AlecT 0 Posted April 2, 2024 Posted April 2, 2024 Hello. I'm using nvidia shield pro 2019 and having transcoding issues - transcoding turns on on some of my videos (with wide bitrate avg 190mbit/s). Maximum bitrate on client is set on 1000mbit, on server - auto. Audio (Dolby True HD) is supported bu my TV, i use audio bitstream. Video stutters and lugging. Same file plays via KODI flawlessly. embyserver.txt ffmpeg-remux-c4be93c7-bea7-4e5b-9139-a913a5975a0e_1.txt
Luke 42241 Posted April 2, 2024 Posted April 2, 2024 Hi. Can you try sideloading our standard android app on the same device and see how that compares? https://emby.media/emby-for-android.html Thanks.
AlecT 0 Posted April 3, 2024 Author Posted April 3, 2024 I have installed this version, but emby premiere required. Android TV version has been paid via google market. I have no activation key.
AlecT 0 Posted April 3, 2024 Author Posted April 3, 2024 Have checked just now. Mobile version works fine. Only ATV version has problems.
Luke 42241 Posted April 3, 2024 Posted April 3, 2024 Great. Are you happy continuing to use the Emby standard app?
AlecT 0 Posted April 4, 2024 Author Posted April 4, 2024 (edited) Hi. Yes, standart app works just fine. But i prefer ATV version to be fixed, i have ATV tv-box and i don't have emby premiere subscription. Mobile EMBY app i have used has been some kind of a mod. Edited April 4, 2024 by AlecT
Luke 42241 Posted April 4, 2024 Posted April 4, 2024 OK. We work very hard on Emby and we thank you for your support.
