kmcmurtrie 3 Posted March 23, 2024 Posted March 23, 2024 A nearby friend is using a lower-end Samsung TV to watch Emby on my server. The App Emby for Samsung 4.8.3.0 usually doesn't work (says no compatible stream) so the TV's web browser is being used. The dashboard activity shows starting and finishing watching normally. On the other hand, TV streaming seems to be paused forever. FFmpeg keeps running and it fills the hard disk. I set "Live stream buffer size limit" to 2 hours but it doesn't help. Killing ffmepg causes Emby to log this: Quote 2024-03-22 20:25:15.449 Info Server: http/1.1 Response 200 to 127.0.0.1. Time: 106816754ms. GET http://127.0.0.1:8096/LiveTv/LiveStreamFiles/ac0a16f2d55f4f6cb2bd2fec9b814baa/stream.ts 2024-03-22 20:25:15.453 Info App: AppendExtraLogData - Read graph file: /var/lib/emby/logs/ffmpeg-transcode-d017f674-fe02-470d-af56-bba6c52255f4_1graph.txt 2024-03-22 20:25:15.453 Info App: AppendExtraLogData - Deserialized GraphData fileStream: 11,932.000 bytes Graph Count: 1 2024-03-22 20:25:15.453 Info App: AppendExtraLogData - File Deleted 2024-03-22 20:25:15.702 Info App: ProcessRun 'StreamTranscode d017f6' Process exited with code 255 - Failed 2024-03-22 20:25:15.702 Info MediaSourceManager: Live stream native_b23ebc9442ec90ed5f591ef1683972b1_7cb44b1bbc7642c89815f8917ef56400 consumer count is now 0 2024-03-22 20:25:15.702 Info MediaSourceManager: Closing live stream 06044cf0e6f93cdae5f285c9ecfaaeb4_01413a525b3a9622ce6fdf19f7dde354_native_b23ebc9442ec90ed5f591ef1683972b1_7cb44b1bbc7642c89815f8917ef56400 2024-03-22 20:25:15.702 Info SharedHttpPipelineSource: Closing SharedHttpPipelineSource 2024-03-22 20:25:15.702 Info SharedHttpPipelineSource: Deleting temp files /tmp/transcoding-temp/ac0a16f2d55f4f6cb2bd2fec9b814baa/0001659.ts, /tmp/transcoding-temp/ac0a16f2d55f4f6cb2bd2fec9b814baa/0001660.ts, /tmp/transcoding-temp/ac0a16f2d55f4f6cb2bd2fec9b814baa/0001661.ts, /tmp/transcoding-temp/ac0a16f2d55f4f6cb2bd2fec9b814baa/0001662.ts, /tmp/transcoding-temp/ac0a16f2d55f4f6cb2bd2fec9b814baa/0001663.ts, /tmp/transcoding-temp/ac0a16f2d55f4f6cb2bd2fec9b814baa/0001664.ts, /tmp/transcoding-temp/ac0a16f2d55f4f6cb2bd2fec9b814baa/0001665.ts, /tmp/transcoding-temp/ac0a16f2d55f4f6cb2bd2fec9b814baa/0001666.ts, /tmp/transcoding-temp/ac0a16f2d55f4f6cb2bd2fec9b814baa/0001667.ts, /tmp/transcoding-temp/ac0a16f2d55f4f6cb2bd2fec9b814baa/0001668.ts, /tmp/transcoding-temp/ac0a16f2d55f4f6cb2bd2fec9b814baa/0001669.ts, /tmp/transcoding-temp/ac0a16f2d55f4f6cb2bd2fec9b814baa/0001670.ts, /tmp/transcoding-temp/ac0a16f2d55f4f6cb2bd2fec9b814baa/0001671.ts, /tmp/transcoding-temp/ac0a16f2d55f4f6cb2bd2fec9b814baa/0001672.ts, /tmp/transcoding-temp/ac0a16f2d55f4f6cb2bd2fec9b814baa/0001673.ts, /tmp/transcoding-temp/ac0a16f2d55f4f6cb2bd2fec9b814baa/0001674.ts, /tmp/transcoding-temp/ac0a16f2d55f4f6cb2bd2fec9b814baa/0001675.ts, /tmp/transcoding-temp/ac0a16f2d55f4f6cb2bd2fec9b814baa/0001676.ts, /tmp/transcoding-temp/ac0a16f2d55f4f6cb2bd2fec9b814baa/0001677.ts, /tmp/transcoding-temp/ac0a16f2d55f4f6cb2bd2fec9b814baa/0001678.ts, /tmp/transcoding-temp/ac0a16f2d55f4f6cb2bd2fec9b814baa/0001679.ts, /tmp/transcoding-temp/ac0a16f2d55f4f6cb2bd2fec9b814baa/0001680.ts, /tmp/transcoding-temp/ac0a16f2d55f4f6cb2bd2fec9b814baa/0001681.ts, /tmp/transcoding-temp/ac0a16f2d55f4f6cb2bd2fec9b814baa/0001682.ts, /tmp/transcoding-temp/ac0a16f2d55f4f6cb2bd2fec9b814baa/0001683.ts, /tmp/transcoding-temp/ac0a16f2d55f4f6cb2bd2fec9b814baa/0001684.ts, /tmp/transcoding-temp/ac0a16f2d55f4f6cb2bd2fec9b814baa/0001685.ts, /tmp/transcoding-temp/ac0a16f2d55f4f6cb2bd2fec9b814baa/0001686.ts, /tmp/transcoding-temp/ac0a16f2d55f4f6cb2bd2fec9b814baa/0001687.ts, /tmp/transcoding-temp/ac0a16f2d55f4f6cb2bd2fec9b814baa/0001688.ts, /tmp/transcoding-temp/ac0a16f2d55f4f6cb2bd2fec9b814baa/0001689.ts, /tmp/transcoding-temp/ac0a16f2d55f4f6cb2bd2fec9b814baa/0001690.ts, /tmp/transcoding-temp/ac0a16f2d55f4f6cb2bd2fec9b814baa/0001691.ts, /tmp/transcoding-temp/ac0a16f2d55f4f6cb2bd2fec9b814baa/0001692.ts, /tmp/transcoding-temp/ac0a16f2d55f4f6cb2bd2fec9b814baa/0001693.ts, /tmp/transcoding-temp/ac0a16f2d55f4f6cb2bd2fec9b814baa/0001694.ts, /tmp/transcoding-temp/ac0a16f2d55f4f6cb2bd2fec9b814baa/0001695.ts, /tmp/transcoding-temp/ac0a16f2d55f4f6cb2bd2fec9b814baa/0001696.ts, /tmp/transcoding-temp/ac0a16f2d55f4f6cb2bd2fec9b814baa/0001697.ts, /tmp/transcoding-temp/ac0a16f2d55f4f6cb2bd2fec9b814baa/0001698.ts, /tmp/transcoding-temp/ac0a16f2d55f4f6cb2bd2fec9b814baa/0001699.ts, /tmp/transcoding-temp/ac0a16f2d55f4f6cb2bd2fec9b814baa/0001700.ts, /tmp/transcoding-temp/ac0a16f2d55f4f6cb2bd2fec9b814baa/0001701.ts, /tmp/transcoding-temp/ac0a16f2d55f4f6cb2bd2fec9b814baa/0001702.ts, /tmp/transcoding-temp/ac0a16f2d55f4f6cb2bd2fec9b814baa/0001703.ts, /tmp/transcoding-temp/ac0a16f2d55f4f6cb2bd2fec9b814baa/0001704.ts, /tmp/transcoding-temp/ac0a16f2d55f4f6cb2bd2fec9b814baa/0001705.ts, /tmp/transcoding-temp/ac0a16f2d55f4f6cb2bd2fec9b814baa/0001706.ts, /tmp/transcoding-temp/ac0a16f2d55f4f6cb2bd2fec9b814baa/0001707.ts, /tmp/transcoding-temp/ac0a16f2d55f4f6cb2bd2fec9b814baa/0001708.ts, /tmp/transcoding-temp/ac0a16f2d55f4f6cb2bd2fec9b814baa/0001709.ts, /tmp/transcoding-temp/ac0a16f2d55f4f6cb2bd2fec9b814baa/0001710.ts, /tmp/transcoding-temp/ac0a16f2d55f4f6cb2bd2fec9b814baa/0001711.ts, /tmp/transcoding-temp/ac0a16f2d55f4f6cb2bd2fec9b814baa/0001712.ts, /tmp/transcoding-temp/ac0a16f2d55f4f6cb2bd2fec9b814baa/0001713.ts, /tmp/transcoding-temp/ac0a16f2d55f4f6cb2bd2fec9b814baa/0001714.ts, /tmp/transcoding-temp/ac0a16f2d55f4f6cb2bd2fec9b814baa/0001715.ts, /tmp/transcoding-temp/ac0a16f2d55f4f6cb2bd2fec9b814baa/0001716.ts, /tmp/transcoding-temp/ac0a16f2d55f4f6cb2bd2fec9b814baa/0001717.ts, /tmp/transcoding-temp/ac0a16f2d55f4f6cb2bd2fec9b814baa/0001718.ts, /tmp/transcoding-temp/ac0a16f2d55f4f6cb2bd2fec9b814baa/0001719.ts, /tmp/transcoding-temp/ac0a16f2d55f4f6cb2bd2fec9b814baa/0001720.ts, /tmp/transcoding-temp/ac0a16f2d55f4f6cb2bd2fec9b814baa/0001721.ts, /tmp/transcoding-temp/ac0a16f2d55f4f6cb2bd2fec9b814baa/0001722.ts, /tmp/transcoding-temp/ac0a16f2d55f4f6cb2bd2fec9b814baa/0001723.ts, /tmp/transcoding-temp/ac0a16f2d55f4f6cb2bd2fec9b814baa/0001724.ts, /tmp/transcoding-temp/ac0a16f2d55f4f6cb2bd2fec9b814baa/0001725.ts, /tmp/transcoding-temp/ac0a16f2d55f4f6cb2bd2fec9b814baa/0001726.ts, /tmp/transcoding-temp/ac0a16f2d55f4f6cb2bd2fec9b814baa/0001727.ts, /tmp/transcoding-temp/ac0a16f2d55f4f6cb2bd2fec9b814baa/0001728.ts, /tmp/transcoding-temp/ac0a16f2d55f4f6cb2bd2fec9b814baa/0001729.ts, /tmp/transcoding-temp/ac0a16f2d55f4f6cb2bd2fec9b814baa/0001730.ts, /tmp/transcoding-temp/ac0a16f2d55f4f6cb2bd2fec9b814baa/0001731.ts, /tmp/transcoding-temp/ac0a16f2d55f4f6cb2bd2fec9b814baa/0001732.ts, /tmp/transcoding-temp/ac0a16f2d55f4f6cb2bd2fec9b814baa/0001733.ts, /tmp/transcoding-temp/ac0a16f2d55f4f6cb2bd2fec9b814baa/0001734.ts, /tmp/transcoding-temp/ac0a16f2d55f4f6cb2bd2fec9b814baa/0001735.ts, /tmp/transcoding-temp/ac0a16f2d55f4f6cb2bd2fec9b814baa/0001736.ts, /tmp/transcoding-temp/ac0a16f2d55f4f6cb2bd2fec9b814baa/0001737.ts, /tmp/transcoding-temp/ac0a16f2d55f4f6cb2bd2fec9b814baa/0001738.ts, /tmp/transcoding-temp/ac0a16f2d55f4f6cb2bd2fec9b814baa/0001739.ts, /tmp/transcoding-temp/ac0a16f2d55f4f6cb2bd2fec9b814baa/0001740.ts, /tmp/transcoding-temp/ac0a16f2d55f4f6cb2bd2fec9b814baa/0001741.ts, /tmp/transcoding-temp/ac0a16f2d55f4f6cb2bd2fec9b814baa/0001742.ts, /tmp/transcoding-temp/ac0a16f2d55f4f6cb2bd2fec9b814baa/0001743.ts, /tmp/transcoding-temp/ac0a16f2d55f4f6cb2bd2fec9b814baa/0001744.ts, /tmp/transcoding-temp/ac0a16f2d55f4f6cb2bd2fec9b814baa/0001745.ts, /tmp/transcoding-temp/ac0a16f2d55f4f6cb2bd2fec9b814baa/0001746.ts, /tmp/transcoding-temp/ac0a16f2d55f4f6cb2bd2fec9b814baa/0001747.ts, /tmp/transcoding-temp/ac0a16f2d55f4f6cb2bd2fec9b814baa/0001748.ts, /tmp/transcoding-temp/ac0a16f2d55f4f6cb2bd2fec9b814baa/0001749.ts, /tmp/transcoding-temp/ac0a16f2d55f4f6cb2bd2fec9b814baa/0001750.ts, /tmp/transcoding-temp/ac0a16f2d55f4f6cb2bd2fec9b814baa/0001751.ts, /tmp/transcoding-temp/ac0a16f2d55f4f6cb2bd2fec9b814baa/0001752.ts, /tmp/transcoding-temp/ac0a16f2d55f4f6cb2bd2fec9b814baa/0001753.ts, /tmp/transcoding-temp/ac0a16f2d55f4f6cb2bd2fec9b814baa/0001754.ts, /tmp/transcoding-temp/ac0a16f2d55f4f6cb2bd2fec9b814baa/0001755.ts, /tmp/transcoding-temp/ac0a16f2d55f4f6cb2bd2fec9b814baa/0001756.ts, /tmp/transcoding-temp/ac0a16f2d55f4f6cb2bd2fec9b814baa/0001757.ts, /tmp/transcoding-temp/ac0a16f2d55f4f6cb2bd2fec9b814baa/0001758.ts, /tmp/transcoding-temp/ac0a16f2d55f4f6cb2bd2fec9b814baa/0001759.ts, /tmp/transcoding-temp/ac0a16f2d55f4f6cb2bd2fec9b814baa/0001760.ts, /tmp/transcoding-temp/ac0a16f2d55f4f6cb2bd2fec9b814baa/0001761.ts, /tmp/transcoding-temp/ac0a16f2d55f4f6cb2bd2fec9b814baa/0001762.ts, /tmp/transcoding-temp/ac0a16f2d55f4f6cb2bd2fec9b814baa/0001763.ts, /tmp/transcoding-temp/ac0a16f2d55f4f6cb2bd2fec9b814baa/0001764.ts, /tmp/transcoding-temp/ac0a16f2d55f4f6cb2bd2fec9b814baa/0001765.ts, /tmp/transcoding-temp/ac0a16f2d55f4f6cb2bd2fec9b814baa/0001766.ts, /tmp/transcoding-temp/ac0a16f2d55f4f6cb2bd2fec9b814baa/0001767.ts, /tmp/transcoding-temp/ac0a16f2d55f4f6cb2bd2fec9b814baa/0001768.ts, /tmp/transcoding-temp/ac0a16f2d55f4f6cb2bd2fec9b814baa/0001769.ts, /tmp/transcoding-temp/ac0a16f2d55f4f6cb2bd2fec9b814baa/0001770.ts, /tmp/transcoding-temp/ac0a16f2d55f4f6cb2bd2fec9b814baa/0001771.ts, /tmp/transcoding-temp/ac0a16f2d55f4f6cb2bd2fec9b814baa/0001772.ts, /tmp/transcoding-temp/ac0a16f2d55f4f6cb2bd2fec9b814baa/0001773.ts, /tmp/transcoding-temp/ac0a16f2d55f4f6cb2bd2fec9b814baa/0001774.ts, /tmp/transcoding-temp/ac0a16f2d55f4f6cb2bd2fec9b814baa/0001775.ts, /tmp/transcoding-temp/ac0a16f2d55f4f6cb2bd2fec9b814baa/0001776.ts, /tmp/transcoding-temp/ac0a16f2d55f4f6cb2bd2fec9b814baa/0001777.ts, /tmp/transcoding-temp/ac0a16f2d55f4f6cb2bd2fec9b814baa/0001778.ts, /tmp/transcoding-temp/ac0a16f2d55f4f6cb2bd2fec9b814baa/0001779.ts 2024-03-22 20:25:15.703 Info SharedHttpPipelineSource: SharedHttpPipelineSource is done streaming. 2024-03-22 20:25:16.732 Info MediaSourceManager: Live stream 06044cf0e6f93cdae5f285c9ecfaaeb4_01413a525b3a9622ce6fdf19f7dde354_native_b23ebc9442ec90ed5f591ef1683972b1_7cb44b1bbc7642c89815f8917ef56400 closed successfully I searched logs for that code and filtered by consumer count: Quote embyserver-63846493200.txt:2024-03-19 07:02:11.494 Info LiveTV: Live stream native_b23ebc9442ec90ed5f591ef1683972b1_7cb44b1bbc7642c89815f8917ef56400 consumer count is now 2 embyserver-63846493200.txt:2024-03-19 07:02:43.949 Info MediaSourceManager: Live stream native_b23ebc9442ec90ed5f591ef1683972b1_7cb44b1bbc7642c89815f8917ef56400 consumer count is now 1 embyserver-63846559361.txt:2024-03-20 07:10:15.524 Info LiveTV: Live stream native_b23ebc9442ec90ed5f591ef1683972b1_7cb44b1bbc7642c89815f8917ef56400 consumer count is now 2 embyserver-63846559361.txt:2024-03-20 07:10:47.710 Info MediaSourceManager: Live stream native_b23ebc9442ec90ed5f591ef1683972b1_7cb44b1bbc7642c89815f8917ef56400 consumer count is now 1 embyserver-63846559361.txt:2024-03-20 18:33:48.517 Info LiveTV: Live stream native_b23ebc9442ec90ed5f591ef1683972b1_7cb44b1bbc7642c89815f8917ef56400 consumer count is now 2 embyserver-63846559361.txt:2024-03-20 18:34:20.559 Info MediaSourceManager: Live stream native_b23ebc9442ec90ed5f591ef1683972b1_7cb44b1bbc7642c89815f8917ef56400 consumer count is now 1 embyserver-63846559361.txt:2024-03-20 19:18:37.537 Info LiveTV: Live stream native_b23ebc9442ec90ed5f591ef1683972b1_7cb44b1bbc7642c89815f8917ef56400 consumer count is now 2 embyserver-63846559361.txt:2024-03-20 19:19:07.472 Info MediaSourceManager: Live stream native_b23ebc9442ec90ed5f591ef1683972b1_7cb44b1bbc7642c89815f8917ef56400 consumer count is now 1 embyserver-63846559361.txt:2024-03-20 19:19:40.514 Info LiveTV: Live stream native_b23ebc9442ec90ed5f591ef1683972b1_7cb44b1bbc7642c89815f8917ef56400 consumer count is now 2 embyserver-63846559361.txt:2024-03-20 19:19:55.583 Info MediaSourceManager: Live stream native_b23ebc9442ec90ed5f591ef1683972b1_7cb44b1bbc7642c89815f8917ef56400 consumer count is now 1 embyserver-63846559361.txt:2024-03-20 19:22:40.536 Info MediaSourceManager: Live stream native_b23ebc9442ec90ed5f591ef1683972b1_7cb44b1bbc7642c89815f8917ef56400 consumer count is now 0 embyserver-63846576000.txt:2024-03-20 19:23:03.780 Info MediaSourceManager: Live stream native_b23ebc9442ec90ed5f591ef1683972b1_7cb44b1bbc7642c89815f8917ef56400 consumer count is now 0 embyserver-63846576000.txt:2024-03-20 20:03:18.022 Info MediaSourceManager: Live stream native_b23ebc9442ec90ed5f591ef1683972b1_7cb44b1bbc7642c89815f8917ef56400 consumer count is now 0 embyserver-63846662400.txt:2024-03-21 07:53:38.072 Info MediaSourceManager: Live stream native_b23ebc9442ec90ed5f591ef1683972b1_7cb44b1bbc7642c89815f8917ef56400 consumer count is now 0 embyserver.txt:2024-03-22 07:19:51.874 Info LiveTV: Live stream native_b23ebc9442ec90ed5f591ef1683972b1_7cb44b1bbc7642c89815f8917ef56400 consumer count is now 2 embyserver.txt:2024-03-22 08:29:15.145 Info MediaSourceManager: Live stream native_b23ebc9442ec90ed5f591ef1683972b1_7cb44b1bbc7642c89815f8917ef56400 consumer count is now 1 embyserver.txt:2024-03-22 20:25:15.702 Info MediaSourceManager: Live stream native_b23ebc9442ec90ed5f591ef1683972b1_7cb44b1bbc7642c89815f8917ef56400 consumer count is now 0
Luke 42241 Posted March 23, 2024 Posted March 23, 2024 Hi there, please attach the complete emby server and ffmpeg log files. thanks.
kmcmurtrie 3 Posted March 23, 2024 Author Posted March 23, 2024 I'll try to catch it faster next time so I can. The last event spanned several days so I don't know when it started. It only seems to happen with the Samsung TV.
kmcmurtrie 3 Posted March 24, 2024 Author Posted March 24, 2024 (edited) /transcoding-temp/3271916c8a4b4c0da8f9d55c5a8a59c1/ has two hours worth of .ts files and it's still going. I don't see ffmpeg running but EmbyServer is using 20% CPU. ffmpeg-transcode-3474199b-f72a-4874-81c1-710637b771ea_1.txt embyserver.txt embyserver-63846835199.txt Edited March 24, 2024 by kmcmurtrie
Luke 42241 Posted April 4, 2024 Posted April 4, 2024 OK what's happening is that somehow two streams are getting requested. Maybe the play button is getting triggered twice? Anyway, the second one never gets terminated by the server. We're looking into it. Thanks.
