Jey2024 33 Posted March 25, 2024 Posted March 25, 2024 Hi there, I recently installed Emby to connect with my seedbox and am loving it so far. However, I'm having some trouble downloading subtitles manually. I have followed the guide and configured opensubtitles login details under Server > Open Subtitles. Now, when I go to manually search for a movie subtitle, it's always reporting as "No results found." I even edited the meta description. When I manually search on the OS website, the subtitle is there. Under Meta description, I've also verified the IMDb ID, etc. How do I troubleshoot this? Is it okay to share the movie name here and logs publicly, or is there a way to do it privately?
Happy2Play 9811 Posted March 25, 2024 Posted March 25, 2024 Really your choice but server log and specific examples are usually needed. I will guess this technically is not an Android issue though. But can have a mod move it later.
Jey2024 33 Posted March 25, 2024 Author Posted March 25, 2024 3 minutes ago, Happy2Play said: Really your choice but server log and specific examples are usually needed. I will guess this technically is not an Android issue though. But can have a mod move it later. Thank you for your time. It looks like Opensubtitles had some hiccups. I refreshed the metadata and reopened the app. The subtitles are listing properly now. I might upgrade to the premiere version because this seems like a really good media manager. Keep up the awesome work - and my apologies for this false alert. 1
