pschweig 6 Posted March 6, 2024 Posted March 6, 2024 Hi I scheduled a recording this evening and attempted to start playing it while it was still recording - it had been recording for about 45 minutes . It started playing sucessfully when selected from the recordings tab. However when I tried skipping forward a few minutes it didn't work properly. I clicked on the seek bar which said a time of approx 21:20 where my mouse hovered over it but the video progress indicator stayed pretty much where it was. The video moved forward maybe a minute but not the 20 minutes it should have done. Also the sound was badly out of sync at this point. I stopped the playback and tried to start from the video guide instead. I got an error after about 30s saying "No compatible streams available" I went back to the recordings tab and started the playback again but I had the same problem with moving the video forward 20 minutes Testing on my Windows 7 PC via the web browser. Logs attached - any chance of a fix for the above issues? thanks ffmpeg-remux-f602cfbe-a63e-4d07-a1c3-e57aa4c68b61_1.txt ffmpeg-transcode-db9a2181-25cd-42d7-8865-f1e717a0ff3b_1.txt ffmpeg-transcode-06d4e947-ca6f-42d4-ae08-29fd58d078b0_1.txt ffmpeg-transcode-b9ac1d09-a27c-4cfd-b411-efab26cf92e2_1.txt ffmpeg-transcode-5728b08d-d7b3-405b-a5bc-1f79e441fc83_1.txt ffmpeg-remux-fd8bfa36-ca67-417b-9ab2-4366d386af76_1.txt embyserver.txt ffmpeg-transcode-4a865421-1ef7-493e-9f01-7f3fd298be8d_1.txt
MBSki 1115 Posted March 6, 2024 Posted March 6, 2024 What app were you using? I've reported this issue for the standard Android app, but @Luke hasn't fixed it yet. Are you using the same app?
pschweig 6 Posted March 6, 2024 Author Posted March 6, 2024 It's via the web browser on my Win7 PC. I've had similar problems using Chromecast via iOS app but never got round to testing properly and getting logs 1
