chrypox 8 Posted March 24, 2024 Posted March 24, 2024 Hello, I've been an Emby user for years and I'm very happy with it. However, I've just noticed that for Video Clips, the "Genres" category has been removed on Chrome and also on the LG application. I manage over 4500 music video clips and everything was classified by genre for ease of use, allowing me to choose what I wanted to listen to at any given moment. I'm using the Plex theme on Chrome and I thought it was the problem, so I removed it, but the problem was still there. I thought about watching on my LG TV and the category was also missing. Can you tell me if you intend to put the genres back in the video clips or if there's a way of adding it in a different way? Thanks in advance
Happy2Play 9811 Posted March 24, 2024 Posted March 24, 2024 Should only be missing if there are no genres on content. Do your video clips still have genres in their metadata?
chrypox 8 Posted March 24, 2024 Author Posted March 24, 2024 Hello, thank you for your quick reply. Yes, all my video clips have genre tags as you can see on the capture.
Happy2Play 9811 Posted March 24, 2024 Posted March 24, 2024 (edited) Sorry was looking at a different content type library. This is a Music Videos content type library correct? @Lukethe tab is hidden per the console. Tags do work if I apply one. Tried appling a new genre and no luck. Unhide functions. Edited March 24, 2024 by Happy2Play
chrypox 8 Posted March 24, 2024 Author Posted March 24, 2024 Yes, it's a clip video library. When I look in the console I also see "Genres", but then why doesn't it appear in the header menu? That's odd.
Happy2Play 9811 Posted March 24, 2024 Posted March 24, 2024 8 minutes ago, chrypox said: Yes, it's a clip video library. When I look in the console I also see "Genres", but then why doesn't it appear in the header menu? That's odd. As you can see in the class it has "hide" so I can only guess a script is broken/changed when actual genres are present. If you remove hide the tab will show until you refresh the browser.
chrypox 8 Posted March 24, 2024 Author Posted March 24, 2024 So if I understand correctly, we have to wait for the coders to fix the problem? I could wait But I also have the same problem with LG's WebOS ...
Happy2Play 9811 Posted March 24, 2024 Posted March 24, 2024 (edited) 2 minutes ago, chrypox said: So if I understand correctly, we have to wait for the coders to fix the problem? I could wait But I also have the same problem with LG's WebOS ... Yes, don't know but will guess code in web client and per device client will have to get updates. But maybe just a server side fix. Edited March 24, 2024 by Happy2Play
Solution Luke 42239 Posted March 26, 2024 Solution Posted March 26, 2024 Hi, yes I can reproduce. We'll have this resolved in the upcoming 4.8.4 maintenance release. Thanks.
chrypox 8 Posted March 26, 2024 Author Posted March 26, 2024 (edited) Great, thank you Luc for this confirmation Edited March 26, 2024 by chrypox 1
chrypox 8 Posted April 20, 2024 Author Posted April 20, 2024 Problème résolu avec la nouvelle mise à jour. Un grand merci à vous 1
