The.doctor 1 Posted March 12, 2024 Posted March 12, 2024 Lately my WD My Cloud EX2 Ultra is showing 100 CPU Usage, and the fan is running %100. If I turn off Emby, the CPU usage and fan drop off. Ffmpeg appears to be an issue when I look at the WD Process. High CPU and Memory usage. What files do you need to see to help me resolve this issue? I updated to version 4.9.0.8. It did not help. If I wish to, how do I do a clean install? Thank you!
Luke 42237 Posted March 12, 2024 Posted March 12, 2024 Hi there, please attach the emby server log from when the problem occurred: How to Report a Problem Thanks.
The.doctor 1 Posted March 12, 2024 Author Posted March 12, 2024 Hi Luke, I have attached the file requested. Thanks for helping me out. embyserver.txt
Luke 42237 Posted March 12, 2024 Posted March 12, 2024 hi, we'll take a look at it. Thanks for reporting.
Happy2Play 9811 Posted March 12, 2024 Posted March 12, 2024 41 minutes ago, The.doctor said: Hi Luke, I have attached the file requested. Thanks for helping me out. embyserver.txt 32.98 kB · 1 download Is it still going the same thing? But probably need to see the log when you restarted Emby and made this post as this 10 minute log doesn't really show anything.
The.doctor 1 Posted March 12, 2024 Author Posted March 12, 2024 I did just restart Emby and pull that log. CPU usage is up and down, and the fan is at is showing 10000 RPM. I will let it run overnight and pull another log. Would the ffmpeg log help?
Happy2Play 9811 Posted March 12, 2024 Posted March 12, 2024 2 minutes ago, The.doctor said: I did just restart Emby and pull that log. CPU usage is up and down, and the fan is at is showing 10000 RPM. I will let it run overnight and pull another log. Would the ffmpeg log help? Yes and No but if transcoding is happening ffmpeg is full throttle processing the media.
The.doctor 1 Posted March 12, 2024 Author Posted March 12, 2024 When does transcoding happen? No one is using my Emby right now. Is it something I can stop/kill?
Happy2Play 9811 Posted March 13, 2024 Posted March 13, 2024 12 minutes ago, The.doctor said: When does transcoding happen? No one is using my Emby right now. Is it something I can stop/kill? Per that log it would appear someone was 2024-03-12 17:09:33.726 Info App: Bitrate exceeds DirectPlay limit: media bitrate: 15204947, max bitrate: 4000000 2024-03-12 17:09:33.727 Info App: Bitrate exceeds DirectStream limit: media bitrate: 15204947, max bitrate: 4000000 2024-03-12 17:09:36.054 Info VideoEncoder: ProcessRun 'Encoding 64e568' Execute: /mnt/HD/HD_a2/Nas_Prog/embyserver/bin/ffmpeg -loglevel +timing -y -print_graphs_file "/mnt/HD/HD_a2/emby/logs/ffmpeg-transcode-64e568ed-0482-4044-88ef-31dd2ff1186e_1graph.txt" -copyts -start_at_zero -f matroska,webm -re -c:v:0 hevc -noautorotate -i "/shares/Public/Shared Videos/Ferrari.2023.2160p.AMZN.WEB-DL.DDP5.1.Atmos.HDR.H.265-FLUX.mkv" -filter_complex "[0:0]scale@f1=width=1920:height=800,format@f2=pix_fmts=yuv420p[f2_out0]" -map [f2_out0] -map 0:1 -sn -c:v:0 libx264 -g:v:0 144 -maxrate:v:0 3616000 -bufsize:v:0 7232000 -sc_threshold:v:0 0 -keyint_min:v:0 144 -r:v:0 23.9760246276855 -pix_fmt:v:0 yuv420p -preset:v:0 veryfast -profile:v:0 high -x264opts:v:0 "subme=0:me_range=4:rc_lookahead=10:partitions=none" -crf:v:0 23 -c:a:0 libmp3lame -ab:a:0 192000 -ac:a:0 2 -metadata:s:a:0 language=eng -filter:a:0 "volume=2" -disposition:a:0 default -avoid_negative_ts disabled -map_metadata -1 -map_chapters -1 "/mnt/HD/HD_a2/emby/sync/13/13/64e568ed-0482-4044-88ef-31dd2ff1186e.mkv" What does the Emby Dashboard show is it will show you when something is playing. example
The.doctor 1 Posted March 13, 2024 Author Posted March 13, 2024 That is very strange. No one was playing anything at that time. Activity I also see this on the dashboard I have attached the latest Emby and ffmpeg logs. embyserver.txt ffmpeg-transcode-64e568ed-0482-4044-88ef-31dd2ff1186e_1.txt
The.doctor 1 Posted March 14, 2024 Author Posted March 14, 2024 Hi. Now I cannot reach the Emby homepage. “Unable to connect” I have attached the latest Emby and ffmpeg logs via WinSCP. embyserver.txt ffmpeg-transcode-64e568ed-0482-4044-88ef-31dd2ff1186e_1.txt
Happy2Play 9811 Posted March 14, 2024 Posted March 14, 2024 Dev will have to comment as everything I could find in the forum is years old. But they are Mono related. 2024-03-13 00:32:10.578 Error Server: Error processing request *** Error Report *** Version: 4.9.0.8 Command line: /mnt/HD/HD_a2/Nas_Prog/embyserver/system/EmbyServer.exe -programdata /mnt/HD/HD_a2/emby -ffdetect /mnt/HD/HD_a2/Nas_Prog/embyserver/bin/ffdetect -ffmpeg /mnt/HD/HD_a2/Nas_Prog/embyserver/bin/ffmpeg -ffprobe /mnt/HD/HD_a2/Nas_Prog/embyserver/bin/ffprobe -nolocalportconfig -defaultdirectory /shares/Public -updatepackage emby-server-western_digital-mono-os5-any_{version}_arm.bin -noskia Operating system: Linux version 4.14.22-armada-18.09.3 (kman@kmachine) (gcc version 8.3.0 (Debian 8.3.0-2)) #1 SMP Thu Oct 27 08:25:39 UTC 2022 ga-18.09.3 Build-30 Framework: Mono: 6.12.0.182 (tarball Thu Jan 19 10:28:52 PM UTC 2023) OS/Process: X86/X86 Runtime: mnt/HD/HD_a2/Nas_Prog/embyserver/lib/mono/4.5/mscorlib.dll Processor count: 2 Data path: /mnt/HD/HD_a2/emby Application path: /mnt/HD/HD_a2/Nas_Prog/embyserver/system System.Net.Sockets.SocketException: System.Net.Sockets.SocketException (0x80004005): The socket is not connected at System.Net.Sockets.Socket.get_RemoteEndPoint () [0x00035] in <592c5cca45dd4995b6e53e31bac2a687>:0 at SocketHttpListener.Net.HttpConnection.get_RemoteEndPoint () [0x00000] in <d1e44c6b1e034cc2a5f3455bdd51f2c0>:0 at SocketHttpListener.Net.HttpListenerRequest.get_RemoteEndPoint () [0x0000b] in <d1e44c6b1e034cc2a5f3455bdd51f2c0>:0 at Emby.Server.SocketSharp.WebSocketSharpRequest.get_RemoteSocketIpAddress () [0x00000] in <fe302e1278c240688ead3a03b2058b68>:0 at Emby.Server.Implementations.HttpServer.BaseRequest.InitRemoteConnectionInfo () [0x0001d] in <d4fc00bd55c04377898945f42c216e82>:0 at Emby.Server.SocketSharp.WebSocketSharpListener.InitTask (SocketHttpListener.Net.HttpListenerContext context, System.Threading.CancellationToken cancellationToken) [0x0006a] in <fe302e1278c240688ead3a03b2058b68>:0 Source: System TargetSite: System.Net.EndPoint get_RemoteEndPoint()
The.doctor 1 Posted March 15, 2024 Author Posted March 15, 2024 Happy2Play, Thanks for taking a look! Hopefully Luke or another Dev will have a solution.
Luke 42237 Posted March 15, 2024 Posted March 15, 2024 For the server running on this NAS you probably want to focus your playback on files that can direct play without any server transcoding. This NAS just does not have the horsepower to transcode on the fly.
The.doctor 1 Posted March 15, 2024 Author Posted March 15, 2024 Luke, I am confused. I thought that transcoding only happened when a video was being played. No one is playing anything. The server is not accessible. As of this morning, WD says that Run App is ON, but I no longer see it in running processes, and the fan and CPU have dropped to normal operation. I have not tried to restart it, yet. Is there any other information I can supply that would help diagnosis the problem? Do you have the proper procedure for doing a clean installation?
Solution Luke 42237 Posted March 15, 2024 Solution Posted March 15, 2024 The transcode might have been coming from either the convert media feature or download feature so check the Conversions section of the server dashboard as well as the Downloads section and cancel any jobs if need be.
Luke 42237 Posted March 15, 2024 Posted March 15, 2024 Quote Do you have the proper procedure for doing a clean installation? I don't think this is your solution. Better to understand what's going on because if you repeat the same setup then you'll just end up in the same place.
The.doctor 1 Posted March 15, 2024 Author Posted March 15, 2024 Luke, I rebooted the App and it came back. There was nothing under Conversions. There were some things under Downloads that I deleted. I have attached a new Emby log. embyserver.txt
The.doctor 1 Posted March 16, 2024 Author Posted March 16, 2024 Luke, I think you found the problem. When I cleared the downloads, things returned to normal. It appears that is where the problem was. The fan and CPU are acting as they should. Something to take note of if anyone else experiences the same issue. I appreciate your and Happy2Play’s assistance. Thank you! 1
