Ivanovyi 1 Posted March 16, 2024 Posted March 16, 2024 (edited) Hello, My emby server is installed on a Windows 10 box and works over WiFi. I Have an Archer C80 as a main router and an RE215 as a satellite in a OneMesh configuration. The server connects to the network via the Satellite. Windows, emby, and routers are all updated. The issue: when I move through the house and my tablet changes from being connected to the router to the satellite. I lose connection to the Emby server (only the internet works). When I reconnect to the router it's all good. Reminder the server is connected to the satellite. Logs from this morning when it happened attached. Any ideas? embyserver.txt Edited March 16, 2024 by Ivanovyi Logs attached
Abobader 3491 Posted March 16, 2024 Posted March 16, 2024 Hello Ivanovyi, ** This is an auto reply ** Please wait for someone from staff support or our members to reply to you. It's recommended to provide more info, as it explain in this thread: Thank you. Emby Team
Luke 42290 Posted March 16, 2024 Posted March 16, 2024 Hi, that's odd. Never heard of this. I have two tp-link mesh setups for testing and have never seen this. What makes you think you're losing connection to the server?
Ivanovyi 1 Posted March 16, 2024 Author Posted March 16, 2024 When I move rooms I monitor the Teher App. When my tablet connects to the satellite streaming stops after the buffer plays out and when I get taken to the select server screen. I try to reconnect and wake to no avail. The moment I reboot the satellite from the app and the tablet connects to the router I can connect again. To be fair I haven't tried this with another device (client) to see if it's a OneMesh issue or the Honour Tab 8.
Ivanovyi 1 Posted March 18, 2024 Author Posted March 18, 2024 I solved my problem by buying a mini PC and connecting it to the router with an ethernet cable. Il I think the issue was that my old box was just too far from the main router and could only reach the satellite. It was too power hungry anyway and overkill for an emby serrver. She is on FB marketplace now thanks for the help 1
