user84 46 Posted March 31, 2024 Posted March 31, 2024 New Premiere user here who is pretty shocked that the trailers included with Premiere are essentially not viewable on the average TV. I noticed another thread stating that the source for higher quality trailers was lost later year and that @ebrand @Lukeare looking for a new solution. Any idea when this will be resolved?
Luke 42176 Posted April 2, 2024 Posted April 2, 2024 Hi, we are looking into better quality trailer sources. Thanks for the feedback.
Luke 42176 Posted April 29, 2025 Posted April 29, 2025 For those on the beta server, once you've updated to 4.9.0.51, and gotten the trailer plugin update, with the following days after that you'll start to more trailers and higher quality trailers. It is all youtube now. Please note, Emby apps are going to require compatibility updates, so i wouldn't switch to beta solely for this just yet. But if you already happen to run the beta, then please leave feedback in the testing area of the community. Thanks.
AngelSing 49 Posted April 30, 2025 Posted April 30, 2025 @LukeIdeally, there should be an option that allows the user to manually add or change the trailer link from the metadata. Many times the system doesn't select the correct language, but if I search on YouTube, I can usually find the trailer in the desired language and in good quality. 1
