Marco3G 6 Posted March 8, 2024 Posted March 8, 2024 (edited) Hi everyone I'm trying to make my emby reachable from the web. I get error 502 Bad Gateway currently, which is no wonder: Quote user@emby:~$ sudo ss -tulpn | grep LISTEN tcp LISTEN 0 4096 0.0.0.0:35939 0.0.0.0:* users:(("rpc.statd",pid=946,fd=9)) tcp LISTEN 0 64 0.0.0.0:41897 0.0.0.0:* tcp LISTEN 0 4096 0.0.0.0:111 0.0.0.0:* users:(("rpcbind",pid=754,fd=4),("systemd",pid=1,fd=47)) tcp LISTEN 0 4096 127.0.0.53%lo:53 0.0.0.0:* users:(("systemd-resolve",pid=809,fd=14)) tcp LISTEN 0 128 0.0.0.0:22 0.0.0.0:* users:(("sshd",pid=888,fd=3)) tcp LISTEN 0 512 *:8096 *:* users:(("EmbyServer",pid=161350,fd=208)) tcp LISTEN 0 4096 [::]:58881 [::]:* users:(("rpc.statd",pid=946,fd=11)) tcp LISTEN 0 4096 [::]:111 [::]:* users:(("rpcbind",pid=754,fd=6),("systemd",pid=1,fd=49)) tcp LISTEN 0 128 [::]:22 [::]:* users:(("sshd",pid=888,fd=4)) tcp LISTEN 0 64 [::]:39709 [::]:* It does not listen on 8920. Under network settings, I have set the domain name, allow remote conenctions and I've tried both Requires for all remote connections and Handled by reverse proxy for Secure connection mode There is just no listener on 8920. Do I need to give emby a self signed certificate? NGINX already has a LetsEncrypt cert for the subdomain I want to use. embyserver(5).txt Edited March 8, 2024 by Marco3G
Marco3G 6 Posted March 8, 2024 Author Posted March 8, 2024 I just found another thread where Luke says the reverse proxy should forward to the http port. That works. So never mind
Luke 42244 Posted March 8, 2024 Posted March 8, 2024 1 hour ago, Marco3G said: I just found another thread where Luke says the reverse proxy should forward to the http port. That works. So never mind HI, a reverse proxy is not required but it can help. Are you all set now? Quote There is just no listener on 8920. Do I need to give emby a self signed certificate? NGINX already has a LetsEncrypt cert for the subdomain I want to use. Yes you need to setup https before you can use it.
Marco3G 6 Posted March 8, 2024 Author Posted March 8, 2024 How is a reverse proxy not required? I mean sure, I could forward the ports and manually create a LetsEncrypt certificate to feed Emby but then I'd either have to enter the port every single time and keep it in mind or forward 443 and then I couldn't use any other service on 443. I've been looking around but so far I haven't found a proper guide on how to do that. I'm assuming I could use a sef-signed certificate for Emby on my internal network and use https like that. Would I have to manually generate that with openssl?
Luke 42244 Posted March 8, 2024 Posted March 8, 2024 Quote I've been looking around but so far I haven't found a proper guide on how to do that. I'm assuming I could use a sef-signed certificate for Emby on my internal network and use https like that. Would I have to manually generate that with openssl? Just keep in mind that not all devices accept self-signed certs, so you may get connection errors. But try it and see how it goes for you.
Marco3G 6 Posted March 8, 2024 Author Posted March 8, 2024 It would only be when connecting to the internal dmz domain name instead of going through the internet. I can live with that. However what I cannot live with is PKCS#12. I have no idea how that works and every guide so far fell flat on my system.
Solution Lessaj 484 Posted March 8, 2024 Solution Posted March 8, 2024 You should be able to create a PKCS#12 (or pfx) as long as you have the key and certificate. I should probably refresh my self signed certificate because I did this 6 years ago but something like this should work. openssl pkcs12 -export -out domain.name.pfx -inkey domain.name.key -in domain.name.crt 1
Marco3G 6 Posted March 8, 2024 Author Posted March 8, 2024 I had to try three times and it finally worked. Couldn't tell you what I did wrong the first two times. I can connect to https internally and I just changed the setup for the reverse proxy. It works now. Thanks everyone. 1 1
Marco3G 6 Posted March 8, 2024 Author Posted March 8, 2024 Well, now I'm off to throw the VM away again and reinstall. I tried to activate hardware transcoding and now it's an NVIDIA trash heap and I forgot to take a snapshot. *sigh* I HATE, absolutely hate OSS, especially when you need proprietary drivers. I'm so tired.
Lessaj 484 Posted March 8, 2024 Posted March 8, 2024 (edited) What are you stuck on? Trying to install the nvidia driver? I've done this in my VM, I pass through the GPU to it. EDIT: Just saw your other topic, don't reply here! Edited March 8, 2024 by Lessaj
Marco3G 6 Posted March 8, 2024 Author Posted March 8, 2024 Well, from what I can tell, the driver is installed. nvidia-smi shows the GPU, EMBY shows me transcoding options under advanced... it just won't touch the GPU with a ten foot pole and one CPU core smacks to 100% and stays there in htop. I have no idea whether it's installed correctly. How to check that is documented nowhere.
Luke 42244 Posted March 11, 2024 Posted March 11, 2024 Hi, what makes you think it won't touch the gpu? Can we please look at an example? Thanks.
Marco3G 6 Posted March 11, 2024 Author Posted March 11, 2024 See the screenshot in the corresponding thread.
