Anon_USR 9 Posted March 16, 2024 Posted March 16, 2024 Hello, I've installed Emby on my machine, my library is a bit huge (80 To), scan for Movies and Series was pretty fast but Anime scan is very very long and looks stuck to 87.4% (now 2 days just for it), I don't know why. Library is mounted on ubuntu server using sshfs with Tailscale tunnel and using the Emby 4.9.0.8 beta embyserver.txt hardware_detection-63846109564.txt
Happy2Play 9812 Posted March 16, 2024 Posted March 16, 2024 It isn't stuck you just have Detect Episode Intros happening also so it makes the overall process even longer.
Happy2Play 9812 Posted March 16, 2024 Posted March 16, 2024 What is your library option for this? But from a new install this should be run as its own task after you have completed an initial scan and once all marks are made you can change the option to both/when added.
Anon_USR 9 Posted March 16, 2024 Author Posted March 16, 2024 (edited) 5 minutes ago, Happy2Play said: What is your library option for this? But from a new install this should be run as its own task after you have completed an initial scan and once all marks are made you can change the option to both/when added. Here you have the options for this library, I've also stopped the detect intro for the moment, will update it later. Edited March 16, 2024 by NoCore9
Happy2Play 9812 Posted March 16, 2024 Posted March 16, 2024 I can only guess the intro scan kicked off at some point of the library scan. As it would have had to happen in previous log. So you may want to disable the Markers option per library or stop the task while initial scan is going. Note the Detect Intros is scheduled for every 24 hours.
Luke 42244 Posted March 16, 2024 Posted March 16, 2024 HI, yes intro detection can take a long time. I think it's just a matter of waiting for it to finish. Please let us know if this helps. Thanks.
Anon_USR 9 Posted March 16, 2024 Author Posted March 16, 2024 1 minute ago, Luke said: HI, yes intro detection can take a long time. I think it's just a matter of waiting for it to finish. Please let us know if this helps. Thanks. Hi, scan didn't mooved at all and still on the same percentage while kicking intro detection, I can see on logs that Emby is doing something on the same Anime for like 1 day.
Anon_USR 9 Posted March 22, 2024 Author Posted March 22, 2024 Ok I can see that it's not only Animes, it's the scan that is taking too long, next scan is very very very long, 2 days to gain 1% on the scan that's a problem, partial scan when changes occurs is not working too, need to full scan.
Anon_USR 9 Posted March 22, 2024 Author Posted March 22, 2024 embyserver.txthere the actual logs of the server
Happy2Play 9812 Posted March 22, 2024 Posted March 22, 2024 If initial scan has not completed you need to disable Markers. As the process is going to slow the entire process down. Only all this task to run after all your media has been imported the it will takes potentially days for the task to do all your media or limit it to so many hours every night. But your server log looks normal for the settings enabled.
Anon_USR 9 Posted March 22, 2024 Author Posted March 22, 2024 (edited) 4 minutes ago, Happy2Play said: If initial scan has not completed you need to disable Markers. As the process is going to slow the entire process down. Only all this task to run after all your media has been imported the it will takes potentially days for the task to do all your media or limit it to so many hours every night. But your server log looks normal for the settings enabled. Initial scan has been done (by doing some metadata detect manually to speed up the process), makers as been enabled like 1 day after scan stuck because he's starting each 24 hours so that's not the problem. The problem is that each new scan (daily scan) is long and taking days to finish and that's a big problem because all other tasks (partial scan especially) are not working. Edited March 22, 2024 by NoCore9
Happy2Play 9812 Posted March 22, 2024 Posted March 22, 2024 But in the end ongoing process will affect all future process no matter what they are. Dev will have to comment further. If you stopped the marker process normal scans are fast correct?
Anon_USR 9 Posted March 22, 2024 Author Posted March 22, 2024 10 minutes ago, Happy2Play said: But in the end ongoing process will affect all future process no matter what they are. Dev will have to comment further. If you stopped the marker process normal scans are fast correct? No, same speed.
Luke 42244 Posted March 22, 2024 Posted March 22, 2024 57 minutes ago, NoCore9 said: No, same speed. What exactly did you do?
Anon_USR 9 Posted March 22, 2024 Author Posted March 22, 2024 28 minutes ago, Luke said: What exactly did you do? restarted the server and let the scan run but it's long, but on first scan i've searched the items manually like searching them
Anon_USR 9 Posted March 25, 2024 Author Posted March 25, 2024 3 minutes ago, Luke said: Have you been able to complete a scan? No
Anon_USR 9 Posted March 25, 2024 Author Posted March 25, 2024 Here you have the logs and the problem, Emby is stuck or very very very very long to do a full scan @Luke embyserver(1).txt
Anon_USR 9 Posted March 30, 2024 Author Posted March 30, 2024 Made the last update 4.9.0.12, still slow / stuck
Luke 42244 Posted April 2, 2024 Posted April 2, 2024 On 3/29/2024 at 10:45 PM, NoCore9 said: Made the last update 4.9.0.12, still slow / stuck Hi, can you please provide a new log example? thanks.
Anon_USR 9 Posted April 3, 2024 Author Posted April 3, 2024 4 hours ago, Luke said: Hi, can you please provide a new log example? thanks. Here you have. embyserver.txt
Luke 42244 Posted April 4, 2024 Posted April 4, 2024 On 4/2/2024 at 9:39 PM, NoCore9 said: Here you have. embyserver.txt 3.15 MB · 0 downloads Please try removing these plugins: AniList 1.0.5.0 Anime 1.5.6.0 InfuseSync 1.4.2.0 Top Picks 1.0.0.60 Then restart the server and see how things compare.
Anon_USR 9 Posted April 8, 2024 Author Posted April 8, 2024 On 4/4/2024 at 7:45 AM, Luke said: Please try removing these plugins: AniList 1.0.5.0 Anime 1.5.6.0 InfuseSync 1.4.2.0 Top Picks 1.0.0.60 Then restart the server and see how things compare. Server finally finished the initial scan after 1 month, I suspect that the plugins are making the search a lot longer but I can't disable them now as it will be useless
Luke 42244 Posted April 9, 2024 Posted April 9, 2024 13 hours ago, NoCore9 said: Server finally finished the initial scan after 1 month, I suspect that the plugins are making the search a lot longer but I can't disable them now as it will be useless I would at least remove Top Picks if you can.
