staeff 10 Posted March 16, 2024 Posted March 16, 2024 (edited) Since LG TVs don't support Dolby Vision through mkv files, but only through mp4 files I currently need to manually convert/mux my files with this ffmpeg command: ffmpeg -map 0:v -c copy -map 0:a -c copy -strict unofficial myfile.mp4 -i myfile.mkv Ideally I would want to be able to use the built in convert feature of emby but when converting a mkv file with the following settings to mp4, then Dolby Vision will be removed in the resulting file. Edited March 16, 2024 by staeff 1 1 1
staeff 10 Posted March 17, 2024 Author Posted March 17, 2024 @RanmaCanadaI would appreciate if you would at least give an explanation why you downvoted this feature request. 1
RanmaCanada 502 Posted March 17, 2024 Posted March 17, 2024 2 hours ago, staeff said: @RanmaCanadaI would appreciate if you would at least give an explanation why you downvoted this feature request. DolbyVision is proprietary. Emby can't include the tools for this in their software without paying a dev fee (there are free tools to do this, but they take time). It is not Emby's responsibiltiy to ensure your pirated materials will work with your devices. If you are ripping your own materials, it is YOUR responsibility to ensure it works with your hardware. As it's obvious you are pirating stuff, it's not their job to make your pirated materials work with your TV. If you're going to pirate or rip your own materials, get/rip them in the format your device supports. But if anything, the amount of people not understanding this and demanding that the devs cater to their laziness and ignorance is starting to get out of hand. This is a YOU problem, not an Emby problem. 2
staeff 10 Posted March 17, 2024 Author Posted March 17, 2024 (edited) @RanmaCanadaI would kindly ask you to be less condescending. I have read through your post history and you come of as a really unpleasant person. That said I'm not asking to manipulate the codec in any way but just to change the container format and keep the encoded stream as is. Which is separate from decoding and re-encoding a Dolby Vision stream, for which I recognize that licensing issues might arise. Edited March 17, 2024 by staeff 2
RanmaCanada 502 Posted March 17, 2024 Posted March 17, 2024 3 minutes ago, staeff said: @RanmaCanadaI would kindly ask you to be less condescending. I have read through your post history and you come of as a really unpleasant person. That said I'm not asking to manipulate the codec in any way but just to change the container format and keep the encoded stream as is. Which is separate from decoding and re-encoding a Dolby Vision stream, for which I recognize that licensing issues might arise. If I come across as unpleasant it is because I am sick and tired of people not understanding the technical aspects of their questions/statements. You can't just change the container without going through and processing the video and audio to ensure it is compliant with the container you want to use. If you could, it would be as simple as changing the file extention from .mkv to .mp4. Which it is not. You still need to have the video and audio tracks processed to ensure they are compliant with the proper headers and other information. And again, DolbyVision is 100% proprietary and Emby doesn't have the legal ability to manipulate streams (which is what remuxing to an mp4 container is), hence it is a YOU problem. Just because there are "free" tools available doesn't mean that they can be used by a company legally. If they could, I am sure they would love to include the ability to encode streams to DTS as afterall, there are "free" tools available to convert ac3 5.1 into DTS. DolbyVision is a monster of a legal mess. And the faster people realize it, the quicker these types of requests will vanish. 1 1
staeff 10 Posted March 17, 2024 Author Posted March 17, 2024 As far as I can tell you are neither an employee of Emby nor a moderator on this forum, therefore I don't get why you go out of your way to berate newcomers seeking help and constructive input. I'm not sure what happened in your life that you feel the need to be rude to strangers on the internet, whatever it is I feel truly sorry for you. But to use the only rethorical device you seem to recognize: whatever problem in life made you turn out this way it's a YOU problem. 1 1
RanmaCanada 502 Posted March 17, 2024 Posted March 17, 2024 I haven't been rude to you at all in this correspondance. If you feel I have, please feel fine to report it to the admins. At no point did I berate you. If my using the emphasis of caps on YOU makes you feel uneasy, understand that this is a text based medium and it is very difficult to get the importance of certain topics across to users without certain means. I am not personally attacking you. 1 1
ebr 16337 Posted March 18, 2024 Posted March 18, 2024 Hi. So you would want the Convert feature to have the option to just do a container swap without any actual conversion of the streams? If so, I think that is already possible...
staeff 10 Posted March 18, 2024 Author Posted March 18, 2024 (edited) @ebrthanks for your answer, yes that basically would be the idea. I don't have any insight in what Emby is doing behind the scenes, but I assume it's using ffmpeg? If yes, then I think the issue might be that remuxing of Dolby Vision from my tests only works with the `-strict unofficial` option (and a fairly recent version of ffmpeg). Personally I would be happy enough with some advanced setting to provide custom arguments, to not enforce unofficial for everyone. With the current Emby convert feature and the following settings and the following source file video information: Profile: Custom Container: mp4 Video codec: hevc, h264 Audio codec: aac, mp3, ac3 Quality: Original quality Title: 4k Dolby Vision HEVC Codec: HEVC Dolby Profile: Profile 8.1 (HDR10 compatilbe) Profile: Main 10 Level: 150 Resolution 3840x1604 Interlaced: No Bitrate: 25mbps Video Range: DolbyVision Color Primaries: bt2020 Color Space bt2020nc Color Transfer smpte2084 Bit Depth: 10 bit Pixel Format: yuv420p10le I get the following output: Title: 4K HDR 10 HEVC Codec: HEVC Codec Tag: hvc1 Profile: Main 10 Resolution: 3840x1604 Interlaced: No Bitrate: 24mbps Video Range: HDR 10 Color Primaries: bt2020 Color Space: bt2020nc Color Transfer: smpte2084 Bit Depth: 10 bit Pixel Format: yuv420p10le In contrast, if I use the ffmpeg command I described initially I get exactly the same output as I had for the input. Edited March 18, 2024 by staeff 1
rbjtech 5344 Posted March 18, 2024 Posted March 18, 2024 (edited) 1 hour ago, staeff said: @ebrthanks for your answer, yes that basically would be the idea. I don't have any insight in what Emby is doing behind the scenes, but I assume it's using ffmpeg? If yes, then I think the issue might be that remuxing of Dolby Vision from my tests only works with the `-strict unofficial` option (and a fairly recent version of ffmpeg). Personally I would be happy enough with some advanced setting to provide custom arguments, to not enforce unofficial for everyone. With the current Emby convert feature and the following settings and the following source file video information: Profile: Custom Container: mp4 Video codec: hevc, h264 Audio codec: aac, mp3, ac3 Quality: Original quality Title: 4k Dolby Vision HEVC Codec: HEVC Dolby Profile: Profile 8.1 (HDR10 compatilbe) Profile: Main 10 Level: 150 Resolution 3840x1604 Interlaced: No Bitrate: 25mbps Video Range: DolbyVision Color Primaries: bt2020 Color Space bt2020nc Color Transfer smpte2084 Bit Depth: 10 bit Pixel Format: yuv420p10le I get the following output: Title: 4K HDR 10 HEVC Codec: HEVC Codec Tag: hvc1 Profile: Main 10 Resolution: 3840x1604 Interlaced: No Bitrate: 24mbps Video Range: HDR 10 Color Primaries: bt2020 Color Space: bt2020nc Color Transfer: smpte2084 Bit Depth: 10 bit Pixel Format: yuv420p10le In contrast, if I use the ffmpeg command I described initially I get exactly the same output as I had for the input. If you use the actual emby ffmpeg (located in the 'system' folder within emby) - does that have the necessary function ? Emby use a custom ffmpeg - so it may not have the -strict unofficial functionality. Then there is the case of support - if they opt to use the above syntax, then how does that impact the 'official' way of doing it .. (pretty sure they just do a -c:a copy -c:v copy today). Adding a 'custom' option will bring many support questions - and probably not something emby would want to do - and frankly, if you know ffmpeg syntax - then writing a quick script as part of a pre or post processing of your files will likely be a better solution ? btw - have you tried saving as a TS file (transport stream) in the Emby Convert function - from memory, this container supports DV on the LG (but may also need the -strict, I'm not sure ..) Edited March 18, 2024 by rbjtech 1
staeff 10 Posted March 18, 2024 Author Posted March 18, 2024 (edited) 22 minutes ago, rbjtech said: If you use the actual emby ffmpeg (located in the 'system' folder within emby) - does that have the necessary function ? Emby use a custom ffmpeg - so it may not have the -strict unofficial functionality. Then there is the case of support - if they opt to use the above syntax, then how does that impact the 'official' way of doing it .. (pretty sure they just do a -c:a copy -c:v copy today). Thanks for the idea! Just tried it out and it seems that the ffmpeg version emby is using when called with the same parameter then the resulting file still contains the Dolby Vision stream. To be honest I'm not 100% sure what impact of the unofficial flag is besides this, since the ffmpeg documentation also only really says the following: "allow unofficial extensions". That's why I would kind of want this to be a feature flag / setting, even though it probably should not have any impact. FFmpeg Codecs Documentation I will try out the TS file conversion later to see if that works, but ideally I like my files to be in a more widely used format, but also a very good hint! Next step would be to set up some file watcher or regular job to run my command, but since Emby already has a built in functionality to convert new files I kind of would like to use it. Edited March 18, 2024 by staeff 2
rbjtech 5344 Posted March 18, 2024 Posted March 18, 2024 2 minutes ago, staeff said: Thanks for the idea! Just tried it out and it seems that the ffmpeg version emby is using works like expected when I use the same parameters and the resulting file still contains the Dolby Vision stream. To be honest I'm not 100% sure what impact of the unofficial flag is besides this, since the ffmpeg documentation also only really says the following: "allow unofficial extensions". That's why I would kind of want this to be a feature flag / setting, even though it probably should not have any impact. FFmpeg Codecs Documentation I will try out the TS file conversion later to see if that works, but ideally I like my files to be in a more widely used format, but also a very good hint! Next step would be to set up some file watcher or regular job to run my command, but since Emby already has a built in functionality to convert new files I kind of would like to use it. Cool - so if the emby ffmpeg already has it - then I don't personally see any issues with adding an option to use -strict unofficial to retain any proprietary metadata in the remuxing process .. over to the Dev's I guess.
staeff 10 Posted March 20, 2024 Author Posted March 20, 2024 @ebrwould adding the `-strict unoffical` option be feasible for Emby (wether directly or through some setting)?
Luke 42245 Posted March 25, 2024 Posted March 25, 2024 On 3/20/2024 at 8:29 AM, staeff said: @ebrwould adding the `-strict unoffical` option be feasible for Emby (wether directly or through some setting)? It's possible, yes, but what happened with the mp4 that wasn't encoded that way?
staeff 10 Posted March 25, 2024 Author Posted March 25, 2024 5 minutes ago, Luke said: It's possible, yes, but what happened with the mp4 that wasn't encoded that way? The last code section in this comment I made above shows the output I got with the current convert feature
Luke 42245 Posted April 30, 2024 Posted April 30, 2024 Have you tried with ffmpeg 6.0 to see if the conversion is usable without -strict unofficial?
staeff 10 Posted April 30, 2024 Author Posted April 30, 2024 @Lukejust tried it with both 6.1.1 and 7.0 and -strict unofficial is needed for both of them to produce a dolby vision output
bandit8623 226 Posted May 2, 2024 Posted May 2, 2024 (edited) On 3/17/2024 at 8:28 AM, staeff said: @RanmaCanadaI would kindly ask you to be less condescending. I have read through your post history and you come of as a really unpleasant person. That said I'm not asking to manipulate the codec in any way but just to change the container format and keep the encoded stream as is. Which is separate from decoding and re-encoding a Dolby Vision stream, for which I recognize that licensing issues might arise. im pretty sure @RanmaCanada kills kittens in RL Edited May 2, 2024 by bandit8623 1
bandit8623 226 Posted May 2, 2024 Posted May 2, 2024 (edited) On 3/17/2024 at 8:44 AM, RanmaCanada said: If I come across as unpleasant it is because I am sick and tired of people not understanding the technical aspects of their questions/statements. You can't just change the container without going through and processing the video and audio to ensure it is compliant with the container you want to use. If you could, it would be as simple as changing the file extention from .mkv to .mp4. Which it is not. You still need to have the video and audio tracks processed to ensure they are compliant with the proper headers and other information. And again, DolbyVision is 100% proprietary and Emby doesn't have the legal ability to manipulate streams (which is what remuxing to an mp4 container is), hence it is a YOU problem. Just because there are "free" tools available doesn't mean that they can be used by a company legally. If they could, I am sure they would love to include the ability to encode streams to DTS as afterall, there are "free" tools available to convert ac3 5.1 into DTS. DolbyVision is a monster of a legal mess. And the faster people realize it, the quicker these types of requests will vanish. no you are just sick in the head. look what happens when you stop jumping in and spewing garbage and let Emby actually speak. its refreshing when a converation actually happens. Edited May 2, 2024 by bandit8623
Shadowflix 3 Posted June 8, 2024 Posted June 8, 2024 On 3/26/2024 at 2:16 AM, Luke said: It's possible, yes, but what happened with the mp4 that wasn't encoded that way? It would be quite amazing if this feature was added. 1 1
