mbmondor 1 Posted March 24, 2024 Posted March 24, 2024 Both are mixed up together Can you open a fix for that so bel-air becomes a separate library in media? I am using the Docker version but follows the same version as linux
GrimReaper 4898 Posted March 24, 2024 Posted March 24, 2024 How are your files and folders named and organized? Your "Bel-Air" has been identified/recognized as "The Fresh Prince of Bel-Air" likely due to ambiguous naming. Either rename series folders distinctively enough: Bel-Air (2022) [tvdbid=388151] The Fresh Prince of Bel-Air (1990) [tvdbid=76738] OR Disable library option "Automatically merge series spread accross multiple folders" and re-Identify wrong show (Bel-Air). 1 1
mbmondor 1 Posted March 24, 2024 Author Posted March 24, 2024 They are renamed differently I can try to add the year on the tv show main folder I have a tv folder and all the shows are in they're own folder
Solution Happy2Play 9812 Posted March 24, 2024 Solution Posted March 24, 2024 (edited) Yes this will be an api by name look-up issue as it will return both shows. So with Emby it is the first choice per the returned api data as there really is no such thing as exact matching (unless you are providing providerids). Year in naming scheme should resolve this. Edited March 24, 2024 by Happy2Play 1
mbmondor 1 Posted March 24, 2024 Author Posted March 24, 2024 It worked. Renaming with the year Thanks 1
