ebr 16333 Posted March 15, 2024 Posted March 15, 2024 2 hours ago, chrisrobbins1970 said: I sent a LOG this morning 839am EST. I have a Roku Ultra that I did MOVIES tab # - Z and I let it go for nearly 30mins and it never progressed. It froze so I got out of emby and sent the log. This is the one thing that is hesitating me to let my family and freinds who ALL use rokus go striaght Emby. If this can be figured out..BOOM all emby users.. please help The only difference that I know of is the three Rokus ultras I have the ONE I use is newer 2022 model and the others are 2019 models. That is the only difference How many items in the view?
chrisrobbins1970 82 Posted March 15, 2024 Author Posted March 15, 2024 5827..in movies TAB and folders TAB this roku is ethernet connected has well
chrisrobbins1970 82 Posted March 18, 2024 Author Posted March 18, 2024 ..any ideas? are the devs looking into this issue for the rokus ?? If you need testing for a new build I can install and let you know ?
Gilgamesh_48 1243 Posted March 18, 2024 Posted March 18, 2024 3 hours ago, chrisrobbins1970 said: ..any ideas? are the devs looking into this issue for the rokus ?? If you need testing for a new build I can install and let you know ? I would say that the fact that @ebr@Lukeand @speechleshave all said they are looking into it and/or it is on their radar says that they are looking into it. Those, at least as far as these forums go, are three of the main developers and generally, if they say they are working on something whatever it is gets fixed or at least changed fairly soon. I hope you have better luck getting your alphapicker working correctly than I have had getting it fixed for photos in browsers. It just seems that Emby thinks I am lying when I report that it simply does not work in browsers. Dear Emby, I am NOT lying and the alpha picker does not work in browsers for posters.
Luke 42239 Posted March 19, 2024 Posted March 19, 2024 10 hours ago, chrisrobbins1970 said: ..any ideas? are the devs looking into this issue for the rokus ?? If you need testing for a new build I can install and let you know ? Hi, yes we are looking into it. Thanks.
chrisrobbins1970 82 Posted March 27, 2024 Author Posted March 27, 2024 hmm.. i just noticed something.. LUKE as asked this before, but 5860..in movies TAB and folders TAB shows 5861 ?? one extra of something?
chrisrobbins1970 82 Posted April 21, 2024 Author Posted April 21, 2024 Any updates on... Reference: Issue #1573: [PosterGridView] Alphapicker jumping takes extraneous amount of time to complete and can also hang and lose focus This has been a problem with my family and friends who are on Roku's... the work around has been to change the movie SORT to filename so the alphapicker does not show and use the FASTFORWARD on the remote to skip through movie selections. For a movie collection of nearly 6000 movies this takes awhile to get through.. but I understnad that there might not be anything that can be done because its Roku OS may not let you... Just wondered if there were any updates?
ebr 16333 Posted April 21, 2024 Posted April 21, 2024 1 hour ago, chrisrobbins1970 said: Any updates on... Reference: Issue #1573: [PosterGridView] Alphapicker jumping takes extraneous amount of time to complete and can also hang and lose focus This has been a problem with my family and friends who are on Roku's... the work around has been to change the movie SORT to filename so the alphapicker does not show and use the FASTFORWARD on the remote to skip through movie selections. For a movie collection of nearly 6000 movies this takes awhile to get through.. but I understnad that there might not be anything that can be done because its Roku OS may not let you... Just wondered if there were any updates? Nothing beyond what has already been implemented in the beta I'm afraid.
