joselveas 0 Posted March 15, 2024 Posted March 15, 2024 (edited) When using bluetooth earphones (galaxy buds live) on emby for android tv (ver 2.1.10g on chromecast 4) any media (only videos) give the error "Too many errors. Giving up". For context, i have normally 3 audio output: HDMI, bluetooth speaker and bluetooth earphones. Only the earphones give the error. I try disabling the transcoding on the server, disabling the option "burn subtitles" on the app for andorid and the audio output (in the app) i try the 3 options (automatic, dolby and stereo) but nothing work. The "solution" i found is disconnect the earphones, play the media with the speakers or the hdmi output an then, when the media is playing, connect the earphones and it work. (obviously not the best solution) *Sorry for the bad english, but spanish is my native language. **Logs of emby when the error occurs are attached. ***desktop version is 4.8.3.0 and app version is 2.1.10g used in chromecast 4 (not 4k version) with android TV last logs emby.txt Edited March 15, 2024 by joselveas
Solution Luke 42243 Posted March 16, 2024 Solution Posted March 16, 2024 Hi. Can you try sideloading our standard android app on the same device and see how that compares? https://emby.media/emby-for-android.html Thanks.
ebr 16335 Posted March 16, 2024 Posted March 16, 2024 15 hours ago, joselveas said: I try disabling the transcoding on the server, Hi. If you've disabled any of the transcoding options and the app needs to transcode, then you may get this error.
joselveas 0 Posted March 16, 2024 Author Posted March 16, 2024 10 hours ago, Luke said: Hi. Can you try sideloading our standard android app on the same device and see how that compares? https://emby.media/emby-for-android.html Thanks. Sideloading the standard android app apparently fixed the problem. thx. 2 hours ago, ebr said: Hi. If you've disabled any of the transcoding options and the app needs to transcode, then you may get this error. I try disabling and enabling but with both configuration the error continued. *I install on the Chromecast the amr7 standard android app and that fix the problem (like @Lukesaid), but in the android tv app the error is still there.
Luke 42243 Posted March 18, 2024 Posted March 18, 2024 Quote Sideloading the standard android app apparently fixed the problem. thx. Hi, that's great, thanks .Are you happy continuing to use this?
joselveas 0 Posted March 18, 2024 Author Posted March 18, 2024 21 minutes ago, Luke said: Hi, that's great, thanks .Are you happy continuing to use this? Well, to tell you the truth, i prefer the androidTv app for the GUI (although it is not very different, it is better optimized for use with the Chromecast control) and also to take advantage of the fact that I have premier hahaha. For now I will use the standard android app, but i hope in the future the problem is solved (maybe i buy another earphones and those will work without problems, or maybe in a future ver. of the android tv app the error will no longer occur). thx.
Luke 42243 Posted March 19, 2024 Posted March 19, 2024 On 3/17/2024 at 10:36 PM, joselveas said: Well, to tell you the truth, i prefer the androidTv app for the GUI (although it is not very different, it is better optimized for use with the Chromecast control) and also to take advantage of the fact that I have premier hahaha. For now I will use the standard android app, but i hope in the future the problem is solved (maybe i buy another earphones and those will work without problems, or maybe in a future ver. of the android tv app the error will no longer occur). thx. Hi there, why do you feel it is better optimized for use with the Chromecast control?
BenjP 0 Posted March 19, 2024 Posted March 19, 2024 (edited) Hi, I have the same problem with my Bluetooth headset but it was working fine before the last update on March 12. Sorry, but slideload the Android version is not a solution. Is there a way to downgrade emby for Android TV? Edited March 19, 2024 by BenjP
joselveas 0 Posted March 19, 2024 Author Posted March 19, 2024 14 hours ago, Luke said: Hi there, why do you feel it is better optimized for use with the Chromecast control? i fell there are some gestures in the android tv app that are more natural (using the chromecast remote) that in the standard android app. Like when I'm watching a chapter of a series and I press down on the control, all the options (like cc, go to the next chapter, pause, etc.) can be seen on the screen. When I press up I can see the chapter divisions and the forward and back buttons simply move the chapter forward or back. But in the standar app, i have to push up to see the options (no problem there), but i cant see any media button (pause, go forward or back, next chapter, etc) and the GUI feels a bit slow. I understand that the above may sound a little silly, but I feel that the movements and the UI are more natural in the android tv app when using a remote. Another thing and this too maybe could sound silly (It's just an opinion from a user perspective), but if i want to make changes in the server, i will use the domain where apache is proxyng emby or connect directly to the host server, or the tablet that i use with the standar android app. Personally, i dont need all the server options in my tv and having them there feels strange and a little confusing (using the standard app on adnroid tv). *I am also a software engineer and I understand that many times being able to focus on both maintainability and adding new functions to satisfy the user is a hellish task.
Luke 42243 Posted April 1, 2024 Posted April 1, 2024 @joselveas Quote Like when I'm watching a chapter of a series and I press down on the control, all the options (like cc, go to the next chapter, pause, etc.) can be seen on the screen. When I press up I can see the chapter divisions and the forward and back buttons simply move the chapter forward or back. But in the standar app, i have to push up to see the options (no problem there), but i cant see any media button (pause, go forward or back, next chapter, etc) and the GUI feels a bit slow. Don't you have these media buttons on your remote? If not, then you can always enable them in the app playback settings. Then they'll show on screen as you're accustomed to. Please let us know if this resolves your issue. Thanks.
ManiacalMobius 0 Posted August 8, 2024 Posted August 8, 2024 Hi, I'm also having this playback problem with both my Sony headphones (WH-1000XM4) and Sony earbuds (WF-C500). I'm on a chromecast HD. It just tries a couple of times and then gives up, unless I'm just using the TV's speakers. It happens both on the Emby for Android TV and the Emby for Android app.
veselyslon 0 Posted August 10, 2024 Posted August 10, 2024 Hello, i have the same problem. Projector Magcubic HY320: Emby for Android TV (i have lifetime licence) works good with internal speaker. But when i connect via bluetooth to external speakers Emby give the error "Too many errors. Giving up". When i use Emby for Android app, then works good, but need pay for Emby Premere, video run only one minute. Is any solution to use licence from TV version, or should I hope that the problem will be solved in the future?
Luke 42243 Posted August 14, 2024 Posted August 14, 2024 Hi, have you tried this with Emby for Android 3.4.20?
ManiacalMobius 0 Posted August 15, 2024 Posted August 15, 2024 On 8/14/2024 at 4:44 AM, Luke said: Hi, have you tried this with Emby for Android 3.4.20? Yes, that's the version I'm using. It works fine if I use the built in TV speakers or plug in something using the TV's headphone jack, but when I switch over to Bluetooth the video can't play anymore. It does take a bit to catch onto the fact that I've changed audio sources, so it's able to play for a little bit, but if I try to skip around it immediately stops working.
Luke 42243 Posted October 22, 2024 Posted October 22, 2024 On 8/15/2024 at 1:48 PM, ManiacalMobius said: Yes, that's the version I'm using. It works fine if I use the built in TV speakers or plug in something using the TV's headphone jack, but when I switch over to Bluetooth the video can't play anymore. It does take a bit to catch onto the fact that I've changed audio sources, so it's able to play for a little bit, but if I try to skip around it immediately stops working. Hi, regarding this, Can you try sideloading the latest build from our website? https://emby.media/emby-for-android.html Does it still happen with that?
ManiacalMobius 0 Posted November 25, 2024 Posted November 25, 2024 On 10/22/2024 at 8:47 PM, Luke said: Hi, regarding this, Can you try sideloading the latest build from our website? https://emby.media/emby-for-android.html Does it still happen with that? Yeah, still happens. Seems to be an issue with surround sound audio maybe? If I see Stereo in the file details I can play it just fine. Anything else doesn't play.
Luke 42243 Posted November 26, 2024 Posted November 26, 2024 5 hours ago, ManiacalMobius said: Yeah, still happens. Seems to be an issue with surround sound audio maybe? If I see Stereo in the file details I can play it just fine. Anything else doesn't play. Hi, what version number did you try?
ManiacalMobius 0 Posted November 26, 2024 Posted November 26, 2024 9 hours ago, Luke said: Hi, what version number did you try? Hi, just redownloaded and sideloaded to verify that it's still happening (3.4.26, arm7). I tried it with a file with many options for audio. (7.1, 5.1, stereo, stereo directors commentary, stereo audio description) Only stereo works as expected. Any other track will not play at all. Let me know if you want me to create a new thread for this.
Luke 42243 Posted December 9, 2024 Posted December 9, 2024 On 11/26/2024 at 4:39 AM, ManiacalMobius said: Hi, just redownloaded and sideloaded to verify that it's still happening (3.4.26, arm7). I tried it with a file with many options for audio. (7.1, 5.1, stereo, stereo directors commentary, stereo audio description) Only stereo works as expected. Any other track will not play at all. Let me know if you want me to create a new thread for this. OK we'll take another look at this. Thanks for reporting.
anye123 0 Posted March 16, 2025 Posted March 16, 2025 For those like me who found this thread due to the mention of this issue on the HY320 projector, I have found that version 3.2.82 of the Android app (not Android TV app) is the latest one where non-stereo content plays back with my Bluetooth headphones connected. From 3.2.92 onwards I experience the same failed playback issue as described above.
Luke 42243 Posted May 12, 2025 Posted May 12, 2025 On 3/16/2025 at 2:27 PM, anye123 said: For those like me who found this thread due to the mention of this issue on the HY320 projector, I have found that version 3.2.82 of the Android app (not Android TV app) is the latest one where non-stereo content plays back with my Bluetooth headphones connected. From 3.2.92 onwards I experience the same failed playback issue as described above. @anye123are you still having an issue with this with the latest versions?
tuckjordan20 3 Posted January 10 Posted January 10 On 12/05/2025 at 04:45, Luke said: @anye123are you still having an issue with this with the latest versions? Hi, i would like to flag that this is still an issue on both the latest emby for android and emby android tv using a magcubic projector connected to a Bluetooth speaker.
Luke 42243 Posted February 4 Posted February 4 Hi have you updated to Emby for android 3.5.28? Has that helped?
