData\Roaming\Emby-Server\programdata\transcoding-temp\d8abace370934fc0a1e4ba5c6cbabddb\0000039.ts, C:\Users\willi\AppData\Roaming\Emby-Server\programdata\transcoding-temp\d8abace370934fc0a1e4ba5c6cbabddb\0000040.ts, C:\Users\willi\AppData\Roaming\Emby-Server\programdata\transcoding-temp\d8abace370934fc0a1e4ba5c6cbabddb\0000041.ts, C:\Users\willi\AppData\Roaming\Emby-Server\programdata\transcoding-temp\d8abace370934fc0a1e4ba5c6cbabddb\0000042.ts, C:\Users\willi\AppData\Roaming\Emby-Server\programdata\transcoding-temp\d8abace370934fc0a1e4ba5c6cbabddb\0000043.ts, C:\Users\willi\AppData\Roaming\Emby-Server\programdata\transcoding-temp\d8abace370934fc0a1e4ba5c6cbabddb\0000044.ts, C:\Users\willi\AppData\Roaming\Emby-Server\programdata\transcoding-temp\d8abace370934fc0a1e4ba5c6cbabddb\0000045.ts, C:\Users\willi\AppData\Roaming\Emby-Server\programdata\transcoding-temp\d8abace370934fc0a1e4ba5c6cbabddb\0000046.ts, C:\Users\willi\AppData\Roaming\Emby-Server\programdata\transcoding-temp\d8abace370934fc0a1e4ba5c6cbabddb\0000047.ts, C:\Users\willi\AppData\Roaming\Emby-Server\programdata\transcoding-temp\d8abace370934fc0a1e4ba5c6cbabddb\0000048.ts, C:\Users\willi\AppData\Roaming\Emby-Server\programdata\transcoding-temp\d8abace370934fc0a1e4ba5c6cbabddb\0000049.ts, C:\Users\willi\AppData\Roaming\Emby-Server\programdata\transcoding-temp\d8abace370934fc0a1e4ba5c6cbabddb\0000050.ts, C:\Users\willi\AppData\Roaming\Emby-Server\programdata\transcoding-temp\d8abace370934fc0a1e4ba5c6cbabddb\0000051.ts, C:\Users\willi\AppData\Roaming\Emby-Server\programdata\transcoding-temp\d8abace370934fc0a1e4ba5c6cbabddb\0000052.ts, C:\Users\willi\AppData\Roaming\Emby-Server\programdata\transcoding-temp\d8abace370934fc0a1e4ba5c6cbabddb\0000053.ts, C:\Users\willi\AppData\Roaming\Emby-Server\programdata\transcoding-temp\d8abace370934fc0a1e4ba5c6cbabddb\0000054.ts, C:\Users\willi\AppData\Roaming\Emby-Server\programdata\transcoding-temp\d8abace370934fc0a1e4ba5c6cbabddb\0000055.ts, C:\Users\willi\AppData\Roaming\Emby-Server\programdata\transcoding-temp\d8abace370934fc0a1e4ba5c6cbabddb\0000056.ts, C:\Users\willi\AppData\Roaming\Emby-Server\programdata\transcoding-temp\d8abace370934fc0a1e4ba5c6cbabddb\0000057.ts, C:\Users\willi\AppData\Roaming\Emby-Server\programdata\transcoding-temp\d8abace370934fc0a1e4ba5c6cbabddb\0000058.ts, C:\Users\willi\AppData\Roaming\Emby-Server\programdata\transcoding-temp\d8abace370934fc0a1e4ba5c6cbabddb\0000059.ts, C:\Users\willi\AppData\Roaming\Emby-Server\programdata\transcoding-temp\d8abace370934fc0a1e4ba5c6cbabddb\0000060.ts, C:\Users\willi\AppData\Roaming\Emby-Server\programdata\transcoding-temp\d8abace370934fc0a1e4ba5c6cbabddb\0000061.ts, C:\Users\willi\AppData\Roaming\Emby-Server\programdata\transcoding-temp\d8abace370934fc0a1e4ba5c6cbabddb\0000062.ts, C:\Users\willi\AppData\Roaming\Emby-Server\programdata\transcoding-temp\d8abace370934fc0a1e4ba5c6cbabddb\0000063.ts, C:\Users\willi\AppData\Roaming\Emby-Server\programdata\transcoding-temp\d8abace370934fc0a1e4ba5c6cbabddb\0000064.ts, C:\Users\willi\AppData\Roaming\Emby-Server\programdata\transcoding-temp\d8abace370934fc0a1e4ba5c6cbabddb\0000065.ts, C:\Users\willi\AppData\Roaming\Emby-Server\programdata\transcoding-temp\d8abace370934fc0a1e4ba5c6cbabddb\0000066.ts, C:\Users\willi\AppData\Roaming\Emby-Server\programdata\transcoding-temp\d8abace370934fc0a1e4ba5c6cbabddb\0000067.ts, C:\Users\willi\AppData\Roaming\Emby-Server\programdata\transcoding-temp\d8abace370934fc0a1e4ba5c6cbabddb\0000068.ts, C:\Users\willi\AppData\Roaming\Emby-Server\programdata\transcoding-temp\d8abace370934fc0a1e4ba5c6cbabddb\0000069.ts, C:\Users\willi\AppData\Roaming\Emby-Server\programdata\transcoding-temp\d8abace370934fc0a1e4ba5c6cbabddb\0000070.ts, C:\Users\willi\AppData\Roaming\Emby-Server\programdata\transcoding-temp\d8abace370934fc0a1e4ba5c6cbabddb\0000071.ts, C:\Users\willi\AppData\Roaming\Emby-Server\programdata\transcoding-temp\d8abace370934fc0a1e4ba5c6cbabddb\0000072.ts, C:\Users\willi\AppData\Roaming\Emby-Server\programdata\transcoding-temp\d8abace370934fc0a1e4ba5c6cbabddb\0000073.ts, C:\Users\willi\AppData\Roaming\Emby-Server\programdata\transcoding-temp\d8abace370934fc0a1e4ba5c6cbabddb\0000074.ts, C:\Users\willi\AppData\Roaming\Emby-Server\programdata\transcoding-temp\d8abace370934fc0a1e4ba5c6cbabddb\0000075.ts, C:\Users\willi\AppData\Roaming\Emby-Server\programdata\transcoding-temp\d8abace370934fc0a1e4ba5c6cbabddb\0000076.ts, C:\Users\willi\AppData\Roaming\Emby-Server\programdata\transcoding-temp\d8abace370934fc0a1e4ba5c6cbabddb\0000077.ts, C:\Users\willi\AppData\Roaming\Emby-Server\programdata\transcoding-temp\d8abace370934fc0a1e4ba5c6cbabddb\0000078.ts, C:\Users\willi\AppData\Roaming\Emby-Server\programdata\transcoding-temp\d8abace370934fc0a1e4ba5c6cbabddb\0000079.ts, C:\Users\willi\AppData\Roaming\Emby-Server\programdata\transcoding-temp\d8abace370934fc0a1e4ba5c6cbabddb\0000080.ts, C:\Users\willi\AppData\Roaming\Emby-Server\programdata\transcoding-temp\d8abace370934fc0a1e4ba5c6cbabddb\0000081.ts, C:\Users\willi\AppData\Roaming\Emby-Server\programdata\transcoding-temp\d8abace370934fc0a1e4ba5c6cbabddb\0000082.ts, C:\Users\willi\AppData\Roaming\Emby-Server\programdata\transcoding-temp\d8abace370934fc0a1e4ba5c6cbabddb\0000083.ts, C:\Users\willi\AppData\Roaming\Emby-Server\programdata\transcoding-temp\d8abace370934fc0a1e4ba5c6cbabddb\0000084.ts, C:\Users\willi\AppData\Roaming\Emby-Server\programdata\transcoding-temp\d8abace370934fc0a1e4ba5c6cbabddb\0000085.ts, C:\Users\willi\AppData\Roaming\Emby-Server\programdata\transcoding-temp\d8abace370934fc0a1e4ba5c6cbabddb\0000086.ts, C:\Users\willi\AppData\Roaming\Emby-Server\programdata\transcoding-temp\d8abace370934fc0a1e4ba5c6cbabddb\0000087.ts, C:\Users\willi\AppData\Roaming\Emby-Server\programdata\transcoding-temp\d8abace370934fc0a1e4ba5c6cbabddb\0000088.ts, C:\Users\willi\AppData\Roaming\Emby-Server\programdata\transcoding-temp\d8abace370934fc0a1e4ba5c6cbabddb\0000089.ts, C:\Users\willi\AppData\Roaming\Emby-Server\programdata\transcoding-temp\d8abace370934fc0a1e4ba5c6cbabddb\0000090.ts, C:\Users\willi\AppData\Roaming\Emby-Server\programdata\transcoding-temp\d8abace370934fc0a1e4ba5c6cbabddb\0000091.ts, C:\Users\willi\AppData\Roaming\Emby-Server\programdata\transcoding-temp\d8abace370934fc0a1e4ba5c6cbabddb\0000092.ts, C:\Users\willi\AppData\Roaming\Emby-Server\programdata\transcoding-temp\d8abace370934fc0a1e4ba5c6cbabddb\0000093.ts, C:\Users\willi\AppData\Roaming\Emby-Server\programdata\transcoding-temp\d8abace370934fc0a1e4ba5c6cbabddb\0000094.ts, C:\Users\willi\AppData\Roaming\Emby-Server\programdata\transcoding-temp\d8abace370934fc0a1e4ba5c6cbabddb\0000095.ts, C:\Users\willi\AppData\Roaming\Emby-Server\programdata\transcoding-temp\d8abace370934fc0a1e4ba5c6cbabddb\0000096.ts, C:\Users\willi\AppData\Roaming\Emby-Server\programdata\transcoding-temp\d8abace370934fc0a1e4ba5c6cbabddb\0000097.ts, C:\Users\willi\AppData\Roaming\Emby-Server\programdata\transcoding-temp\d8abace370934fc0a1e4ba5c6cbabddb\0000098.ts, C:\Users\willi\AppData\Roaming\Emby-Server\programdata\transcoding-temp\d8abace370934fc0a1e4ba5c6cbabddb\0000099.ts, C:\Users\willi\AppData\Roaming\Emby-Server\programdata\transcoding-temp\d8abace370934fc0a1e4ba5c6cbabddb\0000100.ts, C:\Users\willi\AppData\Roaming\Emby-Server\programdata\transcoding-temp\d8abace370934fc0a1e4ba5c6cbabddb\0000101.ts, C:\Users\willi\AppData\Roaming\Emby-Server\programdata\transcoding-temp\d8abace370934fc0a1e4ba5c6cbabddb\0000102.ts, C:\Users\willi\AppData\Roaming\Emby-Server\programdata\transcoding-temp\d8abace370934fc0a1e4ba5c6cbabddb\0000103.ts, C:\Users\willi\AppData\Roaming\Emby-Server\programdata\transcoding-temp\d8abace370934fc0a1e4ba5c6cbabddb\0000104.ts, C:\Users\willi\AppData\Roaming\Emby-Server\programdata\transcoding-temp\d8abace370934fc0a1e4ba5c6cbabddb\0000105.ts, C:\Users\willi\AppData\Roaming\Emby-Server\programdata\transcoding-temp\d8abace370934fc0a1e4ba5c6cbabddb\0000106.ts, C:\Users\willi\AppData\Roaming\Emby-Server\programdata\transcoding-temp\d8abace370934fc0a1e4ba5c6cbabddb\0000107.ts, C:\Users\willi\AppData\Roaming\Emby-Server\programdata\transcoding-temp\d8abace370934fc0a1e4ba5c6cbabddb\0000108.ts, C:\Users\willi\AppData\Roaming\Emby-Server\programdata\transcoding-temp\d8abace370934fc0a1e4ba5c6cbabddb\0000109.ts, C:\Users\willi\AppData\Roaming\Emby-Server\programdata\transcoding-temp\d8abace370934fc0a1e4ba5c6cbabddb\0000110.ts, C:\Users\willi\AppData\Roaming\Emby-Server\programdata\transcoding-temp\d8abace370934fc0a1e4ba5c6cbabddb\0000111.ts, C:\Users\willi\AppData\Roaming\Emby-Server\programdata\transcoding-temp\d8abace370934fc0a1e4ba5c6cbabddb\0000112.ts, C:\Users\willi\AppData\Roaming\Emby-Server\programdata\transcoding-temp\d8abace370934fc0a1e4ba5c6cbabddb\0000113.ts, C:\Users\willi\AppData\Roaming\Emby-Server\programdata\transcoding-temp\d8abace370934fc0a1e4ba5c6cbabddb\0000114.ts, C:\Users\willi\AppData\Roaming\Emby-Server\programdata\transcoding-temp\d8abace370934fc0a1e4ba5c6cbabddb\0000115.ts, C:\Users\willi\AppData\Roaming\Emby-Server\programdata\transcoding-temp\d8abace370934fc0a1e4ba5c6cbabddb\0000116.ts, C:\Users\willi\AppData\Roaming\Emby-Server\programdata\transcoding-temp\d8abace370934fc0a1e4ba5c6cbabddb\0000117.ts, C:\Users\willi\AppData\Roaming\Emby-Server\programdata\transcoding-temp\d8abace370934fc0a1e4ba5c6cbabddb\0000118.ts, C:\Users\willi\AppData\Roaming\Emby-Server\programdata\transcoding-temp\d8abace370934fc0a1e4ba5c6cbabddb\0000119.ts 2024-04-01 21:00:00.001 Info SharedHttpPipelineSource: SharedHttpPipelineSource is done streaming. 2024-04-01 21:00:00.277 Info MediaSourceManager: Live stream 06044cf0e6f93cdae5f285c9ecfaaeb4_01413a525b3a9622ce6fdf19f7dde354_native_dc8fbd69e0dcaf4b4f967488cd69747d_71b5a3799d29c6768eae607ca528d6ce closed successfully 2024-04-01 21:00:00.307 Info LiveTV: Running recording post processor C:\bin\Emby\MyEmbyPP1.bat "D:\Emby Recordings\The 2024 iHeartRadio Music Awards (2024)\The 2024 iHeartRadio Music Awards 2024_04_01_19_00_00.ts" 2024-04-01 21:00:00.307 Info LiveTV: ProcessRun 'Recording 14887245' Execute: C:\bin\Emby\MyEmbyPP1.bat "D:\Emby Recordings\The 2024 iHeartRadio Music Awards (2024)\The 2024 iHeartRadio Music Awards 2024_04_01_19_00_00.ts"
Luke 42184 Posted April 3, 2024 Posted April 3, 2024 Maybe the issue is that you need to run a library scan after the post processing script has completed.
TMCsw 256 Posted April 4, 2024 Posted April 4, 2024 Also, is RTM enabled for the library? and Is your server really running on a Windows server? or Linux?
Bill LeDuc 5 Posted April 4, 2024 Author Posted April 4, 2024 Yes, RTM is enabled and this is a dedicated I7 NUC running Windows 11. I question how well RTM works. When I copy files to a library I have had to manually run a library scan for the files to show up in Emby. It's like it finally notices the change, but it can take a long time. Why is this happening now I have only noticed it recently and I have been live recording for a couple of years. Should Emby doing something in post processing to avoid this and similar issues. Shouldn't Emby do a library scan after post processing. Is there a simple way to force a library scan as part of my post processing?
Luke 42184 Posted April 4, 2024 Posted April 4, 2024 Quote Shouldn't Emby do a library scan after post processing. We've never done this before, but yes it probably makes sense.
