sross44 434 Posted March 21, 2024 Posted March 21, 2024 This is all probably user error on my end. I was running Emby next gen no problems forever. Lately it seems that when Kodi starts and Emby syncs to do the updates, it takes forever. I mean it can take hours to sync any updates with Kodi. I have Kodi Sync installed. I've tried both the beta version and the regular version of Emby next gen. I've even reinstalled Kodi and the initial scan is super quick as always. Probably done in less than 2-3 minutes. Then a day or so later, bam.... it's back to taking forever to sync. Any thoughts? 1
quickmic 1709 Posted March 21, 2024 Posted March 21, 2024 (edited) 5 hours ago, sross44 said: This is all probably user error on my end. I was running Emby next gen no problems forever. Lately it seems that when Kodi starts and Emby syncs to do the updates, it takes forever. I mean it can take hours to sync any updates with Kodi. I have Kodi Sync installed. I've tried both the beta version and the regular version of Emby next gen. I've even reinstalled Kodi and the initial scan is super quick as always. Probably done in less than 2-3 minutes. Then a day or so later, bam.... it's back to taking forever to sync. Any thoughts? Well, I need a kodi.log (probably a debug log) for review. I have performance issues with musicalbum sync since, I guess it was 4.8.X beta 48. Anyway, I don't think you are affected by this issue cause this is a init sync problem. Other than that, no performance issues on my side. I could imagine, your Emby libraries was completely "rebuild" for some reason, ergo the plugin syncs every content on start. I've seen this by other users when they used scripts to modify content not even knowing, that a modification (e.g. nfo files etc) results in "modified" content (after a Emby library scan). Edited March 21, 2024 by quickmic
sross44 434 Posted March 21, 2024 Author Posted March 21, 2024 Here's a debug log as far as I can tell. It's getting pretty frustrating because it keeps happening. Hopefully we can figure it out! kodi.log 1
quickmic 1709 Posted March 21, 2024 Posted March 21, 2024 Thanks. First sight, it's related to BoxSet updates. I will review it...
quickmic 1709 Posted March 21, 2024 Posted March 21, 2024 I checked the log again. I can see the Emby server scan was running. Is this just a coincidence? As mentioned, there are endless Boxsets syncs but no issue found so far. Also I performed several test with Boxsets, but could not trigger the issue. Any pattern?
sross44 434 Posted March 21, 2024 Author Posted March 21, 2024 No.... it just happens after I set it up and a day or two later it stalls out. Then every time I try to run Kodi it just goes forever. It's strange behavior to say the least.
quickmic 1709 Posted March 21, 2024 Posted March 21, 2024 Does it really never stop or just takes very long time? Please send me another log when this happens again (just a regular log) and probably the kodi.old.log The only reason this could happen, when the sync was incomplete/crashed. The uploaded log doesn't show any crashes or bugs. Probably it never came to that point the issue appears. -> the sync was not completed in the log.
sross44 434 Posted March 21, 2024 Author Posted March 21, 2024 Honestly I've never let it finish.... it's gone on for over an hour or two and I cancel out. I'll let it try completing. Interesting enough it happens even when I'm on my home server or have one setup at my fiance's house remotely for access to Emby as well. I'll try both again and get you logs. 1
quickmic 1709 Posted March 21, 2024 Posted March 21, 2024 Even if the sync is completed, but takes unusual long time please send me the log. The issue could be already triggered and if so, each Kodi restart could double the sync time till the issue appears again. 1
BMan1 5 Posted March 23, 2024 Posted March 23, 2024 I'm having similar issues. Setup the server a few months ago. Htpc runs the emby server, and hosts the files. Running kodi on the htpc it loads ok. Done on under a minute. Not sure why it has to load everything every time. Trying to run it from the kodi Android app on the TV and it takes forever! The TV was a fresh install and the first load was fine. Now it loads about 1% a minute. TV hits screen saver and then kodi stops so can never get it to finish.
BMan1 5 Posted March 24, 2024 Posted March 24, 2024 13 hours ago, quickmic said: logs Not sure how to grab logs? I tried leaving it run to finish and after 4 hours it was at like 80% Ended up cancelling it Have deleted all media sources and factory reset. Re added libraries and has re-added the media sources and is loading all media at the speed the other device loads. About 5 mins to load the whole library. Exited and re opened and scans in 20 seconds.
Luke 42237 Posted March 25, 2024 Posted March 25, 2024 On 3/23/2024 at 9:10 PM, BMan1 said: Not sure how to grab logs? I tried leaving it run to finish and after 4 hours it was at like 80% Ended up cancelling it Have deleted all media sources and factory reset. Re added libraries and has re-added the media sources and is loading all media at the speed the other device loads. About 5 mins to load the whole library. Exited and re opened and scans in 20 seconds. @BMan1I think he means the Kodi log file: https://kodi.wiki/view/Log_file 1 1
sross44 434 Posted April 4, 2024 Author Posted April 4, 2024 I haven't been able to check in a while. I'll get in today or tomorrow with .12 and check on it.
Vvilams 2 Posted April 5, 2024 Posted April 5, 2024 I'm on 9.4.19 and have the same issue. It will run for days without moving. kodi.log 1
Cepheus_King 3 Posted April 6, 2024 Posted April 6, 2024 10.0.12 2024-04-06 09:49:42.312 T:3888 error <general>: Exception ignored in thread started by 2024-04-06 09:49:42.313 T:3888 error <general>: : 2024-04-06 09:49:42.313 T:3888 error <general>: <bound method Library.KodiStartSync of <database.library.Library object at 0xc1b747e8>> 2024-04-06 09:49:42.313 T:3888 error <general>: 2024-04-06 09:49:42.317 T:3888 error <general>: Traceback (most recent call last): 2024-04-06 09:49:42.317 T:3888 error <general>: File "/storage/.kodi/addons/plugin.video.emby-next-gen/database/library.py", line 160, in KodiStartSync 2024-04-06 09:49:42.320 T:3888 error <general>: 2024-04-06 09:49:42.320 T:3888 error <general>: self.RunJobs() 2024-04-06 09:49:42.320 T:3888 error <general>: 2024-04-06 09:49:42.321 T:3888 error <general>: File "/storage/.kodi/addons/plugin.video.emby-next-gen/database/library.py", line 667, in RunJobs 2024-04-06 09:49:42.324 T:3888 error <general>: 2024-04-06 09:49:42.325 T:3888 error <general>: if self.worker_update(): 2024-04-06 09:49:42.325 T:3888 error <general>: 2024-04-06 09:49:42.325 T:3888 error <general>: 2024-04-06 09:49:42.325 T:3888 info <general>: Skipped 6 duplicate messages.. 2024-04-06 09:49:42.325 T:3888 error <general>: ^ 2024-04-06 09:49:42.326 T:3888 info <general>: Skipped 19 duplicate messages.. 2024-04-06 09:49:42.326 T:3888 error <general>: 2024-04-06 09:49:42.326 T:3888 error <general>: File "/storage/.kodi/addons/plugin.video.emby-next-gen/database/library.py", line 356, in worker_update 2024-04-06 09:49:42.327 T:3888 error <general>: 2024-04-06 09:49:42.328 T:3888 error <general>: Continue, SQLs = self.ItemOps(int(index / RecordsPercent), index, Item, SQLs, WorkerName, KodiDBs, ProgressBar, StartSync) 2024-04-06 09:49:42.328 T:3888 error <general>: 2024-04-06 09:49:42.328 T:3888 error <general>: 2024-04-06 09:49:42.329 T:3888 info <general>: Skipped 20 duplicate messages.. 2024-04-06 09:49:42.329 T:3888 error <general>: ^ 2024-04-06 09:49:42.330 T:3888 info <general>: Skipped 104 duplicate messages.. 2024-04-06 09:49:42.330 T:3888 error <general>: 2024-04-06 09:49:42.330 T:3888 error <general>: File "/storage/.kodi/addons/plugin.video.emby-next-gen/database/library.py", line 580, in ItemOps 2024-04-06 09:49:42.332 T:3888 error <general>: 2024-04-06 09:49:42.333 T:3888 error <general>: Ret = self.ContentObject.change(Item) 2024-04-06 09:49:42.333 T:3888 error <general>: 2024-04-06 09:49:42.333 T:3888 error <general>: 2024-04-06 09:49:42.333 T:3888 info <general>: Skipped 9 duplicate messages.. 2024-04-06 09:49:42.333 T:3888 error <general>: ^ 2024-04-06 09:49:42.334 T:3888 info <general>: Skipped 30 duplicate messages.. 2024-04-06 09:49:42.334 T:3888 error <general>: 2024-04-06 09:49:42.334 T:3888 error <general>: File "/storage/.kodi/addons/plugin.video.emby-next-gen/core/season.py", line 48, in change 2024-04-06 09:49:42.335 T:3888 error <general>: 2024-04-06 09:49:42.336 T:3888 error <general>: self.SQLs["video"].update_season(item['KodiParentId'], item['IndexNumber'], item['Name'], item['KodiItemId']) 2024-04-06 09:49:42.336 T:3888 error <general>: 2024-04-06 09:49:42.336 T:3888 error <general>: File "/storage/.kodi/addons/plugin.video.emby-next-gen/database/video_db.py", line 396, in update_season 2024-04-06 09:49:42.339 T:3888 error <general>: 2024-04-06 09:49:42.339 T:3888 error <general>: Name = self.cursor.fetchone()[0] 2024-04-06 09:49:42.339 T:3888 error <general>: 2024-04-06 09:49:42.339 T:3888 error <general>: 2024-04-06 09:49:42.339 T:3888 info <general>: Skipped 10 duplicate messages.. 2024-04-06 09:49:42.339 T:3888 error <general>: ~ 2024-04-06 09:49:42.339 T:3888 info <general>: Skipped 21 duplicate messages.. 2024-04-06 09:49:42.339 T:3888 error <general>: ^ 2024-04-06 09:49:42.340 T:3888 info <general>: Skipped 2 duplicate messages.. 2024-04-06 09:49:42.340 T:3888 error <general>: 2024-04-06 09:49:42.340 T:3888 error <general>: TypeError 2024-04-06 09:49:42.340 T:3888 error <general>: : 2024-04-06 09:49:42.340 T:3888 error <general>: 'NoneType' object is not subscriptable 2024-04-06 09:49:42.340 T:3888 error <general>: 2024-04-06 11:24:50.526 T:3887 info <general>: Skipped 9 duplicate messages.. 2024-04-06 11:24:50.526 T:3887 info <general>: EMBY.database.library: open_EmbyDBRW waiting: updated 2024-04-06 11:25:00.534 T:3887 info <general>: Skipped 9 duplicate messages.. 2024-04-06 11:25:00.534 T:3887 info <general>: EMBY.database.library: open_EmbyDBRW waiting: updated 2024-04-06 11:25:10.542 T:3887 info <general>: Skipped 9 duplicate messages.. 2024-04-06 11:25:10.542 T:3887 info <general>: EMBY.database.library: open_EmbyDBRW waiting: updated 2024-04-06 11:25:20.548 T:3887 info <general>: Skipped 9 duplicate messages.. 2024-04-06 11:25:20.548 T:3887 info <general>: EMBY.database.library: open_EmbyDBRW waiting: updated 2024-04-06 11:25:30.552 T:3887 info <general>: Skipped 9 duplicate messages.. 2024-04-06 11:25:30.552 T:3887 info <general>: EMBY.database.library: open_EmbyDBRW waiting: updated 2024-04-06 11:25:40.557 T:3887 info <general>: Skipped 9 duplicate messages.. 2024-04-06 11:25:40.557 T:3887 info <general>: EMBY.database.library: open_EmbyDBRW waiting: updated 2024-04-06 11:25:50.563 T:3887 info <general>: Skipped 9 duplicate messages.. 2024-04-06 11:25:50.563 T:3887 info <general>: EMBY.database.library: open_EmbyDBRW waiting: updated 2024-04-06 11:26:00.581 T:3887 info <general>: Skipped 9 duplicate messages.. 2024-04-06 11:26:00.581 T:3887 info <general>: EMBY.database.library: open_EmbyDBRW waiting: updated 2024-04-06 11:26:10.589 T:3887 info <general>: Skipped 9 duplicate messages.. 2024-04-06 11:26:10.589 T:3887 info <general>: EMBY.database.library: open_EmbyDBRW waiting: updated 2024-04-06 11:26:20.605 T:3887 info <general>: Skipped 9 duplicate messages.. 2024-04-06 11:26:20.605 T:3887 info <general>: EMBY.database.library: open_EmbyDBRW waiting: updated 2024-04-06 11:26:30.612 T:3887 info <general>: Skipped 9 duplicate messages.. 2024-04-06 11:26:30.612 T:3887 info <general>: EMBY.database.library: open_EmbyDBRW waiting: updated 2024-04-06 11:26:40.618 T:3887 info <general>: Skipped 9 duplicate messages.. 2024-04-06 11:26:40.618 T:3887 info <general>: EMBY.database.library: open_EmbyDBRW waiting: updated 2024-04-06 11:26:50.625 T:3887 info <general>: Skipped 9 duplicate messages.. 2024-04-06 11:26:50.625 T:3887 info <general>: EMBY.database.library: open_EmbyDBRW waiting: updated 2024-04-06 11:27:00.635 T:3887 info <general>: Skipped 9 duplicate messages.. 2024-04-06 11:27:00.635 T:3887 info <general>: EMBY.database.library: open_EmbyDBRW waiting: updated 2024-04-06 11:27:10.643 T:3887 info <general>: Skipped 9 duplicate messages.. 2024-04-06 11:27:10.643 T:3887 info <general>: EMBY.database.library: open_EmbyDBRW waiting: updated 2024-04-06 11:27:20.649 T:3887 info <general>: Skipped 9 duplicate messages.. 2024-04-06 11:27:20.649 T:3887 info <general>: EMBY.database.library: open_EmbyDBRW waiting: updated 2024-04-06 11:27:30.655 T:3887 info <general>: Skipped 9 duplicate messages.. 2024-04-06 11:27:30.655 T:3887 info <general>: EMBY.database.library: open_EmbyDBRW waiting: updated 2024-04-06 11:27:40.668 T:3887 info <general>: Skipped 9 duplicate messages.. 2024-04-06 11:27:40.668 T:3887 info <general>: EMBY.database.library: open_EmbyDBRW waiting: updated 2024-04-06 11:27:50.681 T:3887 info <general>: Skipped 9 duplicate messages.. 2024-04-06 11:27:50.681 T:3887 info <general>: EMBY.database.library: open_EmbyDBRW waiting: updated 2024-04-06 11:28:00.686 T:3887 info <general>: Skipped 9 duplicate messages.. 2024-04-06 11:28:00.686 T:3887 info <general>: EMBY.database.library: open_EmbyDBRW waiting: updated 2024-04-06 11:28:10.692 T:3887 info <general>: Skipped 9 duplicate messages.. 2024-04-06 11:28:10.692 T:3887 info <general>: EMBY.database.library: open_EmbyDBRW waiting: updated 2024-04-06 11:28:20.704 T:3887 info <general>: Skipped 9 duplicate messages.. 2024-04-06 11:28:20.704 T:3887 info <general>: EMBY.database.library: open_EmbyDBRW waiting: updated 2024-04-06 11:28:30.712 T:3887 info <general>: Skipped 9 duplicate messages.. 2024-04-06 11:28:30.712 T:3887 info <general>: EMBY.database.library: open_EmbyDBRW waiting: updated 2024-04-06 11:28:40.723 T:3887 info <general>: Skipped 9 duplicate messages.. 2024-04-06 11:28:40.723 T:3887 info <general>: EMBY.database.library: open_EmbyDBRW waiting: updated 2024-04-06 11:28:50.727 T:3887 info <general>: Skipped 9 duplicate messages.. 2024-04-06 11:28:50.727 T:3887 info <general>: EMBY.database.library: open_EmbyDBRW waiting: updated 2024-04-06 11:29:00.734 T:3887 info <general>: Skipped 9 duplicate messages.. 2024-04-06 11:29:00.734 T:3887 info <general>: EMBY.database.library: open_EmbyDBRW waiting: updated 2024-04-06 11:29:10.750 T:3887 info <general>: Skipped 9 duplicate messages.. 2024-04-06 11:29:10.750 T:3887 info <general>: EMBY.database.library: open_EmbyDBRW waiting: updated 2024-04-06 11:29:20.754 T:3887 info <general>: Skipped 9 duplicate messages.. 2024-04-06 11:29:20.754 T:3887 info <general>: EMBY.database.library: open_EmbyDBRW waiting: updated 2024-04-06 11:29:30.759 T:3887 info <general>: Skipped 9 duplicate messages.. 2024-04-06 11:29:30.759 T:3887 info <general>: EMBY.database.library: open_EmbyDBRW waiting: updated 2024-04-06 11:29:40.766 T:3887 info <general>: Skipped 9 duplicate messages.. 2024-04-06 11:29:40.766 T:3887 info <general>: EMBY.database.library: open_EmbyDBRW waiting: updated 2024-04-06 11:29:50.773 T:3887 info <general>: Skipped 9 duplicate messages.. 2024-04-06 11:29:50.773 T:3887 info <general>: EMBY.database.library: open_EmbyDBRW waiting: updated 2024-04-06 11:30:00.779 T:3887 info <general>: Skipped 9 duplicate messages.. 2024-04-06 11:30:00.779 T:3887 info <general>: EMBY.database.library: open_EmbyDBRW waiting: updated 2024-04-06 11:30:10.785 T:3887 info <general>: Skipped 9 duplicate messages.. 2024-04-06 11:30:10.785 T:3887 info <general>: EMBY.database.library: open_EmbyDBRW waiting: updated 2024-04-06 11:30:20.789 T:3887 info <general>: Skipped 9 duplicate messages.. 2024-04-06 11:30:20.789 T:3887 info <general>: EMBY.database.library: open_EmbyDBRW waiting: updated 2024-04-06 11:30:30.793 T:3887 info <general>: Skipped 9 duplicate messages.. 2024-04-06 11:30:30.793 T:3887 info <general>: EMBY.database.library: open_EmbyDBRW waiting: updated 1
quickmic 1709 Posted April 6, 2024 Posted April 6, 2024 (edited) 8 hours ago, Vvilams said: I'm on 9.4.19 and have the same issue. It will run for days without moving. kodi.log 1.08 MB · 0 downloads This issue should be solved by latest 10.X version or on 9.X by restarting Kodi. Actually your Emby server reported "busy" and under special circumstances, the (un)busy/finished was never detected by the plugin. If a Kodi restart doesn't solve the problem, let me know. Edited April 6, 2024 by quickmic
quickmic 1709 Posted April 6, 2024 Posted April 6, 2024 (edited) 3 hours ago, Cepheus_King said: 10.0.12 2024-04-06 09:49:42.312 T:3888 error <general>: Exception ignored in thread started by 2024-04-06 09:49:42.313 T:3888 error <general>: : 2024-04-06 09:49:42.313 T:3888 error <general>: <bound method Library.KodiStartSync of <database.library.Library object at 0xc1b747e8>> 2024-04-06 09:49:42.313 T:3888 error <general>: 2024-04-06 09:49:42.317 T:3888 error <general>: Traceback (most recent call last): 2024-04-06 09:49:42.317 T:3888 error <general>: File "/storage/.kodi/addons/plugin.video.emby-next-gen/database/library.py", line 160, in KodiStartSync 2024-04-06 09:49:42.320 T:3888 error <general>: 2024-04-06 09:49:42.320 T:3888 error <general>: self.RunJobs() 2024-04-06 09:49:42.320 T:3888 error <general>: 2024-04-06 09:49:42.321 T:3888 error <general>: File "/storage/.kodi/addons/plugin.video.emby-next-gen/database/library.py", line 667, in RunJobs 2024-04-06 09:49:42.324 T:3888 error <general>: 2024-04-06 09:49:42.325 T:3888 error <general>: if self.worker_update(): 2024-04-06 09:49:42.325 T:3888 error <general>: 2024-04-06 09:49:42.325 T:3888 error <general>: 2024-04-06 09:49:42.325 T:3888 info <general>: Skipped 6 duplicate messages.. 2024-04-06 09:49:42.325 T:3888 error <general>: ^ 2024-04-06 09:49:42.326 T:3888 info <general>: Skipped 19 duplicate messages.. 2024-04-06 09:49:42.326 T:3888 error <general>: 2024-04-06 09:49:42.326 T:3888 error <general>: File "/storage/.kodi/addons/plugin.video.emby-next-gen/database/library.py", line 356, in worker_update 2024-04-06 09:49:42.327 T:3888 error <general>: 2024-04-06 09:49:42.328 T:3888 error <general>: Continue, SQLs = self.ItemOps(int(index / RecordsPercent), index, Item, SQLs, WorkerName, KodiDBs, ProgressBar, StartSync) 2024-04-06 09:49:42.328 T:3888 error <general>: 2024-04-06 09:49:42.328 T:3888 error <general>: 2024-04-06 09:49:42.329 T:3888 info <general>: Skipped 20 duplicate messages.. 2024-04-06 09:49:42.329 T:3888 error <general>: ^ 2024-04-06 09:49:42.330 T:3888 info <general>: Skipped 104 duplicate messages.. 2024-04-06 09:49:42.330 T:3888 error <general>: 2024-04-06 09:49:42.330 T:3888 error <general>: File "/storage/.kodi/addons/plugin.video.emby-next-gen/database/library.py", line 580, in ItemOps 2024-04-06 09:49:42.332 T:3888 error <general>: 2024-04-06 09:49:42.333 T:3888 error <general>: Ret = self.ContentObject.change(Item) 2024-04-06 09:49:42.333 T:3888 error <general>: 2024-04-06 09:49:42.333 T:3888 error <general>: 2024-04-06 09:49:42.333 T:3888 info <general>: Skipped 9 duplicate messages.. 2024-04-06 09:49:42.333 T:3888 error <general>: ^ 2024-04-06 09:49:42.334 T:3888 info <general>: Skipped 30 duplicate messages.. 2024-04-06 09:49:42.334 T:3888 error <general>: 2024-04-06 09:49:42.334 T:3888 error <general>: File "/storage/.kodi/addons/plugin.video.emby-next-gen/core/season.py", line 48, in change 2024-04-06 09:49:42.335 T:3888 error <general>: 2024-04-06 09:49:42.336 T:3888 error <general>: self.SQLs["video"].update_season(item['KodiParentId'], item['IndexNumber'], item['Name'], item['KodiItemId']) 2024-04-06 09:49:42.336 T:3888 error <general>: 2024-04-06 09:49:42.336 T:3888 error <general>: File "/storage/.kodi/addons/plugin.video.emby-next-gen/database/video_db.py", line 396, in update_season 2024-04-06 09:49:42.339 T:3888 error <general>: 2024-04-06 09:49:42.339 T:3888 error <general>: Name = self.cursor.fetchone()[0] 2024-04-06 09:49:42.339 T:3888 error <general>: 2024-04-06 09:49:42.339 T:3888 error <general>: 2024-04-06 09:49:42.339 T:3888 info <general>: Skipped 10 duplicate messages.. 2024-04-06 09:49:42.339 T:3888 error <general>: ~ 2024-04-06 09:49:42.339 T:3888 info <general>: Skipped 21 duplicate messages.. 2024-04-06 09:49:42.339 T:3888 error <general>: ^ 2024-04-06 09:49:42.340 T:3888 info <general>: Skipped 2 duplicate messages.. 2024-04-06 09:49:42.340 T:3888 error <general>: 2024-04-06 09:49:42.340 T:3888 error <general>: TypeError 2024-04-06 09:49:42.340 T:3888 error <general>: : 2024-04-06 09:49:42.340 T:3888 error <general>: 'NoneType' object is not subscriptable 2024-04-06 09:49:42.340 T:3888 error <general>: 2024-04-06 11:24:50.526 T:3887 info <general>: Skipped 9 duplicate messages.. 2024-04-06 11:24:50.526 T:3887 info <general>: EMBY.database.library: open_EmbyDBRW waiting: updated 2024-04-06 11:25:00.534 T:3887 info <general>: Skipped 9 duplicate messages.. 2024-04-06 11:25:00.534 T:3887 info <general>: EMBY.database.library: open_EmbyDBRW waiting: updated 2024-04-06 11:25:10.542 T:3887 info <general>: Skipped 9 duplicate messages.. 2024-04-06 11:25:10.542 T:3887 info <general>: EMBY.database.library: open_EmbyDBRW waiting: updated 2024-04-06 11:25:20.548 T:3887 info <general>: Skipped 9 duplicate messages.. 2024-04-06 11:25:20.548 T:3887 info <general>: EMBY.database.library: open_EmbyDBRW waiting: updated 2024-04-06 11:25:30.552 T:3887 info <general>: Skipped 9 duplicate messages.. 2024-04-06 11:25:30.552 T:3887 info <general>: EMBY.database.library: open_EmbyDBRW waiting: updated 2024-04-06 11:25:40.557 T:3887 info <general>: Skipped 9 duplicate messages.. 2024-04-06 11:25:40.557 T:3887 info <general>: EMBY.database.library: open_EmbyDBRW waiting: updated 2024-04-06 11:25:50.563 T:3887 info <general>: Skipped 9 duplicate messages.. 2024-04-06 11:25:50.563 T:3887 info <general>: EMBY.database.library: open_EmbyDBRW waiting: updated 2024-04-06 11:26:00.581 T:3887 info <general>: Skipped 9 duplicate messages.. 2024-04-06 11:26:00.581 T:3887 info <general>: EMBY.database.library: open_EmbyDBRW waiting: updated 2024-04-06 11:26:10.589 T:3887 info <general>: Skipped 9 duplicate messages.. 2024-04-06 11:26:10.589 T:3887 info <general>: EMBY.database.library: open_EmbyDBRW waiting: updated 2024-04-06 11:26:20.605 T:3887 info <general>: Skipped 9 duplicate messages.. 2024-04-06 11:26:20.605 T:3887 info <general>: EMBY.database.library: open_EmbyDBRW waiting: updated 2024-04-06 11:26:30.612 T:3887 info <general>: Skipped 9 duplicate messages.. 2024-04-06 11:26:30.612 T:3887 info <general>: EMBY.database.library: open_EmbyDBRW waiting: updated 2024-04-06 11:26:40.618 T:3887 info <general>: Skipped 9 duplicate messages.. 2024-04-06 11:26:40.618 T:3887 info <general>: EMBY.database.library: open_EmbyDBRW waiting: updated 2024-04-06 11:26:50.625 T:3887 info <general>: Skipped 9 duplicate messages.. 2024-04-06 11:26:50.625 T:3887 info <general>: EMBY.database.library: open_EmbyDBRW waiting: updated 2024-04-06 11:27:00.635 T:3887 info <general>: Skipped 9 duplicate messages.. 2024-04-06 11:27:00.635 T:3887 info <general>: EMBY.database.library: open_EmbyDBRW waiting: updated 2024-04-06 11:27:10.643 T:3887 info <general>: Skipped 9 duplicate messages.. 2024-04-06 11:27:10.643 T:3887 info <general>: EMBY.database.library: open_EmbyDBRW waiting: updated 2024-04-06 11:27:20.649 T:3887 info <general>: Skipped 9 duplicate messages.. 2024-04-06 11:27:20.649 T:3887 info <general>: EMBY.database.library: open_EmbyDBRW waiting: updated 2024-04-06 11:27:30.655 T:3887 info <general>: Skipped 9 duplicate messages.. 2024-04-06 11:27:30.655 T:3887 info <general>: EMBY.database.library: open_EmbyDBRW waiting: updated 2024-04-06 11:27:40.668 T:3887 info <general>: Skipped 9 duplicate messages.. 2024-04-06 11:27:40.668 T:3887 info <general>: EMBY.database.library: open_EmbyDBRW waiting: updated 2024-04-06 11:27:50.681 T:3887 info <general>: Skipped 9 duplicate messages.. 2024-04-06 11:27:50.681 T:3887 info <general>: EMBY.database.library: open_EmbyDBRW waiting: updated 2024-04-06 11:28:00.686 T:3887 info <general>: Skipped 9 duplicate messages.. 2024-04-06 11:28:00.686 T:3887 info <general>: EMBY.database.library: open_EmbyDBRW waiting: updated 2024-04-06 11:28:10.692 T:3887 info <general>: Skipped 9 duplicate messages.. 2024-04-06 11:28:10.692 T:3887 info <general>: EMBY.database.library: open_EmbyDBRW waiting: updated 2024-04-06 11:28:20.704 T:3887 info <general>: Skipped 9 duplicate messages.. 2024-04-06 11:28:20.704 T:3887 info <general>: EMBY.database.library: open_EmbyDBRW waiting: updated 2024-04-06 11:28:30.712 T:3887 info <general>: Skipped 9 duplicate messages.. 2024-04-06 11:28:30.712 T:3887 info <general>: EMBY.database.library: open_EmbyDBRW waiting: updated 2024-04-06 11:28:40.723 T:3887 info <general>: Skipped 9 duplicate messages.. 2024-04-06 11:28:40.723 T:3887 info <general>: EMBY.database.library: open_EmbyDBRW waiting: updated 2024-04-06 11:28:50.727 T:3887 info <general>: Skipped 9 duplicate messages.. 2024-04-06 11:28:50.727 T:3887 info <general>: EMBY.database.library: open_EmbyDBRW waiting: updated 2024-04-06 11:29:00.734 T:3887 info <general>: Skipped 9 duplicate messages.. 2024-04-06 11:29:00.734 T:3887 info <general>: EMBY.database.library: open_EmbyDBRW waiting: updated 2024-04-06 11:29:10.750 T:3887 info <general>: Skipped 9 duplicate messages.. 2024-04-06 11:29:10.750 T:3887 info <general>: EMBY.database.library: open_EmbyDBRW waiting: updated 2024-04-06 11:29:20.754 T:3887 info <general>: Skipped 9 duplicate messages.. 2024-04-06 11:29:20.754 T:3887 info <general>: EMBY.database.library: open_EmbyDBRW waiting: updated 2024-04-06 11:29:30.759 T:3887 info <general>: Skipped 9 duplicate messages.. 2024-04-06 11:29:30.759 T:3887 info <general>: EMBY.database.library: open_EmbyDBRW waiting: updated 2024-04-06 11:29:40.766 T:3887 info <general>: Skipped 9 duplicate messages.. 2024-04-06 11:29:40.766 T:3887 info <general>: EMBY.database.library: open_EmbyDBRW waiting: updated 2024-04-06 11:29:50.773 T:3887 info <general>: Skipped 9 duplicate messages.. 2024-04-06 11:29:50.773 T:3887 info <general>: EMBY.database.library: open_EmbyDBRW waiting: updated 2024-04-06 11:30:00.779 T:3887 info <general>: Skipped 9 duplicate messages.. 2024-04-06 11:30:00.779 T:3887 info <general>: EMBY.database.library: open_EmbyDBRW waiting: updated 2024-04-06 11:30:10.785 T:3887 info <general>: Skipped 9 duplicate messages.. 2024-04-06 11:30:10.785 T:3887 info <general>: EMBY.database.library: open_EmbyDBRW waiting: updated 2024-04-06 11:30:20.789 T:3887 info <general>: Skipped 9 duplicate messages.. 2024-04-06 11:30:20.789 T:3887 info <general>: EMBY.database.library: open_EmbyDBRW waiting: updated 2024-04-06 11:30:30.793 T:3887 info <general>: Skipped 9 duplicate messages.. 2024-04-06 11:30:30.793 T:3887 info <general>: EMBY.database.library: open_EmbyDBRW waiting: updated That's a crash, I'll check it. Thanks for reporting. Please upload the complete kodi.log if you still have it. I could simply intercept the crash, but actually this shouldn't happen at all. Something unusual with season updates had triggered the issue. Edited April 6, 2024 by quickmic
Vvilams 2 Posted April 8, 2024 Posted April 8, 2024 On 4/6/2024 at 2:37 AM, quickmic said: This issue should be solved by latest 10.X version or on 9.X by restarting Kodi. Actually your Emby server reported "busy" and under special circumstances, the (un)busy/finished was never detected by the plugin. If a Kodi restart doesn't solve the problem, let me know. A restart didn't solve it but at least it's not totally stalled, just moving very slowly. I did upgrade to the latest version of Kodi but didn't see 10.X on the official repository yet. Is there something I should be looking at on the server side? The server version is 4.8.3.0 but now that I'm looking at the server, it is showing a running task of 'Scan Media Library' at about 91% and not moving. The server was restarted 2 days ago.
quickmic 1709 Posted April 12, 2024 Posted April 12, 2024 On 4/6/2024 at 5:30 AM, Cepheus_King said: 10.0.12 2024-04-06 09:49:42.312 T:3888 error <general>: Exception ignored in thread started by 2024-04-06 09:49:42.313 T:3888 error <general>: : 2024-04-06 09:49:42.313 T:3888 error <general>: <bound method Library.KodiStartSync of <database.library.Library object at 0xc1b747e8>> 2024-04-06 09:49:42.313 T:3888 error <general>: 2024-04-06 09:49:42.317 T:3888 error <general>: Traceback (most recent call last): 2024-04-06 09:49:42.317 T:3888 error <general>: File "/storage/.kodi/addons/plugin.video.emby-next-gen/database/library.py", line 160, in KodiStartSync 2024-04-06 09:49:42.320 T:3888 error <general>: 2024-04-06 09:49:42.320 T:3888 error <general>: self.RunJobs() 2024-04-06 09:49:42.320 T:3888 error <general>: 2024-04-06 09:49:42.321 T:3888 error <general>: File "/storage/.kodi/addons/plugin.video.emby-next-gen/database/library.py", line 667, in RunJobs 2024-04-06 09:49:42.324 T:3888 error <general>: 2024-04-06 09:49:42.325 T:3888 error <general>: if self.worker_update(): 2024-04-06 09:49:42.325 T:3888 error <general>: 2024-04-06 09:49:42.325 T:3888 error <general>: 2024-04-06 09:49:42.325 T:3888 info <general>: Skipped 6 duplicate messages.. 2024-04-06 09:49:42.325 T:3888 error <general>: ^ 2024-04-06 09:49:42.326 T:3888 info <general>: Skipped 19 duplicate messages.. 2024-04-06 09:49:42.326 T:3888 error <general>: 2024-04-06 09:49:42.326 T:3888 error <general>: File "/storage/.kodi/addons/plugin.video.emby-next-gen/database/library.py", line 356, in worker_update 2024-04-06 09:49:42.327 T:3888 error <general>: 2024-04-06 09:49:42.328 T:3888 error <general>: Continue, SQLs = self.ItemOps(int(index / RecordsPercent), index, Item, SQLs, WorkerName, KodiDBs, ProgressBar, StartSync) 2024-04-06 09:49:42.328 T:3888 error <general>: 2024-04-06 09:49:42.328 T:3888 error <general>: 2024-04-06 09:49:42.329 T:3888 info <general>: Skipped 20 duplicate messages.. 2024-04-06 09:49:42.329 T:3888 error <general>: ^ 2024-04-06 09:49:42.330 T:3888 info <general>: Skipped 104 duplicate messages.. 2024-04-06 09:49:42.330 T:3888 error <general>: 2024-04-06 09:49:42.330 T:3888 error <general>: File "/storage/.kodi/addons/plugin.video.emby-next-gen/database/library.py", line 580, in ItemOps 2024-04-06 09:49:42.332 T:3888 error <general>: 2024-04-06 09:49:42.333 T:3888 error <general>: Ret = self.ContentObject.change(Item) 2024-04-06 09:49:42.333 T:3888 error <general>: 2024-04-06 09:49:42.333 T:3888 error <general>: 2024-04-06 09:49:42.333 T:3888 info <general>: Skipped 9 duplicate messages.. 2024-04-06 09:49:42.333 T:3888 error <general>: ^ 2024-04-06 09:49:42.334 T:3888 info <general>: Skipped 30 duplicate messages.. 2024-04-06 09:49:42.334 T:3888 error <general>: 2024-04-06 09:49:42.334 T:3888 error <general>: File "/storage/.kodi/addons/plugin.video.emby-next-gen/core/season.py", line 48, in change 2024-04-06 09:49:42.335 T:3888 error <general>: 2024-04-06 09:49:42.336 T:3888 error <general>: self.SQLs["video"].update_season(item['KodiParentId'], item['IndexNumber'], item['Name'], item['KodiItemId']) 2024-04-06 09:49:42.336 T:3888 error <general>: 2024-04-06 09:49:42.336 T:3888 error <general>: File "/storage/.kodi/addons/plugin.video.emby-next-gen/database/video_db.py", line 396, in update_season 2024-04-06 09:49:42.339 T:3888 error <general>: 2024-04-06 09:49:42.339 T:3888 error <general>: Name = self.cursor.fetchone()[0] 2024-04-06 09:49:42.339 T:3888 error <general>: 2024-04-06 09:49:42.339 T:3888 error <general>: 2024-04-06 09:49:42.339 T:3888 info <general>: Skipped 10 duplicate messages.. 2024-04-06 09:49:42.339 T:3888 error <general>: ~ 2024-04-06 09:49:42.339 T:3888 info <general>: Skipped 21 duplicate messages.. 2024-04-06 09:49:42.339 T:3888 error <general>: ^ 2024-04-06 09:49:42.340 T:3888 info <general>: Skipped 2 duplicate messages.. 2024-04-06 09:49:42.340 T:3888 error <general>: 2024-04-06 09:49:42.340 T:3888 error <general>: TypeError 2024-04-06 09:49:42.340 T:3888 error <general>: : 2024-04-06 09:49:42.340 T:3888 error <general>: 'NoneType' object is not subscriptable 2024-04-06 09:49:42.340 T:3888 error <general>: 2024-04-06 11:24:50.526 T:3887 info <general>: Skipped 9 duplicate messages.. 2024-04-06 11:24:50.526 T:3887 info <general>: EMBY.database.library: open_EmbyDBRW waiting: updated 2024-04-06 11:25:00.534 T:3887 info <general>: Skipped 9 duplicate messages.. 2024-04-06 11:25:00.534 T:3887 info <general>: EMBY.database.library: open_EmbyDBRW waiting: updated 2024-04-06 11:25:10.542 T:3887 info <general>: Skipped 9 duplicate messages.. 2024-04-06 11:25:10.542 T:3887 info <general>: EMBY.database.library: open_EmbyDBRW waiting: updated 2024-04-06 11:25:20.548 T:3887 info <general>: Skipped 9 duplicate messages.. 2024-04-06 11:25:20.548 T:3887 info <general>: EMBY.database.library: open_EmbyDBRW waiting: updated 2024-04-06 11:25:30.552 T:3887 info <general>: Skipped 9 duplicate messages.. 2024-04-06 11:25:30.552 T:3887 info <general>: EMBY.database.library: open_EmbyDBRW waiting: updated 2024-04-06 11:25:40.557 T:3887 info <general>: Skipped 9 duplicate messages.. 2024-04-06 11:25:40.557 T:3887 info <general>: EMBY.database.library: open_EmbyDBRW waiting: updated 2024-04-06 11:25:50.563 T:3887 info <general>: Skipped 9 duplicate messages.. 2024-04-06 11:25:50.563 T:3887 info <general>: EMBY.database.library: open_EmbyDBRW waiting: updated 2024-04-06 11:26:00.581 T:3887 info <general>: Skipped 9 duplicate messages.. 2024-04-06 11:26:00.581 T:3887 info <general>: EMBY.database.library: open_EmbyDBRW waiting: updated 2024-04-06 11:26:10.589 T:3887 info <general>: Skipped 9 duplicate messages.. 2024-04-06 11:26:10.589 T:3887 info <general>: EMBY.database.library: open_EmbyDBRW waiting: updated 2024-04-06 11:26:20.605 T:3887 info <general>: Skipped 9 duplicate messages.. 2024-04-06 11:26:20.605 T:3887 info <general>: EMBY.database.library: open_EmbyDBRW waiting: updated 2024-04-06 11:26:30.612 T:3887 info <general>: Skipped 9 duplicate messages.. 2024-04-06 11:26:30.612 T:3887 info <general>: EMBY.database.library: open_EmbyDBRW waiting: updated 2024-04-06 11:26:40.618 T:3887 info <general>: Skipped 9 duplicate messages.. 2024-04-06 11:26:40.618 T:3887 info <general>: EMBY.database.library: open_EmbyDBRW waiting: updated 2024-04-06 11:26:50.625 T:3887 info <general>: Skipped 9 duplicate messages.. 2024-04-06 11:26:50.625 T:3887 info <general>: EMBY.database.library: open_EmbyDBRW waiting: updated 2024-04-06 11:27:00.635 T:3887 info <general>: Skipped 9 duplicate messages.. 2024-04-06 11:27:00.635 T:3887 info <general>: EMBY.database.library: open_EmbyDBRW waiting: updated 2024-04-06 11:27:10.643 T:3887 info <general>: Skipped 9 duplicate messages.. 2024-04-06 11:27:10.643 T:3887 info <general>: EMBY.database.library: open_EmbyDBRW waiting: updated 2024-04-06 11:27:20.649 T:3887 info <general>: Skipped 9 duplicate messages.. 2024-04-06 11:27:20.649 T:3887 info <general>: EMBY.database.library: open_EmbyDBRW waiting: updated 2024-04-06 11:27:30.655 T:3887 info <general>: Skipped 9 duplicate messages.. 2024-04-06 11:27:30.655 T:3887 info <general>: EMBY.database.library: open_EmbyDBRW waiting: updated 2024-04-06 11:27:40.668 T:3887 info <general>: Skipped 9 duplicate messages.. 2024-04-06 11:27:40.668 T:3887 info <general>: EMBY.database.library: open_EmbyDBRW waiting: updated 2024-04-06 11:27:50.681 T:3887 info <general>: Skipped 9 duplicate messages.. 2024-04-06 11:27:50.681 T:3887 info <general>: EMBY.database.library: open_EmbyDBRW waiting: updated 2024-04-06 11:28:00.686 T:3887 info <general>: Skipped 9 duplicate messages.. 2024-04-06 11:28:00.686 T:3887 info <general>: EMBY.database.library: open_EmbyDBRW waiting: updated 2024-04-06 11:28:10.692 T:3887 info <general>: Skipped 9 duplicate messages.. 2024-04-06 11:28:10.692 T:3887 info <general>: EMBY.database.library: open_EmbyDBRW waiting: updated 2024-04-06 11:28:20.704 T:3887 info <general>: Skipped 9 duplicate messages.. 2024-04-06 11:28:20.704 T:3887 info <general>: EMBY.database.library: open_EmbyDBRW waiting: updated 2024-04-06 11:28:30.712 T:3887 info <general>: Skipped 9 duplicate messages.. 2024-04-06 11:28:30.712 T:3887 info <general>: EMBY.database.library: open_EmbyDBRW waiting: updated 2024-04-06 11:28:40.723 T:3887 info <general>: Skipped 9 duplicate messages.. 2024-04-06 11:28:40.723 T:3887 info <general>: EMBY.database.library: open_EmbyDBRW waiting: updated 2024-04-06 11:28:50.727 T:3887 info <general>: Skipped 9 duplicate messages.. 2024-04-06 11:28:50.727 T:3887 info <general>: EMBY.database.library: open_EmbyDBRW waiting: updated 2024-04-06 11:29:00.734 T:3887 info <general>: Skipped 9 duplicate messages.. 2024-04-06 11:29:00.734 T:3887 info <general>: EMBY.database.library: open_EmbyDBRW waiting: updated 2024-04-06 11:29:10.750 T:3887 info <general>: Skipped 9 duplicate messages.. 2024-04-06 11:29:10.750 T:3887 info <general>: EMBY.database.library: open_EmbyDBRW waiting: updated 2024-04-06 11:29:20.754 T:3887 info <general>: Skipped 9 duplicate messages.. 2024-04-06 11:29:20.754 T:3887 info <general>: EMBY.database.library: open_EmbyDBRW waiting: updated 2024-04-06 11:29:30.759 T:3887 info <general>: Skipped 9 duplicate messages.. 2024-04-06 11:29:30.759 T:3887 info <general>: EMBY.database.library: open_EmbyDBRW waiting: updated 2024-04-06 11:29:40.766 T:3887 info <general>: Skipped 9 duplicate messages.. 2024-04-06 11:29:40.766 T:3887 info <general>: EMBY.database.library: open_EmbyDBRW waiting: updated 2024-04-06 11:29:50.773 T:3887 info <general>: Skipped 9 duplicate messages.. 2024-04-06 11:29:50.773 T:3887 info <general>: EMBY.database.library: open_EmbyDBRW waiting: updated 2024-04-06 11:30:00.779 T:3887 info <general>: Skipped 9 duplicate messages.. 2024-04-06 11:30:00.779 T:3887 info <general>: EMBY.database.library: open_EmbyDBRW waiting: updated 2024-04-06 11:30:10.785 T:3887 info <general>: Skipped 9 duplicate messages.. 2024-04-06 11:30:10.785 T:3887 info <general>: EMBY.database.library: open_EmbyDBRW waiting: updated 2024-04-06 11:30:20.789 T:3887 info <general>: Skipped 9 duplicate messages.. 2024-04-06 11:30:20.789 T:3887 info <general>: EMBY.database.library: open_EmbyDBRW waiting: updated 2024-04-06 11:30:30.793 T:3887 info <general>: Skipped 9 duplicate messages.. 2024-04-06 11:30:30.793 T:3887 info <general>: EMBY.database.library: open_EmbyDBRW waiting: updated This issue should be solved (workaround) by 10.0.13
quickmic 1709 Posted April 12, 2024 Posted April 12, 2024 On 4/8/2024 at 11:40 PM, Vvilams said: A restart didn't solve it but at least it's not totally stalled, just moving very slowly. I did upgrade to the latest version of Kodi but didn't see 10.X on the official repository yet. Is there something I should be looking at on the server side? The server version is 4.8.3.0 but now that I'm looking at the server, it is showing a running task of 'Scan Media Library' at about 91% and not moving. The server was restarted 2 days ago. 10.X is not available in repos yet. You must manually upgrade via public testing versions.
BMan1 5 Posted April 17, 2024 Posted April 17, 2024 It was loading fine for me early last week then it wanted me to do a database reset (literally only done one of them to fix this issue) Done that and seems to be working fine so far 1
d0ogie 9 Posted May 2, 2024 Posted May 2, 2024 (edited) I seem to be having the "repetitive boxsets updates" issue, too. I'm not sure what I did. I can reproduce this on Nexus 20.5, Omega 21.0, with Emby for Kodi Next-gen 9.4.21. The pattern seems to be: update single Movie entry -> update ALL boxsets and add relevant movies to each -> repeat until all Movies are updated. If I delete all Collections on the Emby server, everything continues to work great and sync is then really fast. I had the server recreate all Collections from metadata, and it's instantly back to reproducing this issue on Kodi clients. Behavior is consistent across Android and Windows clients; syncs therefore take a really long time and occupy a lot of CPU time, but do eventually complete. I have done many "factory resets"/"reset local database"..initial sync goes great, then if any movies get updated, we're back to this issue. Minimally sanitized log from a Windows machine is attached. I can try 10.x.x if helpful. This is a new Emby install so I unfortunately don't have a "this started after version x.y.z". edit=some code spelunking partially for my own curiosity. I understand the `boxsets` class..and indeed if we're in `Boxsets.change` over and over, I can see why the CPU usage is driven high. Working to understand what evaluates the need to trigger that update - logically I get the workflow "movie changed -> update boxsets"..but why *every* boxset? I don't understand that code path yet. kodi.log Edited May 2, 2024 by d0ogie 1
quickmic 1709 Posted May 2, 2024 Posted May 2, 2024 (edited) Yes please try 10.X. I changed couple of thinks for boxset sync. Anyway, your log shows you deleted around 150 boxsets. Not sure why, but seems Emby server reported that. Followup records in the log shows adding boxset again. Probably also 150... Seems you rebuild all the boxsets on Emby server. Also no issue, crashes or anything odd is reported in the log. I'll check your described pattern... Edited May 2, 2024 by quickmic
