Trelane 38 Posted March 8, 2024 Posted March 8, 2024 Hi, Is there a method to remove the old FireTV beta app from my account? I am stuck with both the regular and test versions anytime I install either one. The two icons for each are stuck together. If i install one, it installs the icons for both, if i move/pin one in the hotbar in the FireTV interface it moves/pins both. Thank you
ebr 16337 Posted March 8, 2024 Posted March 8, 2024 Perhaps ask Amazon because we no longer have anyone listed in the beta program and don't use it on that platform.
Trelane 38 Posted March 8, 2024 Author Posted March 8, 2024 (edited) 22 minutes ago, ebr said: Perhaps ask Amazon because we no longer have anyone listed in the beta program and don't use it on that platform. Ok I guess I can give that a try.. I figured they would have no idea what I'm talking about, and tell me to contact the app owner.. Here is the problem: I think you are right tho, as when I delete it from my account it re-appears.. so I think this is bugged on my account somehow. I'll see what they tell me. Thank you. Edited March 8, 2024 by SeanM
Solution Trelane 38 Posted March 8, 2024 Author Solution Posted March 8, 2024 Just to button this up. Issue is resolved. Amazon was able to fix it on their end. No more duplicate entry. 2
