nague 5 Posted March 7, 2024 Posted March 7, 2024 I'm no longer able to transcode after upgrading to 4.8.30. All clients report "No compatible Stream" when transcoding is necessary. Only directstream is ok. I think there is something wrong with ffmpeg. Hardware transcoding is disable. Everything was fine with emby 4.7.x and previous versions. embyserver (3).txt
nague 5 Posted March 8, 2024 Author Posted March 8, 2024 (edited) Hi, Ubuntu 16.04 LTS Edited March 8, 2024 by nague
alucryd 318 Posted March 8, 2024 Posted March 8, 2024 (edited) Is Ubuntu fully updated (as in 16.04.7), it should come with glibc 2.28 which is the minimum glibc version we require. Edit: Scratch that, I was thinking of 18.04. 16.04 is way too old and is EOL since 2021, it doesn't meet the glibc 2.28 requirement. Edited March 8, 2024 by alucryd
nague 5 Posted March 8, 2024 Author Posted March 8, 2024 Now that you mention it, there was a warning about glibc during upgrade. I'll go for a fresh OS install. Thanks
Luke 42244 Posted March 8, 2024 Posted March 8, 2024 8 hours ago, nague said: Now that you mention it, there was a warning about glibc during upgrade. I'll go for a fresh OS install. Thanks Let us know how this goes. Thanks.
nague 5 Posted March 15, 2024 Author Posted March 15, 2024 Sorry, I need some time to proprely setup a new VM and migrate emby data. I'll come back to you asap. 1
Solution nague 5 Posted March 20, 2024 Author Solution Posted March 20, 2024 Just install a new VM with Ubuntu 22.04 LTS and import /var/lib/emby. It works like a charm, no more issue with ffmpeg. Thanks for your help. 1
