amateurgod 33 Posted March 21, 2024 Posted March 21, 2024 I noticed earlier when some of my subtitles were slightly out of sync that the android TV app doesn't have an option to offset subtitles like every other emby app does
GrimReaper 4898 Posted March 21, 2024 Posted March 21, 2024 What type of subs? Only external .srts can be offset in AndroidTV app.
amateurgod 33 Posted March 21, 2024 Author Posted March 21, 2024 6 minutes ago, GrimReaper said: What type of subs? Only external .srts can be offset in AndroidTV app. Oh that's probably why, they are ASS I figured since they could be offset in the android phone app, it should be possible to do it in the TV one too
GrimReaper 4898 Posted March 21, 2024 Posted March 21, 2024 5 minutes ago, amateurgod said: Oh that's probably why, they are ASS I figured since they could be offset in the android phone app, it should be possible to do it in the TV one too You can download (if available in your store/for your device) or sideload standard Android app and see how does that compare. https://emby.media/emby-for-android.html
ebr 16337 Posted March 21, 2024 Posted March 21, 2024 It has the same support. The subs must be external though.
Luke 42244 Posted May 9, 2024 Posted May 9, 2024 @amateurgod Hi. Can you try searching for our standard android app (Just "Emby" on Amazon and "Emby for Android on Google) on the same device's app store and see how that compares? Thanks. 1
