NorthDegree 10 Posted March 27, 2024 Posted March 27, 2024 On the projectivity launcher Home Screen, emby shows blank thumbnails for watch next. Not necessarily a emby issue but maybe emby techs can help figure this out because it effects those using projectivity launcher on shield and may deter them from using emby. This link explains and shows the issue :
NorthDegree 10 Posted March 27, 2024 Author Posted March 27, 2024 tx for the reply Luke, yes with Emby running the thumbnails appear as per that reddit thread. I tested other apps (prime, Plex, Disney etc...) on the projectivity launcher and they all work fine. I also test on a CCwGTV with projectivity launcher and Emby was the only app that is having issues with thumbnail images on the launchers watch next home screen
Luke 42184 Posted March 27, 2024 Posted March 27, 2024 Hi. Can you try sideloading our standard android app on the same device and see how that compares? https://emby.media/emby-for-android.html Thanks.
NorthDegree 10 Posted March 28, 2024 Author Posted March 28, 2024 14 hours ago, Luke said: Hi. Can you try sideloading our standard android app on the same device and see how that compares? https://emby.media/emby-for-android.html Thanks. Luke, just tested with arm7 and same issue as regular android tv version
thomasboll 1 Posted March 30, 2024 Posted March 30, 2024 (edited) Having the same issue. Haven't found a solution anywhere. Edited March 30, 2024 by thomasboll
Luke 42184 Posted April 2, 2024 Posted April 2, 2024 OK we'll take a look at it. Thanks for reporting. 2
thomasboll 1 Posted April 2, 2024 Posted April 2, 2024 Seems like someone found a rather cumbersome solution: here. 1
NorthDegree 10 Posted April 8, 2024 Author Posted April 8, 2024 On 02/04/2024 at 02:21, Luke said: OK we'll take a look at it. Thanks for reporting. Hello again Luke, as thomasboll pointed out above , I looked into this solution but found this a bit much for my capabilities so will hold out on possible fix from your end if possible to access "localhost" like Plex does for image thumbnails.
Luke 42184 Posted April 9, 2024 Posted April 9, 2024 12 hours ago, NorthDegree said: Hello again Luke, as thomasboll pointed out above , I looked into this solution but found this a bit much for my capabilities so will hold out on possible fix from your end if possible to access "localhost" like Plex does for image thumbnails. Hi, the issue as we've mentioned in that topic is that Google is currently limiting access to this to their partners.
xlerate 9 Posted April 12, 2024 Posted April 12, 2024 On 4/9/2024 at 12:01 AM, Luke said: Hi, the issue as we've mentioned in that topic is that Google is currently limiting access to this to their partners. Is the reason that Plex thumbnails show because Plex is a partner and Emby is not? If so, is Emby going to become a Google partner?
NorthDegree 10 Posted April 12, 2024 Author Posted April 12, 2024 There was an update to the launcher today and the thumbnails now are displaying correctly 2
Luke 42184 Posted April 13, 2024 Posted April 13, 2024 1 hour ago, NorthDegree said: There was an update to the launcher today and the thumbnails now are displaying correctly That's great news. Thanks for following up.
