Emre51 0 Posted March 30, 2024 Posted March 30, 2024 (edited) Hello, There is a bug in LG WebOS app when browsing photos. The browsing/viewing order gets messed up. It happens randomly after I view some photos for about 10 minutes and I have to restart the app to solve it. I demonstrated the problem in a video. This is not a one time thing, I have been having this problem ever since I started using Emby on my LG TV, which was about 4 months ago. Also, I know it is not a bug but loading some of the pictures is quiet slow. It takes 3 seconds to load some pictures. It would be great if you can improve the speed/performance. embyserver.txt Edited March 30, 2024 by Emre51
Luke 42234 Posted April 2, 2024 Posted April 2, 2024 Hi, we'll take a look at it. Thanks for reporting.
Fyn0X6F 2 Posted April 2, 2024 Posted April 2, 2024 (edited) I have the VERY slow loading of pictures on the LG Emby app as well. Some pictures it will load just fine, then every few it takes a very long time to load starting from the top of the image. So slow that would think it was coming down from Prodigy on a 2400Baud modem. If I have it set on a slide-show it will often take so long to load an image that the timer will have expired by the time the image loads and it is already moving on to the next image. I have tested this on 2 other devices one with a Roku Ultra on the same LG TV and one with a pretty old Roku built in on a TCL TV and both of those load just fine. It only seems to be affecting the Emby app on the LG WebOS. A side note, and a annoyance that may have nothing to do with the Emby app but the slideshow does not prevent the TV from going into it's screen-saver mode, which you would think it would given that there is constant activity on the screen, though perhaps that has something to do with how long it is taking to load the pictures. Edited April 2, 2024 by Fyn0X6F 2
Lid 4 Posted April 19, 2024 Posted April 19, 2024 I also seem to have a combination of the slow loading images which currently makes the LG App unusable for viewing photos. Along with the mixed up photo order where you select an image and then eventually see another image.
Emre51 0 Posted April 19, 2024 Author Posted April 19, 2024 2 hours ago, Lid said: I also seem to have a combination of the slow loading images which currently makes the LG App unusable for viewing photos. Along with the mixed up photo order where you select an image and then eventually see another image. I agree that Emby for LG is a poor experience for viewing photos. I ended up connecting an Android TV box and use the Android version of Emby app instead. It doesn't have these issues. I don't think Emby team will work on these issues any time soon, considering the fact that these issue were present for several months. I understand that Photo gallery is the least used feature of Emby, but I consider this as a critical issue and it should have been fixed months ago already. It literally makes photo viewing unusable.
Luke 42234 Posted April 30, 2024 Posted April 30, 2024 Hi, we are working on improving it .Thanks for the feedback.
Lid 4 Posted August 5, 2024 Posted August 5, 2024 Just to update on this to say I'm still experiencing the same problem even after an OS change and clean install of the Emby server. I was running my Emby server on 2008 R2 and finally moved over to Windows 10 recently. So there is a new OS and clean install of Emby server with imported backup from the previous setup. Server is running the latest stable release, LG C2 is running the latest firmware and has the latest Emby app installed. The photos all open correctly via other methods, web browsers, Emby client on Android, Emby Theatre on Windows PC. I don't believe there is any network performance issue between TV and server which would cause the slow photo opening as I can direct play a full 4K movie on the Emby LG App. Hopefully this can be resolved in the next LG App update. Thank you.
Emre51 0 Posted August 8, 2024 Author Posted August 8, 2024 On 8/5/2024 at 1:04 PM, Lid said: Just to update on this to say I'm still experiencing the same problem even after an OS change and clean install of the Emby server. I was running my Emby server on 2008 R2 and finally moved over to Windows 10 recently. So there is a new OS and clean install of Emby server with imported backup from the previous setup. Server is running the latest stable release, LG C2 is running the latest firmware and has the latest Emby app installed. The photos all open correctly via other methods, web browsers, Emby client on Android, Emby Theatre on Windows PC. I don't believe there is any network performance issue between TV and server which would cause the slow photo opening as I can direct play a full 4K movie on the Emby LG App. Hopefully this can be resolved in the next LG App update. Thank you. I am pretty sure this problem is not caused by server or the network speed. It is a problem with client, the LG app. Perhaps TV is performance wise not capable of loading the images quickly. But I find this to be very unlikely, considering that the same TV can direct play 4K 60-70 mbps movies without performance issues. Compared to average 3-5 MB size of pictures.
Luke 42234 Posted August 11, 2024 Posted August 11, 2024 On 8/8/2024 at 2:25 PM, Emre51 said: I am pretty sure this problem is not caused by server or the network speed. It is a problem with client, the LG app. Perhaps TV is performance wise not capable of loading the images quickly. But I find this to be very unlikely, considering that the same TV can direct play 4K 60-70 mbps movies without performance issues. Compared to average 3-5 MB size of pictures. Hi, the size is only one aspect. There is also decoding each image, how many it can decode at once, etc.
