Leinad86 6 Posted March 9, 2024 Posted March 9, 2024 (edited) Hello everyone, I have exactly the same problem. Some users report that films/series start to buffer shortly after starting. The strange thing is that sometimes the problems occur and sometimes they don't. Yesterday evening I was able to recreate the problem after a report from a user, and this morning the series is running without any problems. If you play the film/series without transcoding there are no problems. What I also noticed is that when you look on the dashboard, the orange bar for the transcoding progress is completely filled! Attach 2 logs and 2 pictures. It also started for me after I updated to Emby 4.8.1.0. Unraid 6.12.6 Emby 4.8.3.0 Transkoding Temp is a NVME GPU RTX 4000 Ryzen 5700x 64GB Ram Many thanks in advance embyserver-63845566167.txt ffmpeg-transcode-17dc4851-90e1-47bd-a226-3b4b9a050e95_1.txt ffmpeg-transcode-4683450c-5ea8-4de7-b94f-791fa2d3d996_1.txt Edited March 9, 2024 by Leinad86
Luke 42255 Posted March 9, 2024 Posted March 9, 2024 @Leinad86that'd odd. can you try setting the transcode temp folder back to default and see how things compare? thanks.
Leinad86 6 Posted March 9, 2024 Author Posted March 9, 2024 Hi Luke, thanks for the quick reply. I deleted everything in the transcoding settings, it should just be default. Unfortunately the same. 08:14:24.113 Too many packets buffered for output stream 1:1. 08:14:24.133 [libmp3lame @ 0x1154080] 3 frames left in the queue on closing 08:14:24.256 Conversion failed! 08:14:24.256 EXIT The orange bar on the dashboard is complete again. It's just strange that the series runs without buffering! That's what I mean, sometimes it doesn't buffer! ffmpeg-transcode-28be56e6-f34f-4bf7-9e61-047f4d8ed093_1.txt
JoLas 26 Posted March 11, 2024 Posted March 11, 2024 Try disabling hardware transcoding. It's not a good fix but it's worth a try. I have some weird intermittent buffering issues and subtitle issues that only appears when using hardware transcoding.
Leinad86 6 Posted March 12, 2024 Author Posted March 12, 2024 Since the update to 4.8.1 everything has been strange! I've tried turning off HW. Unfortunately the result is the same. Here is the log ffmpeg-transcode-48eb64e0-cc1d-40a8-9da9-01ef79546b56_1 .txt
Leinad86 6 Posted March 12, 2024 Author Posted March 12, 2024 Now there are new problems. Can't play 2 movies here. 07:36:46.483 [h264 @ 0xff9b80] Error splitting the input into NAL units. 07:36:46.483 [h264 @ 0xff9b80] Invalid NAL unit size (0 > 36229). As soon as I switch to direct play everything works. ffmpeg-transcode-a493c789-460e-4f7b-9571-833c926aef12_1.txt
Leinad86 6 Posted March 12, 2024 Author Posted March 12, 2024 I have now loaded the Emby Server Beta Docker from Unraid. Quickly set up and the films that don't run with normal Docker work wonderfully here. I'm attaching two more logs. Each from the two servers. Both run on the same hardware. I still have to test the series that doesn't work. Now the question for me is whether I should switch my main Emby installation to beta! Or is there a fix coming soon? ffmpeg-transcode-d7906b7e-abff-4652-895a-fa7e8e0a7e63_1.txt ffmpeg-transcode-a3476fcc-7572-468a-85a1-6211de9f6e04_1.txt
Luke 42255 Posted March 16, 2024 Posted March 16, 2024 On 3/12/2024 at 4:06 AM, Leinad86 said: I have now loaded the Emby Server Beta Docker from Unraid. Quickly set up and the films that don't run with normal Docker work wonderfully here. I'm attaching two more logs. Each from the two servers. Both run on the same hardware. I still have to test the series that doesn't work. Now the question for me is whether I should switch my main Emby installation to beta! Or is there a fix coming soon? ffmpeg-transcode-d7906b7e-abff-4652-895a-fa7e8e0a7e63_1.txt 153.4 kB · 1 download ffmpeg-transcode-a3476fcc-7572-468a-85a1-6211de9f6e04_1.txt 7.82 MB · 1 download These two comparisons are different files though, or at least different file paths. Can you provide a comparison from the same file? Thanks.
Leinad86 6 Posted March 19, 2024 Author Posted March 19, 2024 (edited) I have now installed Emby 4.7.14.0 as a test. Can someone tell me why HW transcoding works without problems here and not in 4.8.3.0? What can I do to make it work again without problems? It doesn't happen in every film, just in some. The same with series. And whenever a problem arises, the transcoding progress display on the dashboard jumps to full. Sometimes the film continues to run without any problems and sometimes it starts to buffer. The same thing happens with different films/series. Unfortunately I don't see any pattern. The logs always look the same. Do you need more? Emby_4.7.14.0.txt Emby_4.8.3.0.txt Edited March 19, 2024 by Leinad86
Leinad86 6 Posted March 19, 2024 Author Posted March 19, 2024 Here's another example with a series Emby_4.7.14.0.txt Emby_4.8.3.0.txt
visproduction 336 Posted March 19, 2024 Posted March 19, 2024 Related: https://superuser.com/questions/1315664/why-ffmpeg-increases-file-size Slight changes either in Emby encoding settings or how ffmpeg makes lossy copies of already lossy media can cause Invalid NAL unit size. Some encoding issues in a video may cause ffmpeg to not handle encoding at the preferred user setting and then automatically changing the encoding to a lower quality to compensate may also fail on media that has prerecorded encoding issues. The best way to rule out such encoding issues is to use a test video and not rely on random encoded videos. --- Related issue solved: https://github.com/mpv-player/mpv/issues/11268 Quote lavara123 commented on Feb 11, 2023 Do you get the same error if you use https instead of http? That would rule out your ISP dropping packets. yes, that's the problem, why is it such a ________?
Leinad86 6 Posted March 19, 2024 Author Posted March 19, 2024 Yes, something has been changed, unfortunately I personally don't have the understanding to find out what exactly and where the problem lies. I can only say that with V 4.7.14.0 everything worked without any problems.
Leinad86 6 Posted March 21, 2024 Author Posted March 21, 2024 Does no one have any idea what could be the problem? Will the problem be solved in the near future?
Leinad86 6 Posted March 25, 2024 Author Posted March 25, 2024 Can someone give me some information here? A we have no idea where the error is is better than no answer. Thanks
Happy2Play 9814 Posted March 25, 2024 Posted March 25, 2024 Suggests TranscodingPosition is broke in 4.8. But the devs will have to look at. From logs above 4.8 C:\Users\Media\Downloads\Emby_4.8.3.0.txt (8 hits) Line 298: >> ThrottleBySegmentRequest: RequestPosition: 00:00:39 - TranscodingPosition: 00:00:00 - ThrottleBuffer: -39s (Treshold: 120s) Line 472: >> ThrottleBySegmentRequest: RequestPosition: 00:01:33 - TranscodingPosition: 00:00:00 - ThrottleBuffer: -93s (Treshold: 120s) Line 657: >> ThrottleBySegmentRequest: RequestPosition: 00:02:27 - TranscodingPosition: 00:00:00 - ThrottleBuffer: -147s (Treshold: 120s) Line 831: >> ThrottleBySegmentRequest: RequestPosition: 00:03:18 - TranscodingPosition: 00:00:00 - ThrottleBuffer: -198s (Treshold: 120s) Line 1014: >> ThrottleBySegmentRequest: RequestPosition: 00:03:48 - TranscodingPosition: 00:00:00 - ThrottleBuffer: -228s (Treshold: 120s) Line 1194: >> ThrottleBySegmentRequest: RequestPosition: 00:03:51 - TranscodingPosition: 00:00:00 - ThrottleBuffer: -231s (Treshold: 120s) Line 1379: >> ThrottleBySegmentRequest: RequestPosition: 00:03:54 - TranscodingPosition: 00:00:00 - ThrottleBuffer: -234s (Treshold: 120s) Line 1565: >> ThrottleBySegmentRequest: RequestPosition: 00:03:54 - TranscodingPosition: 00:00:00 - ThrottleBuffer: -234s (Treshold: 120s) 4.7 C:\Users\Media\Downloads\Emby_4.7.14.0.txt (62 hits) Line 499: >> ThrottleBySegmentRequest: RequestPosition: 00:01:15 - TranscodingPosition: 00:01:09 - ThrottleBuffer: -5s (Treshold: 120s) Line 900: >> ThrottleBySegmentRequest: RequestPosition: 00:02:03 - TranscodingPosition: 00:02:51 - ThrottleBuffer: 49s (Treshold: 120s) Line 1295: >> ThrottleBySegmentRequest: RequestPosition: 00:02:03 - TranscodingPosition: 00:04:27 - ThrottleBuffer: 145s (Treshold: 120s) Line 1321: >> ThrottleBySegmentRequest: RequestPosition: 00:02:06 - TranscodingPosition: 00:04:49 - ThrottleBuffer: 163s (Treshold: 120s) Line 1326: >> ThrottleBySegmentRequest: RequestPosition: 00:02:09 - TranscodingPosition: 00:04:49 - ThrottleBuffer: 160s (Treshold: 120s) Line 1331: >> ThrottleBySegmentRequest: RequestPosition: 00:02:09 - TranscodingPosition: 00:04:49 - ThrottleBuffer: 161s (Treshold: 120s) Line 1336: >> ThrottleBySegmentRequest: RequestPosition: 00:02:12 - TranscodingPosition: 00:04:50 - ThrottleBuffer: 158s (Treshold: 120s) Line 1341: >> ThrottleBySegmentRequest: RequestPosition: 00:02:15 - TranscodingPosition: 00:04:50 - ThrottleBuffer: 156s (Treshold: 120s) Line 1346: >> ThrottleBySegmentRequest: RequestPosition: 00:02:15 - TranscodingPosition: 00:04:50 - ThrottleBuffer: 156s (Treshold: 120s) Line 1351: >> ThrottleBySegmentRequest: RequestPosition: 00:02:18 - TranscodingPosition: 00:04:51 - ThrottleBuffer: 153s (Treshold: 120s) Line 1359: >> ThrottleBySegmentRequest: RequestPosition: 00:02:21 - TranscodingPosition: 00:04:51 - ThrottleBuffer: 151s (Treshold: 120s) Line 1367: >> ThrottleBySegmentRequest: RequestPosition: 00:02:21 - TranscodingPosition: 00:04:51 - ThrottleBuffer: 151s (Treshold: 120s)
Luke 42255 Posted March 28, 2024 Posted March 28, 2024 On 3/25/2024 at 1:02 PM, Happy2Play said: Suggests TranscodingPosition is broke in 4.8. But the devs will have to look at. From logs above 4.8 C:\Users\Media\Downloads\Emby_4.8.3.0.txt (8 hits) Line 298: >> ThrottleBySegmentRequest: RequestPosition: 00:00:39 - TranscodingPosition: 00:00:00 - ThrottleBuffer: -39s (Treshold: 120s) Line 472: >> ThrottleBySegmentRequest: RequestPosition: 00:01:33 - TranscodingPosition: 00:00:00 - ThrottleBuffer: -93s (Treshold: 120s) Line 657: >> ThrottleBySegmentRequest: RequestPosition: 00:02:27 - TranscodingPosition: 00:00:00 - ThrottleBuffer: -147s (Treshold: 120s) Line 831: >> ThrottleBySegmentRequest: RequestPosition: 00:03:18 - TranscodingPosition: 00:00:00 - ThrottleBuffer: -198s (Treshold: 120s) Line 1014: >> ThrottleBySegmentRequest: RequestPosition: 00:03:48 - TranscodingPosition: 00:00:00 - ThrottleBuffer: -228s (Treshold: 120s) Line 1194: >> ThrottleBySegmentRequest: RequestPosition: 00:03:51 - TranscodingPosition: 00:00:00 - ThrottleBuffer: -231s (Treshold: 120s) Line 1379: >> ThrottleBySegmentRequest: RequestPosition: 00:03:54 - TranscodingPosition: 00:00:00 - ThrottleBuffer: -234s (Treshold: 120s) Line 1565: >> ThrottleBySegmentRequest: RequestPosition: 00:03:54 - TranscodingPosition: 00:00:00 - ThrottleBuffer: -234s (Treshold: 120s) 4.7 C:\Users\Media\Downloads\Emby_4.7.14.0.txt (62 hits) Line 499: >> ThrottleBySegmentRequest: RequestPosition: 00:01:15 - TranscodingPosition: 00:01:09 - ThrottleBuffer: -5s (Treshold: 120s) Line 900: >> ThrottleBySegmentRequest: RequestPosition: 00:02:03 - TranscodingPosition: 00:02:51 - ThrottleBuffer: 49s (Treshold: 120s) Line 1295: >> ThrottleBySegmentRequest: RequestPosition: 00:02:03 - TranscodingPosition: 00:04:27 - ThrottleBuffer: 145s (Treshold: 120s) Line 1321: >> ThrottleBySegmentRequest: RequestPosition: 00:02:06 - TranscodingPosition: 00:04:49 - ThrottleBuffer: 163s (Treshold: 120s) Line 1326: >> ThrottleBySegmentRequest: RequestPosition: 00:02:09 - TranscodingPosition: 00:04:49 - ThrottleBuffer: 160s (Treshold: 120s) Line 1331: >> ThrottleBySegmentRequest: RequestPosition: 00:02:09 - TranscodingPosition: 00:04:49 - ThrottleBuffer: 161s (Treshold: 120s) Line 1336: >> ThrottleBySegmentRequest: RequestPosition: 00:02:12 - TranscodingPosition: 00:04:50 - ThrottleBuffer: 158s (Treshold: 120s) Line 1341: >> ThrottleBySegmentRequest: RequestPosition: 00:02:15 - TranscodingPosition: 00:04:50 - ThrottleBuffer: 156s (Treshold: 120s) Line 1346: >> ThrottleBySegmentRequest: RequestPosition: 00:02:15 - TranscodingPosition: 00:04:50 - ThrottleBuffer: 156s (Treshold: 120s) Line 1351: >> ThrottleBySegmentRequest: RequestPosition: 00:02:18 - TranscodingPosition: 00:04:51 - ThrottleBuffer: 153s (Treshold: 120s) Line 1359: >> ThrottleBySegmentRequest: RequestPosition: 00:02:21 - TranscodingPosition: 00:04:51 - ThrottleBuffer: 151s (Treshold: 120s) Line 1367: >> ThrottleBySegmentRequest: RequestPosition: 00:02:21 - TranscodingPosition: 00:04:51 - ThrottleBuffer: 151s (Treshold: 120s) What do you see in 4.9?
Happy2Play 9814 Posted March 28, 2024 Posted March 28, 2024 (edited) 41 minutes ago, Luke said: What do you see in 4.9? It appears to be working fine for me on 4.8/4.9 on Windows. As what I posted came from the Unix 6.1.74.0 logs above. Spoiler 21:06:03.893 elapsed=00:00:48.59 frame= 6484 fps=133 q=19.0 size=N/A time=00:04:30.38 bitrate=N/A throttle=100 speed=5.56x 21:06:04.446 elapsed=00:00:49.14 frame= 6485 fps=132 q=15.0 size=N/A time=00:04:30.43 bitrate=N/A throttle=100 speed= 5.5x >> ThrottleBySegmentRequest: RequestPosition: 00:02:33 - TranscodingPosition: 00:04:30 - ThrottleBuffer: 117s (Treshold: 120s) Enter throttle value: <int, ms wait per input cycle> (0 to disable) Disable throttling 21:06:04.954 elapsed=00:00:49.70 frame= 6486 fps=130 q=19.0 size=N/A time=00:04:30.48 bitrate=N/A throttle=off speed=5.44x 21:06:04.958 [segment @ 0000021821366800] Opening 'C:\Users\Media\Desktop\TEST\programdata\transcoding-temp\7ACF91\7ACF91.m3u8.tmp' for writing 21:06:04.966 SegmentComplete=video:0 Index=89 Start=267.308700 End=270.311700 Duration=3.003000 offset_pts=0 start_pts=267308700 Frames=72 filename=7ACF91_89.ts 21:06:04.966 [segment @ 0000021821366800] Opening 'C:\Users\Media\Desktop\TEST\programdata\transcoding-temp\7ACF91\7ACF91_90.ts.tmp' for writing 21:06:05.231 [segment @ 0000021821366800] Opening 'C:\Users\Media\Desktop\TEST\programdata\transcoding-temp\7ACF91\7ACF91.m3u8.tmp' for writing 21:06:05.240 SegmentComplete=video:0 Index=90 Start=270.311700 End=273.314700 Duration=3.003000 offset_pts=0 start_pts=270311700 Frames=72 filename=7ACF91_90.ts 21:06:05.240 [segment @ 0000021821366800] Opening 'C:\Users\Media\Desktop\TEST\programdata\transcoding-temp\7ACF91\7ACF91_91.ts.tmp' for writing 21:06:05.392 elapsed=00:00:50.20 frame= 6605 fps=132 q=11.0 size=N/A time=00:04:35.44 bitrate=N/A throttle=off speed=5.49x 21:06:05.485 [segment @ 0000021821366800] Opening 'C:\Users\Media\Desktop\TEST\programdata\transcoding-temp\7ACF91\7ACF91.m3u8.tmp' for writing 21:06:05.495 SegmentComplete=video:0 Index=91 Start=273.314700 End=276.317700 Duration=3.003000 offset_pts=0 start_pts=273314700 Frames=72 filename=7ACF91_91.ts 21:06:05.495 [segment @ 0000021821366800] Opening 'C:\Users\Media\Desktop\TEST\programdata\transcoding-temp\7ACF91\7ACF91_92.ts.tmp' for writing 21:06:05.734 [segment @ 0000021821366800] Opening 'C:\Users\Media\Desktop\TEST\programdata\transcoding-temp\7ACF91\7ACF91.m3u8.tmp' for writing 21:06:05.744 SegmentComplete=video:0 Index=92 Start=276.317700 End=279.320700 Duration=3.003000 offset_pts=0 start_pts=276317700 Frames=72 filename=7ACF91_92.ts 21:06:05.744 [segment @ 0000021821366800] Opening 'C:\Users\Media\Desktop\TEST\programdata\transcoding-temp\7ACF91\7ACF91_93.ts.tmp' for writing 21:06:05.890 elapsed=00:00:50.70 frame= 6745 fps=133 q=14.0 size=N/A time=00:04:41.28 bitrate=N/A throttle=off speed=5.55x 21:06:06.008 [segment @ 0000021821366800] Opening 'C:\Users\Media\Desktop\TEST\programdata\transcoding-temp\7ACF91\7ACF91.m3u8.tmp' for writing 21:06:06.016 SegmentComplete=video:0 Index=93 Start=279.320700 End=282.323700 Duration=3.003000 offset_pts=0 start_pts=279320700 Frames=72 filename=7ACF91_93.ts 21:06:06.016 [segment @ 0000021821366800] Opening 'C:\Users\Media\Desktop\TEST\programdata\transcoding-temp\7ACF91\7ACF91_94.ts.tmp' for writing 21:06:06.289 [segment @ 0000021821366800] Opening 'C:\Users\Media\Desktop\TEST\programdata\transcoding-temp\7ACF91\7ACF91.m3u8.tmp' for writing 21:06:06.296 SegmentComplete=video:0 Index=94 Start=282.323700 End=285.326700 Duration=3.003000 offset_pts=0 start_pts=282323700 Frames=72 filename=7ACF91_94.ts 21:06:06.296 [segment @ 0000021821366800] Opening 'C:\Users\Media\Desktop\TEST\programdata\transcoding-temp\7ACF91\7ACF91_95.ts.tmp' for writing 21:06:06.391 elapsed=00:00:51.20 frame= 6874 fps=134 q=19.0 size=N/A time=00:04:46.68 bitrate=N/A throttle=off speed= 5.6x 21:06:06.563 [segment @ 0000021821366800] Opening 'C:\Users\Media\Desktop\TEST\programdata\transcoding-temp\7ACF91\7ACF91.m3u8.tmp' for writing 21:06:06.571 SegmentComplete=video:0 Index=95 Start=285.326700 End=288.329700 Duration=3.003000 offset_pts=0 start_pts=285326700 Frames=72 filename=7ACF91_95.ts 21:06:06.571 [segment @ 0000021821366800] Opening 'C:\Users\Media\Desktop\TEST\programdata\transcoding-temp\7ACF91\7ACF91_96.ts.tmp' for writing >> ThrottleBySegmentRequest: RequestPosition: 00:02:33 - TranscodingPosition: 00:04:46 - ThrottleBuffer: 134s (Treshold: 120s) Enter throttle value: <int, ms wait per input cycle> (0 to disable) Setting throttle value to 100 ms 21:06:07.101 elapsed=00:00:51.80 frame= 6984 fps=135 q=20.0 size=N/A time=00:04:51.26 bitrate=N/A throttle=100 speed=5.62x 21:06:07.654 elapsed=00:00:52.35 frame= 6985 fps=133 q=16.0 size=N/A time=00:04:51.31 bitrate=N/A throttle=100 speed=5.56x Edited March 28, 2024 by Happy2Play
Leinad86 6 Posted March 28, 2024 Author Posted March 28, 2024 The problem doesn't exist with every film/Episode , just with some. I'm attaching a sample. I always have problems with this episode in 4.8. In 4.7 it runs without problems Chicago Med - S02E11 - Graveyard Shift - WEBDL-1080p (1)-001.mkv
Happy2Play 9814 Posted March 28, 2024 Posted March 28, 2024 (edited) Devs will have to analyze that file but would assume there is something wrong with the encoding as I get no "RequestPosition". Could be to small of a clip though. Reprocess clip and throttle was not able to kick in on such a short file. Edited March 28, 2024 by Happy2Play
Happy2Play 9814 Posted March 28, 2024 Posted March 28, 2024 Playing one of my episodes it looks like Throttle kicked in after processing 12 minutes. 1
Leinad86 6 Posted March 28, 2024 Author Posted March 28, 2024 Hope it's okay if I share a OneDrive link with the complete episode. Emby – OneDrive (live.com)
Leinad86 6 Posted March 28, 2024 Author Posted March 28, 2024 @Happy2Play What kind of Dashboard is this? Ive never seen this bevore.
pwhodges 2036 Posted March 28, 2024 Posted March 28, 2024 You need the Diagnostics plugin installed to have the User Sessions page of the dashboard. Paul
visproduction 336 Posted March 30, 2024 Posted March 30, 2024 MP4 stream 1.3 mbps --> HLS 720 kbps 380 fps 380 frames per second?? Corrupt metadata in the video? Related: https://stackoverflow.com/questions/13565062/fps-too-high-when-saving-video-in-mp4-container
