Scoobz 2 Posted March 10, 2024 Posted March 10, 2024 I am wondering if i can ask for some assistance. I have a problem with audio drifting out of sync on video files when using the internal player, no matter what options i try. All is fine if i use VLC as an external player. Windows 10 conencted via HDMI to amp, haver tried exclusive mode, and turned on and off passthrough but seems to drop out of sync. Open to suggestions on where to look for the problem. Thanks in advance S
Luke 42235 Posted March 10, 2024 Posted March 10, 2024 Hi there, let's look at an example. Please attach the information requested in how to report a media playback issue. Thanks!
Scoobz 2 Posted March 11, 2024 Author Posted March 11, 2024 (edited) please see attached the log files. really appreciate you helping me try and work this out 2024-03-11 13:23:41 this is when playback starts embyserver.txt Edited March 11, 2024 by Scoobz
rbjtech 5341 Posted March 11, 2024 Posted March 11, 2024 have you looked at changing the setting for 'Enable Video display Sync' ? In the Emby Theater > Video > Advanced settings (should possibly be in Audio section tbh as it relates to Audio ..)
Scoobz 2 Posted March 11, 2024 Author Posted March 11, 2024 thanks for the suggestion, was set to Auto, tried both option but audio still not in sync
Luke 42235 Posted March 11, 2024 Posted March 11, 2024 HI, that's odd, but stay tuned because we have a new windows app coming very soon for you to try. Thanks.
Guest Posted March 12, 2024 Posted March 12, 2024 (edited) 9 hours ago, Scoobz said: thanks for the suggestion, was set to Auto, tried both option but audio still not in sync If you're using audio passthrough, you'll have to use vdrop, the other options will silently be disabled. Can you post a screenshot of your stats when you experience audio drift? Edited March 12, 2024 by generiq
