fox_chow 1 Posted March 25, 2024 Posted March 25, 2024 Currently, in the Emby player, the lowest bitrate option for selected 4K resolution is capped at 40 Mbps. If you want to decrease the bitrate further, you're forced to drop down to 1080p resolution. However, I'd like the freedom to choose lower bitrates while still keeping the 4K resolution intact. 1
Luke 42245 Posted March 25, 2024 Posted March 25, 2024 HI, yes more options are certainly possible for future updates. Thanks. 1
Happy2Play 9812 Posted March 25, 2024 Posted March 25, 2024 At the same time Bitrate and Resolution are meaningless as there is no correlation between the two from an Emby standpoint. Example 1080P/4Mbps doesn't exist as you will get 4Mbps but not 1080p.
