jglazer63 23 Posted March 7, 2024 Posted March 7, 2024 I have noticed that for some reason some TV shows do not show the main actors on the synopsis page. It shows the director and other people (assumably guests but I cannot tell) but definitely not the main actors. Why is this?
Luke 42290 Posted March 8, 2024 Posted March 8, 2024 Hi there, can you please provide a specific example?
Happy2Play 9814 Posted March 8, 2024 Posted March 8, 2024 Yes would need specific example and metadata provider order.
jglazer63 23 Posted March 10, 2024 Author Posted March 10, 2024 Here is a screenshot of The Practice, Season 1 Episode 3. You'll note it doesn't show ANY main characters and only 1 actor and writer.
Happy2Play 9814 Posted March 10, 2024 Posted March 10, 2024 3 minutes ago, jglazer63 said: Here is a screenshot of The Practice, Season 1 Episode 3. You'll note it doesn't show ANY main characters and only 1 actor and writer. But there are none.
jglazer63 23 Posted March 10, 2024 Author Posted March 10, 2024 6 minutes ago, Happy2Play said: But there are none. Ahh I see. I have TheTVDB.com as the only scraper. I find it pretty inaccurate. I'll try switching to IMDB instead. Question though, what if I have them both enabled? Where does the info come from? Thanks for the response!
jglazer63 23 Posted March 10, 2024 Author Posted March 10, 2024 4 minutes ago, Happy2Play said: What providers do you have enabled? Yea, tvdb.com. Turning that off now....
Happy2Play 9814 Posted March 10, 2024 Posted March 10, 2024 2 minutes ago, jglazer63 said: Where does the info come from? Alway comes from first provider. As each sort of handle this info differently. But most don't want main show acters per episode.
jglazer63 23 Posted March 10, 2024 Author Posted March 10, 2024 1 minute ago, Happy2Play said: Alway comes from first provider. As each sort of handle this info differently. But most don't want main show acters per episode. Ok, I can't for the life of me, figure out where to change providers. Can you point me?
Happy2Play 9814 Posted March 10, 2024 Posted March 10, 2024 1 minute ago, jglazer63 said: Ok, I can't for the life of me, figure out where to change providers. Can you point me? Per library setup
jglazer63 23 Posted March 10, 2024 Author Posted March 10, 2024 2 minutes ago, Happy2Play said: Per library setup Oh, IDMB isn't available. Not sure this can be fixed the way I want it. But thanks for the info!
Happy2Play 9814 Posted March 10, 2024 Posted March 10, 2024 Just now, jglazer63 said: Oh, IDMB isn't available. Not sure this can be fixed the way I want it. But thanks for the info! IMDB has never been a provider option as their data cost too much. AWS Marketplace: IMDb Essential Metadata for Movies/TV/OTT (API) (amazon.com)
jglazer63 23 Posted March 10, 2024 Author Posted March 10, 2024 5 minutes ago, Happy2Play said: IMDB has never been a provider option as their data cost too much. AWS Marketplace: IMDb Essential Metadata for Movies/TV/OTT (API) (amazon.com) Thanks again. 1
