Vodalex 2 Posted March 10, 2024 Posted March 10, 2024 Hello! I am using CoreELEC with the Emby next gen addon and with Emby server installed on separate Hardware (Odroid M1) After updating CoreELEC to version 20.5 I can see the movies with the progress bar but no cover anymore. but when I try to play them the system says it cannot start the playback. How can I fix it without reinstalling Kodi completely? Sincerely yours, Alexander
Vodalex 2 Posted March 11, 2024 Author Posted March 11, 2024 Thank you for your answer! Can you tell me how to grab it over SMB? I found a folder Logfiles and copied the log file from there. Is it of any use? log-2024-03-11-17.07.46.zip
quickmic 1709 Posted March 11, 2024 Posted March 11, 2024 4 minutes ago, Vodalex said: Thank you for your answer! Can you tell me how to grab it over SMB? I found a folder Logfiles and copied the log file from there. Is it of any use? log-2024-03-11-17.07.46.zip 2.52 MB · 0 downloads 2024-03-09 22:13:24.680 T:4401 warning <general>: EMBY.hooks.webservice: Emby ServerId not found 8f65f46b9fd044a285052784152e5998 Did you try a factory reset?
Vodalex 2 Posted March 11, 2024 Author Posted March 11, 2024 Here another log.. I can try a factory reset of the addon if you tell me so.. kodi.log
quickmic 1709 Posted March 11, 2024 Posted March 11, 2024 (edited) 1 hour ago, Vodalex said: Here another log.. I can try a factory reset of the addon if you tell me so.. kodi.log 63.47 kB · 0 downloads This log looks clean to me, but yes try a factory reset. Obviously something is wrong in your setup. I hope you didn't try a KODI beta upgrade, and rolled back to KODI stable. This will mess up your config and even a factory reset will not fix the issue. Edited March 11, 2024 by quickmic 1
Vodalex 2 Posted March 11, 2024 Author Posted March 11, 2024 This is exactly what I did. Had a beta and now on 20.5 stable. Time to full reset of kodi! Thank you for this advice! Now I know why it is not working anymore!
Solution quickmic 1709 Posted March 11, 2024 Solution Posted March 11, 2024 22 minutes ago, Vodalex said: This is exactly what I did. Had a beta and now on 20.5 stable. Time to full reset of kodi! Thank you for this advice! Now I know why it is not working anymore! You need to stop Kodi, delete ...../userdata/Database/MyMusic*, ...../userdata/Database/MyVideo*, ...../userdata/Database/Textures*, ...../userdata/Database/Epg*, ...../userdata/Database/emby_* manually. KEEP AddonsXX.db and ViewModesXX.db Then start Kodi and perform a sync. 1
Vodalex 2 Posted March 11, 2024 Author Posted March 11, 2024 Thank you! This was the solution! I performed the steps and it fixed the problems. Now I see all the movies and can play them. Have a nice evening and thank you for your help! 1
