zaHrecsohbiw 14 Posted March 27, 2024 Posted March 27, 2024 On 8/19/2023 at 5:27 PM, Luke said: HI, confirmed in Emby for Apple TV 1.7.6. We're getting an update out to resolve it. Thanks. I believe this problem is back as of 1.8.4 1
Luke 42239 Posted March 27, 2024 Posted March 27, 2024 @zaHrecsohbiwHi there, can you please describe your issue in more detail? Thanks !
zaHrecsohbiw 14 Posted March 27, 2024 Author Posted March 27, 2024 Thank you for the quick reply. Installed Emby app on an Apple TV that has never had the app installed before. Trying to Skip on the opening “generate code” screen and nothing happens. It isn’t a case of freezing or an error, just can’t get past this screen.
Luke 42239 Posted March 27, 2024 Posted March 27, 2024 OK we'll take a look at this. Thanks for reporting. 1
Solution Luke 42239 Posted March 28, 2024 Solution Posted March 28, 2024 Hi, please try Emby for Apple TV 1.8.5. Thanks.
zaHrecsohbiw 14 Posted March 28, 2024 Author Posted March 28, 2024 Fixed! thank you again for the quick reply and especially resolution! 1
