Morshu 4 Posted March 23, 2024 Posted March 23, 2024 Hi! Using latest version of Emby for Android TV (from the store) with the latest Emby server for Synology NAS (64 bit). Some HEVC files aren't playing correctly, such as this one: Format : Matroska Format version : Version 4 File size : 33.9 GiB Duration : 3 h 0 min Overall bit rate mode : Variable Overall bit rate : 26.9 Mb/s Frame rate : 23.976 FPS Encoded date : 2024-03-17 13:47:53 UTC Writing application : mkvmerge v81.0 ('Milliontown') 64-bit Writing library : libebml v1.4.4 + libmatroska v1.7.1 Video ID : 1 Format : HEVC Format/Info : High Efficiency Video Coding Format profile : Main 10@L6@Main HDR format : SMPTE ST 2086, HDR10 compatible Codec ID : V_MPEGH/ISO/HEVC Duration : 3 h 0 min Bit rate : 23.3 Mb/s Width : 3 840 pixels Height : 2 160 pixels Display aspect ratio : 16:9 Frame rate mode : Constant Frame rate : 23.976 (24000/1001) FPS Color space : YUV Chroma subsampling : 4:2:0 (Type 2) Bit depth : 10 bits Bits/(Pixel*Frame) : 0.117 Stream size : 29.4 GiB (87%) Writing library : x265 3.5+37-0d865ebe2:[Windows][GCC 12.1.0][64 bit] 10bit Encoding settings : cpuid=1111039 / frame-threads=6 / numa-pools=24,24,24,24,0,0,0,0 / wpp / no-pmode / no-pme / no-psnr / no-ssim / log-level=2 / input-csp=1 / input-res=3840x2160 / interlace=0 / total-frames=259473 / level-idc=0 / high-tier=1 / uhd-bd=0 / ref=6 / no-allow-non-conformance / repeat-headers / annexb / no-aud / no-eob / no-eos / no-hrd / info / hash=0 / no-temporal-layers / no-open-gop / min-keyint=23 / keyint=250 / gop-lookahead=0 / bframes=14 / b-adapt=2 / b-pyramid / bframe-bias=0 / rc-lookahead=75 / lookahead-slices=8 / scenecut=40 / no-hist-scenecut / radl=0 / no-splice / no-intra-refresh / ctu=32 / min-cu-size=8 / no-rect / no-amp / max-tu-size=32 / tu-inter-depth=1 / tu-intra-depth=1 / limit-tu=0 / rdoq-level=2 / dynamic-rd=0.00 / no-ssim-rd / signhide / no-tskip / nr-intra=0 / nr-inter=0 / no-constrained-intra / no-strong-intra-smoothing / max-merge=3 / limit-refs=1 / no-limit-modes / me=3 / subme=7 / merange=64 / temporal-mvp / no-frame-dup / no-hme / weightp / weightb / no-analyze-src-pics / deblock=0:0 / no-sao / no-sao-non-deblock / rd=4 / selective-sao=0 / no-early-skip / rskip / no-fast-intra / no-tskip-fast / no-cu-lossless / b-intra / no-splitrd-skip / rdpenalty=2 / psy-rd=3.00 / psy-rdoq=4.80 / no-rd-refine / no-lossless / cbqpoffs=0 / crqpoffs=0 / rc=crf / crf=15.0 / qcomp=0.60 / qpstep=4 / stats-write=0 / stats-read=0 / ipratio=1.40 / pbratio=1.30 / aq-mode=1 / aq-strength=1.00 / cutree / zone-count=0 / no-strict-cbr / qg-size=32 / no-rc-grain / qpmax=69 / qpmin=0 / no-const-vbv / sar=0 / overscan=0 / videoformat=5 / range=0 / colorprim=9 / transfer=16 / colormatrix=9 / chromaloc=1 / chromaloc-top=2 / chromaloc-bottom=2 / display-window=0 / master-display=G(13250,34500)B(7500,3000)R(34000,16000)WP(15635,16450)L(10000000,50) / cll=186,147 / min-luma=0 / max-luma=1023 / log2-max-poc-lsb=8 / vui-timing-info / vui-hrd-info / slices=1 / no-opt-qp-pps / no-opt-ref-list-length-pps / no-multi-pass-opt-rps / scenecut-bias=0.05 / hist-threshold=0.03 / no-opt-cu-delta-qp / aq-motion / hdr10 / hdr10-opt / no-dhdr10-opt / no-idr-recovery-sei / analysis-reuse-level=0 / analysis-save-reuse-level=0 / analysis-load-reuse-level=0 / scale-factor=0 / refine-intra=0 / refine-inter=0 / refine-mv=1 / refine-ctu-distortion=0 / no-limit-sao / ctu-info=0 / no-lowpass-dct / refine-analysis-type=0 / copy-pic=1 / max-ausize-factor=1.0 / no-dynamic-refine / no-single-sei / no-hevc-aq / no-svt / no-field / qp-adaptation-range=1.00 / scenecut-aware-qp=0conformance-window-offsets / right=0 / bottom=0 / decoder-max-rate=0 / no-vbv-live-multi-pass Default : Yes Forced : No Color range : Limited Color primaries : BT.2020 Transfer characteristics : PQ Matrix coefficients : BT.2020 non-constant Mastering display color primaries : Display P3 Mastering display luminance : min: 0.0050 cd/m2, max: 1000 cd/m2 Maximum Content Light Level : 186 cd/m2 Maximum Frame-Average Light Level : 147 cd/m2 Audio ID : 2 ID in the original source medium : 4352 (0x1100) Format : DTS XLL Format/Info : Digital Theater Systems Commercial name : DTS-HD Master Audio Codec ID : A_DTS Duration : 3 h 0 min Bit rate mode : Variable Bit rate : 3 567 kb/s Channel(s) : 6 channels Channel layout : C L R Ls Rs LFE Sampling rate : 48.0 kHz Frame rate : 93.750 FPS (512 SPF) Bit depth : 24 bits Compression mode : Lossless Stream size : 4.49 GiB (13%) Title : 5.1 Language : English Default : Yes Forced : No Original source medium : Blu-ray Text #1 ID : 3 ID in the original source medium : 4768 (0x12A0) Format : PGS Muxing mode : zlib Codec ID : S_HDMV/PGS Codec ID/Info : Picture based subtitle format used on BDs/HD-DVDs Duration : 2 h 53 min Bit rate : 61.7 kb/s Frame rate : 0.594 FPS Count of elements : 6172 Stream size : 76.4 MiB (0%) Title : ENG Language : English Default : No Forced : No Original source medium : Blu-ray Text #2 ID : 4 Format : UTF-8 Codec ID : S_TEXT/UTF8 Codec ID/Info : UTF-8 Plain Text Duration : 2 h 59 min Bit rate : 68 b/s Frame rate : 0.187 FPS Count of elements : 2015 Stream size : 90.2 KiB (0%) Language : English Default : No Forced : No Can't really figure out why it's doing this. Let me know if you need more info, thanks!
Morshu 4 Posted March 23, 2024 Author Posted March 23, 2024 Hi again! Just thought I'd share another one that doesn't work: ormat : Matroska Format version : Version 4 File size : 15.9 GiB Duration : 2 h 20 min Overall bit rate mode : Variable Overall bit rate : 16.2 Mb/s Frame rate : 23.976 FPS Movie name : Movie Encoded date : 2024-03-16 11:05:30 UTC Writing application : mkvmerge v81.0 ('Milliontown') 64-bit Writing library : libebml v1.4.4 + libmatroska v1.7.1 / Lavf60.16.100 Video ID : 1 Format : HEVC Format/Info : High Efficiency Video Coding Format profile : Main@L6.2@Main Codec ID : V_MPEGH/ISO/HEVC Duration : 2 h 20 min Bit rate : 12.1 Mb/s Width : 3 840 pixels Height : 2 072 pixels Display aspect ratio : 1.85:1 Frame rate mode : Constant Frame rate : 23.976 (24000/1001) FPS Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Bits/(Pixel*Frame) : 0.064 Stream size : 11.9 GiB (75%) Default : Yes Forced : No Color range : Limited Color primaries : BT.709 Transfer characteristics : BT.709 Matrix coefficients : Identity matrix_coefficients_Original : BT.709 Audio ID : 2 Format : DTS XLL Format/Info : Digital Theater Systems Commercial name : DTS-HD Master Audio Codec ID : A_DTS Duration : 2 h 20 min Bit rate mode : Variable Bit rate : 4 020 kb/s Channel(s) : 6 channels Channel layout : C L R Ls Rs LFE Sampling rate : 48.0 kHz Frame rate : 93.750 FPS (512 SPF) Bit depth : 24 bits Compression mode : Lossless Stream size : 3.95 GiB (25%) Language : English Default : Yes Forced : No Text #1 ID : 3 Format : PGS Muxing mode : zlib Codec ID : S_HDMV/PGS Codec ID/Info : Picture based subtitle format used on BDs/HD-DVDs Duration : 2 h 12 min Bit rate : 41.3 kb/s Frame rate : 0.443 FPS Count of elements : 3514 Stream size : 39.0 MiB (0%) Language : English Default : No Forced : No Text #2 ID : 4 Format : PGS Muxing mode : zlib Codec ID : S_HDMV/PGS Codec ID/Info : Picture based subtitle format used on BDs/HD-DVDs Duration : 2 h 14 min Bit rate : 43.4 kb/s Frame rate : 0.475 FPS Count of elements : 3838 Stream size : 41.8 MiB (0%) Language : English Default : No Forced : No Text #3 ID : 5 Format : UTF-8 Codec ID : S_TEXT/UTF8 Codec ID/Info : UTF-8 Plain Text Duration : 2 h 12 min Bit rate : 58 b/s Frame rate : 0.203 FPS Count of elements : 1618 Stream size : 56.5 KiB (0%) Language : English Default : No Forced : No And here is one that do work: Format : Matroska Format version : Version 4 File size : 28.4 GiB Duration : 2 h 18 min Overall bit rate mode : Variable Overall bit rate : 29.4 Mb/s Frame rate : 23.976 FPS Movie name : Movie Encoded date : 2024-03-22 19:12:21 UTC Writing application : mkvmerge v83.0 ('Circle Of Friends') 64-bit Writing library : libebml v1.4.5 + libmatroska v1.7.1 Video ID : 1 Format : HEVC Format/Info : High Efficiency Video Coding Format profile : Main 10@L5.1@Main HDR format : Dolby Vision, Version 1.0, dvhe.08.06, BL+RPU, HDR10 compatible / SMPTE ST 2086, HDR10 compatible / SMPTE ST 2086, HDR10 compatible Codec ID : V_MPEGH/ISO/HEVC Duration : 2 h 18 min Bit rate : 25.1 Mb/s Width : 3 840 pixels Height : 1 604 pixels Display aspect ratio : 2.39:1 Frame rate mode : Constant Frame rate : 23.976 (24000/1001) FPS Color space : YUV Chroma subsampling : 4:2:0 (Type 2) Bit depth : 10 bits Bits/(Pixel*Frame) : 0.170 Stream size : 24.2 GiB (85%) Writing library : x265 3.5+1-f0c1022b6:[Windows][GCC 13.2.0][64 bit] 10bit Encoding settings : cpuid=1111039 / frame-threads=4 / numa-pools=24 / wpp / no-pmode / no-pme / no-psnr / no-ssim / log-level=2 / input-csp=1 / input-res=3840x1604 / interlace=0 / total-frames=0 / level-idc=51 / high-tier=0 / uhd-bd=0 / ref=1 / no-allow-non-conformance / repeat-headers / annexb / aud / no-eob / no-eos / hrd / info / hash=0 / temporal-layers=0 / open-gop / min-keyint=24 / keyint=240 / gop-lookahead=0 / bframes=3 / b-adapt=0 / b-pyramid / bframe-bias=0 / rc-lookahead=10 / lookahead-slices=8 / scenecut=40 / no-hist-scenecut / radl=0 / no-splice / no-intra-refresh / ctu=32 / min-cu-size=8 / no-rect / no-amp / max-tu-size=32 / tu-inter-depth=1 / tu-intra-depth=1 / limit-tu=0 / rdoq-level=1 / dynamic-rd=0.00 / no-ssim-rd / signhide / no-tskip / nr-intra=0 / nr-inter=0 / no-constrained-intra / no-strong-intra-smoothing / max-merge=2 / limit-refs=0 / no-limit-modes / me=1 / subme=1 / merange=57 / temporal-mvp / no-frame-dup / no-hme / no-weightp / no-weightb / no-analyze-src-pics / deblock=0:0 / no-sao / no-sao-non-deblock / rd=4 / selective-sao=0 / early-skip / rskip / rskip-edge-threshold=0.050000 / fast-intra / no-tskip-fast / no-cu-lossless / no-b-intra / no-splitrd-skip / rdpenalty=0 / psy-rd=0.75 / psy-rdoq=4.00 / no-rd-refine / no-lossless / cbqpoffs=0 / crqpoffs=0 / rc=abr / bitrate=25500 / qcomp=0.60 / qpstep=4 / stats-write=0 / stats-read=2 / cplxblur=20.0 / qblur=0.5 / vbv-maxrate=25600 / vbv-bufsize=25600 / vbv-init=0.9 / min-vbv-fullness=50.0 / max-vbv-fullness=80.0 / ipratio=1.40 / pbratio=1.30 / aq-mode=1 / aq-strength=0.00 / cutree / zone-count=0 / no-strict-cbr / qg-size=32 / no-rc-grain / qpmax=69 / qpmin=0 / no-const-vbv / sar=1 / overscan=0 / videoformat=5 / range=0 / colorprim=9 / transfer=16 / colormatrix=9 / chromaloc=1 / chromaloc-top=2 / chromaloc-bottom=2 / display-window=0 / master-display=G(8500,39850)B(6550,2300)R(35400,14600)WP(15635,16450)L(10000000,1) / cll=798,773 / min-luma=0 / max-luma=1023 / log2-max-poc-lsb=8 / vui-timing-info / vui-hrd-info / slices=1 / no-opt-qp-pps / no-opt-ref-list-length-pps / no-multi-pass-opt-rps / scenecut-bias=0.05 / no-opt-cu-delta-qp / no-aq-motion / hdr10 / hdr10-opt / no-dhdr10-opt / no-idr-recovery-sei / analysis-reuse-level=0 / analysis-save-reuse-level=0 / analysis-load-reuse-level=0 / scale-factor=0 / refine-intra=0 / refine-inter=0 / refine-mv=1 / refine-ctu-distortion=0 / no-limit-sao / ctu-info=0 / no-lowpass-dct / refine-analysis-type=0 / copy-pic=1 / max-ausize-factor=1.0 / no-dynamic-refine / no-single-sei / no-hevc-aq / no-svt / no-field / qp-adaptation-range=1.00 / scenecut-aware-qp=0conformance-window-offsets / right=0 / bottom=0 / decoder-max-rate=0 / no-vbv-live-multi-pass / no-mcstf / no-sbrc Default : Yes Forced : No Color range : Limited Color primaries : BT.2020 Transfer characteristics : PQ Matrix coefficients : BT.2020 non-constant Mastering display color primaries : BT.2020 Mastering display luminance : min: 0.0001 cd/m2, max: 1000 cd/m2 Maximum Content Light Level : 798 MaxCLL_Original : 798 cd/m2 Maximum Frame-Average Light Level : 773 MaxFALL_Original : 773 cd/m2 Audio ID : 2 ID in the original source medium : 4352 (0x1100) Format : DTS XLL Format/Info : Digital Theater Systems Commercial name : DTS-HD Master Audio Codec ID : A_DTS Duration : 2 h 18 min Bit rate mode : Variable Bit rate : 4 280 kb/s Channel(s) : 6 channels Channel layout : C L R Ls Rs LFE Sampling rate : 48.0 kHz Frame rate : 93.750 FPS (512 SPF) Bit depth : 24 bits Compression mode : Lossless Stream size : 4.13 GiB (15%) Title : English Language : English Default : Yes Forced : No Original source medium : Blu-ray Text ID : 3 ID in the original source medium : 4768 (0x12A0) Format : PGS Muxing mode : zlib Codec ID : S_HDMV/PGS Codec ID/Info : Picture based subtitle format used on BDs/HD-DVDs Duration : 2 h 16 min Bit rate : 30.3 kb/s Frame rate : 0.428 FPS Count of elements : 3514 Stream size : 29.6 MiB (0%) Language : English Default : No Forced : No Original source medium : Blu-ray
ebr 16336 Posted March 24, 2024 Posted March 24, 2024 Hi. Can you try sideloading our standard android app on the same device and see how that compares? https://emby.media/emby-for-android.html Thanks.
Morshu 4 Posted March 25, 2024 Author Posted March 25, 2024 Hi, and thanks for the reply. I tried your advice, but it's no better when sideloading the other app,although slightly different. With the Android TV app I just get a black screen, the player says it is direct playing (which it should): With the sideloaded Android app you linked to, I get choppy play with washed out colors (don't know if it comes through in the screenshot): Also, I'm a bit confused about the sideloaded app, it says I'm restricted to 1 minute of play, should it do that? My Android TV app is unlocked...
FrostByte 5454 Posted June 23, 2024 Posted June 23, 2024 Are all the files that don't work HEVC level 6.x? Does your TV/device support it? Just looking at new Samsung's I see they only support 4K up to HEVC level 5.1 and HEVC level 6.x is reserved for 8K. Video Decoder Limitations H.264 FHD: Level 4.2 supported (FMO/ASO/RS not supported). H.264 UHD: Level 5.1 supported, seamless resolution change supported up to 3840x2160. HEVC FHD: Level 4.1 supported. HEVC UHD: Level 5.2 supported, seamless resolution change supported with Level 5.1 up to 3840x2160. HEVC 8K : Level 6.1 supported. HEVC: Supported only for MKV/MP4/TS containers. VC-1 AP L4: Not supported. GMC 2 and higher: Not supported. 2
Happy2Play 9812 Posted June 23, 2024 Posted June 23, 2024 (edited) Good catch Format profile : Main 10@L6@Main Format profile : Main@L6.2@Main I would think logs should have catch this or capabilities checks. Basically encoding beyond supported specs. Edited June 23, 2024 by Happy2Play
Morshu 4 Posted June 23, 2024 Author Posted June 23, 2024 Hi! Sorry for the late reply, had to re-test this, and also updated Emby server to the latest version prior to doing so. Unfortunately, the files I reported still don't play on Emby. The same context as I made in my original post applies, i.e. I use Nvidia shield pro for playback, the files play fine on PLEX, but I can't get them to work on Emby for Android TV.
Happy2Play 9812 Posted June 23, 2024 Posted June 23, 2024 And is Plex Direct Playing them also? Without specific methods it is impossible to say and may need Transcoding for the defective encoded method. Potentially need logs also. 1
ebr 16336 Posted June 24, 2024 Posted June 24, 2024 On 6/23/2024 at 9:50 AM, Happy2Play said: Good catch Format profile : Main 10@L6@Main Format profile : Main@L6.2@Main I would think logs should have catch this or capabilities checks. Basically encoding beyond supported specs. Yeah, the TV app is not checking the profile level on HEVC. I'll correct that. 1
ebr 16336 Posted June 24, 2024 Posted June 24, 2024 @MorshuIf you enable "Show extended media information" in the settings of the Android TV app and scroll down to the media info cards on the detail page, what does the "Level" show for one that works and one that doesn't?
Morshu 4 Posted June 28, 2024 Author Posted June 28, 2024 Sorry for the late reply, I am not home so much during the summer, so couldn't test right away. For a file that works it says: Level 153 For a file that doesn't work it says: Level 186 1
reas11 2 Posted July 13, 2024 Posted July 13, 2024 Having the same issue of no video and only sound. For me it's with files that are rips from Bravia core such as the enhanced IMAX files. They play fine in Kodi, VLC and Plex. It's only a Emby issue on Shield
bearzilla333 2 Posted July 14, 2024 Posted July 14, 2024 I too am having this issue now, HEVC not playing on my Nvidia Shield, I am using the side loaded standard app.
smgsmagus 0 Posted July 14, 2024 Posted July 14, 2024 same for me for files with profile: Main 10@L6@Main but for whatever reason it behaves same way with file like: Video ID : 1 Format : HEVC Format/Info : High Efficiency Video Coding Format profile : Main 10@L5.2@High Codec ID : hvc1 Codec ID/Info : High Efficiency Video Coding Duration : 53 s 267 ms Bit rate : 130 Mb/s Width : 3 840 pixels Height : 2 160 pixels Display aspect ratio : 16:9 Frame rate mode : Constant Frame rate : 30.000 FPS Standard : Component Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 10 bits Scan type : Progressive Bits/(Pixel*Frame) : 0.522 Stream size : 822 MiB (100%) Encoded date : 2024-07-14 19:58:55 UTC Tagged date : 2024-07-14 20:01:50 UTC Color range : Limited Color primaries : BT.709 Transfer characteristics : BT.709 Matrix coefficients : BT.709 Codec configuration box : hvcC Audio ID : 2 Format : AAC LC Format/Info : Advanced Audio Codec Low Complexity Codec ID : mp4a-40-2 Duration : 53 s 267 ms Source duration : 53 s 290 ms Bit rate mode : Constant Bit rate : 203 kb/s Channel(s) : 2 channels Channel layout : L R Sampling rate : 44.1 kHz Frame rate : 43.066 FPS (1024 SPF) Compression mode : Lossy Stream size : 1.29 MiB (0%) Source stream size : 1.29 MiB (0%) Default : Yes Alternate group : 1 Encoded date : 2024-07-14 19:58:55 UTC Tagged date : 2024-07-14 20:01:50 UTC mdhd_Duration : 53267
Luke 42243 Posted July 16, 2024 Posted July 16, 2024 On 7/14/2024 at 4:53 PM, smgsmagus said: same for me for files with profile: Main 10@L6@Main but for whatever reason it behaves same way with file like: Video ID : 1 Format : HEVC Format/Info : High Efficiency Video Coding Format profile : Main 10@L5.2@High Codec ID : hvc1 Codec ID/Info : High Efficiency Video Coding Duration : 53 s 267 ms Bit rate : 130 Mb/s Width : 3 840 pixels Height : 2 160 pixels Display aspect ratio : 16:9 Frame rate mode : Constant Frame rate : 30.000 FPS Standard : Component Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 10 bits Scan type : Progressive Bits/(Pixel*Frame) : 0.522 Stream size : 822 MiB (100%) Encoded date : 2024-07-14 19:58:55 UTC Tagged date : 2024-07-14 20:01:50 UTC Color range : Limited Color primaries : BT.709 Transfer characteristics : BT.709 Matrix coefficients : BT.709 Codec configuration box : hvcC Audio ID : 2 Format : AAC LC Format/Info : Advanced Audio Codec Low Complexity Codec ID : mp4a-40-2 Duration : 53 s 267 ms Source duration : 53 s 290 ms Bit rate mode : Constant Bit rate : 203 kb/s Channel(s) : 2 channels Channel layout : L R Sampling rate : 44.1 kHz Frame rate : 43.066 FPS (1024 SPF) Compression mode : Lossy Stream size : 1.29 MiB (0%) Source stream size : 1.29 MiB (0%) Default : Yes Alternate group : 1 Encoded date : 2024-07-14 19:58:55 UTC Tagged date : 2024-07-14 20:01:50 UTC mdhd_Duration : 53267 Hi. Can you try searching for our standard android app (Just "Emby" on Amazon and "Emby for Android on Google) on the same device's app store and see how that compares? Thanks.
Morshu 4 Posted July 24, 2024 Author Posted July 24, 2024 Sorry for the late reply, had to get home to test. Tested with the other app, but sadly that one also had choppy playback (although a little less choppy, dunno if that matters). Also, it didn't seem to read the colors correctly.
rbjtech 5344 Posted July 25, 2024 Posted July 25, 2024 (edited) 130Mbit/sec bitrate ... ? HEVC Profile is good. Are you playing back via wired (1Gig on Shield) or wireless ? Kodi and VLC will be playing back via SMB/File - Plex I'm not sure. The Shield is more than capable of playing 130Mbit - but if your server cannot handle the conversion to HTTP or you do not have enough bandwidth, then it may be that issue here - difficult to see without a log. Edited July 25, 2024 by rbjtech
smgsmagus 0 Posted July 25, 2024 Posted July 25, 2024 I have just tested freshly updated LG WebOS Emby app and file plays there without any issues. Still hangs on Shield after 1 second ( audio plays, video freeze).
Happy2Play 9812 Posted July 25, 2024 Posted July 25, 2024 On 7/14/2024 at 1:53 PM, smgsmagus said: same for me for files with profile: Main 10@L6@Main but for whatever reason it behaves same way with file like: Video ID : 1 Format : HEVC Format/Info : High Efficiency Video Coding Format profile : Main 10@L5.2@High In reality most device specs are limited to @L5.1 as previously mentioned. So unless that changes, I really don't see direct play of this media working out very well.
Morshu 4 Posted July 25, 2024 Author Posted July 25, 2024 Although since these files play fine on Plex, I have hard time seeing the hardware limitation here... And no, there is no re-encoding going on as I don't have a plex pass (nor hw capable server), so that's gotta be direct play.
Morshu 4 Posted July 25, 2024 Author Posted July 25, 2024 5 hours ago, rbjtech said: 130Mbit/sec bitrate ... ? HEVC Profile is good. Are you playing back via wired (1Gig on Shield) or wireless ? Kodi and VLC will be playing back via SMB/File - Plex I'm not sure. The Shield is more than capable of playing 130Mbit - but if your server cannot handle the conversion to HTTP or you do not have enough bandwidth, then it may be that issue here - difficult to see without a log. All wired 1Gig, no wireless.
Happy2Play 9812 Posted July 25, 2024 Posted July 25, 2024 43 minutes ago, Morshu said: Although since these files play fine on Plex, I have hard time seeing the hardware limitation here... And no, there is no re-encoding going on as I don't have a plex pass (nor hw capable server), so that's gotta be direct play. Specs were posted so if you don't go by manufacture spec then I don't see how play back can be expected. Have no idea what the other guy do though. But you already stated anything above @L5.1 does not play correctly. Devs would have to comment more as all I can do is go off documentation.
ebr 16336 Posted July 26, 2024 Posted July 26, 2024 18 hours ago, smgsmagus said: I have just tested freshly updated LG WebOS Emby app and file plays there without any issues. Still hangs on Shield after 1 second ( audio plays, video freeze). Can you please try the beta release of the app?
Morshu 4 Posted July 26, 2024 Author Posted July 26, 2024 32 minutes ago, ebr said: Can you please try the beta release of the app? Wow, it totally worked! That's some masterful dev work right there, thank you sir. 1 1
