Lelix2603 1 Posted March 29, 2024 Posted March 29, 2024 Hello could you help me? I installed Emby Server on an android mini pc I connected to it an external hdd with films inside I was able to connect Emby to the hdd and indeed sees the content correctly The problem is that when I try with Emby Client to start the movies do not start the screen remains black and I see no activity on the hdd (the LED does not flash) this happens both on android client and on smart tv do you have any suggestions? Another thing...I can't find the option to add files remotely in the library item I can't find the option to remotely add data thanks in advance
Luke 42237 Posted March 29, 2024 Posted March 29, 2024 Hi there, let's look at an example. Please attach the information requested in how to report a media playback issue. Thanks!
Lelix2603 1 Posted March 29, 2024 Author Posted March 29, 2024 Hello Luke Thanks for your fast reply With the streaming i have solved , with the upload file in the library problem no Can i upload from the network , files in the library of emby? I have create more library but i can t find the option to upload files Regards
Luke 42237 Posted March 30, 2024 Posted March 30, 2024 11 hours ago, Lelix2603 said: Hello Luke Thanks for your fast reply With the streaming i have solved , with the upload file in the library problem no Can i upload from the network , files in the library of emby? I have create more library but i can t find the option to upload files Regards Hi, no, but this question has come up before and is possible for future updates. Thanks.
