Trevor68 70 Posted March 29, 2024 Posted March 29, 2024 Using 4.8.3 server upcoming TV episodes take forever to load on android client, to the point where I just give up waiting, for the web client about a full minute before they load. Server 4.7 is instant in either. embyserver.txt 3
Happy2Play 9814 Posted March 29, 2024 Posted March 29, 2024 Yes as it has to hit your Cache and on demand from provider to show you Upcome/future episodes. Where in 4.7 everything was in the database but was removed in 4.8.
Trevor68 70 Posted March 29, 2024 Author Posted March 29, 2024 (edited) Right, so basically yet another design decision that is totally unworkable then. So glad I kept 4.7 as my main server. Edited March 29, 2024 by Trevor68 2
Spaceboy 2573 Posted March 29, 2024 Posted March 29, 2024 page doesnt load at all for me. it may as well be removed
Happy2Play 9814 Posted March 29, 2024 Posted March 29, 2024 Not sure why it queries so often as I would think one a week would be more than enough. But will guess it is system or how many series one has on the list but only takes no more than 15 seconds here.
LongMan 117 Posted March 30, 2024 Posted March 30, 2024 Why not make this an optional feature, if having it slows the system so much. Maybe some of us are willing to give it up. 1
Happy2Play 9814 Posted March 30, 2024 Posted March 30, 2024 That catch 22 as already cached load instantly. Personally think the system may be too aggressive hitting TVDB. But that is a guess on my part.
Lessaj 486 Posted March 30, 2024 Posted March 30, 2024 You can tail the server log as the Upcoming page is loading and see all the requests being made, it can certainly take some time if you have a lot of shows that are still recurring and haven't ended yet.
Trevor68 70 Posted March 30, 2024 Author Posted March 30, 2024 (edited) 7 hours ago, Spaceboy said: page doesnt load at all for me. it may as well be removed That's my experience on any android client too. Given it literally doesn't work for a lot of the time I think it would be best to enable a radio button to allow those who choose to cache the info. I understand a lot of other stuff being dumped to trim the DB, but at least let us have this? What say you @Luke Edited March 30, 2024 by Trevor68 1
JoLas 26 Posted March 30, 2024 Posted March 30, 2024 (edited) For me it takes about 30 seconds to load in Edge and I have about 300 series or so... Personally I'm fine with it because I know it takes time and I use it as a reminder for upcoming seasons to get. For my users I would say useless, 30 seconds is way to long, they would have backed out within 10 seconds. It would be nice if there was a scheduled task for this so you could run it maybe once a week or set it to what you want. Edited March 30, 2024 by JoLarsson
esp1818 6 Posted March 30, 2024 Posted March 30, 2024 I have the same issue. Before version 4.8.x the Upcoming tab used to display instantly. Now it sits blank for about 30 seconds. The first time using it after the update I thought it was broken because it took so long to populate.
Trevor68 70 Posted April 1, 2024 Author Posted April 1, 2024 Cool, as I just timed the web app, it was a bit over a minute of spinny blue circle. 1
JediMedia 3 Posted April 21, 2024 Posted April 21, 2024 @Lukewhy not use the schedule to pre call the upcoming and save it into the Cache/DB. it is not that the upcoming changes every second to call the TVDB on the fly. for someone who has a very large media, this could take forever. 1 2
Luke 42288 Posted April 21, 2024 Posted April 21, 2024 HI, yes we are looking into imrpoving it. Thanks for the feedback.
Happy2Play 9814 Posted April 21, 2024 Posted April 21, 2024 Seems a lot faster in 4.8.4.0. But could be the plugin update also.
PrincessClevage 175 Posted May 20, 2024 Posted May 20, 2024 +1 for adding this to schedule and into db cache.
Luke 42288 Posted May 23, 2024 Posted May 23, 2024 HI, yes this is on our list for review. Thanks for the feedback.
Happy2Play 9814 Posted December 31, 2025 Posted December 31, 2025 1 hour ago, invertedknife said: Any update on this? Depends as it will always be a little slow depending on how many Shows you have that has to be updated/requeried as it takes mine 5 to 10 seconds depending on last time I clicked on it. And almost instant for a while afterwards as everything has been cached.
invertedknife 13 Posted December 31, 2025 Posted December 31, 2025 Is there a background task I can run to do this every day so there's no delay when I click on the upcoming?
Luke 42288 Posted December 31, 2025 Posted December 31, 2025 1 hour ago, invertedknife said: Is there a background task I can run to do this every day so there's no delay when I click on the upcoming? HI, not a built-in one, but what you could do is just open up the metadata manager and navigate to the missing episode view once a day to start the downloading of data. If you want to take that a step further, you could capture the emby server api url that it uses and automate fetching that once per day.
