someperson 3 Posted March 8, 2024 Posted March 8, 2024 Here in Houston, there is an audio-only channel on 8.5, but it does not play in Emby from my HDHomeRun. I have attached the ffmpeg log. ffmpeg-transcode-10f82dd5-46c2-4643-8275-b96c1c9c6976_1.txt
Luke 42241 Posted March 10, 2024 Posted March 10, 2024 HI there, please attach the main emby server log as well. thanks.
someperson 3 Posted April 14, 2024 Author Posted April 14, 2024 Attached logs ffmpeg-transcode-c741e65b-5aae-4aef-aabc-f291f88f1b31_1.txt ffmpeg-transcode-32e29568-7b94-4c74-b82a-7e4e4b2bb24e_1.txt ffmpeg-transcode-5a92e5be-7af5-4c02-9d39-c34f1fe5469c_1.txt ffmpeg-transcode-ff189c22-0c3f-4d00-942e-783361542910_1.txt ffmpeg-transcode-801fec17-3716-45b2-a501-984957cf166d_1.txt ffmpeg-transcode-2f4a84d4-4227-428a-ac49-3e616fb2afdf_1.txt embyserver.txt
someperson 3 Posted April 27, 2024 Author Posted April 27, 2024 It's an HDHomeRun Connect Quatro, model number HDHR5-4US.
Luke 42241 Posted May 13, 2024 Posted May 13, 2024 hi @somepersonhave you updated to Emby Server 4.8.6? Has that helped?
someperson 3 Posted May 14, 2024 Author Posted May 14, 2024 19 hours ago, Luke said: hi @somepersonhave you updated to Emby Server 4.8.6? Has that helped? This is still a problem in 4.8.6.
Luke 42241 Posted June 1, 2024 Posted June 1, 2024 HI, please let us know if Emby Server 4.8.8 helps with this issue. Thanks.
